11-20-2012, 05:44 PM | #71 |
2 wheel member
Drives: JZA80, 997.1, Taco
Good info!
When I saw results on the first page I
The Following User Says Thank You to RRnold For This Useful Post: | Jesse (12-01-2012) |
11-21-2012, 05:02 PM | #72 |
Drives: Frs
I just got my first oil change analysis back from Blackstone.
Same as everyone else, high wear and silicon. I did an easy 1K break in with varying RPM on the highway. After 1K I drove the car relatively hard. This oil also has 50+ autox runs. They did suggest to run the next oil change out 10k miles. I have my free oil changes, so I will probably do 7,500 miles. |
11-22-2012, 08:48 AM | #73 |
10,000 miles based on one uoa of the factory fill? Sometimes I really wonder about their comments. Did you not fill the bottle completely? Nice to see someone really pushing the factory fill instead of, "ZoMg! I need to change the oil at 50, 100, 500, 1,000, and 3,000 to get the metal bits out!".
-Dennis |
11-22-2012, 09:13 AM | #74 |
Drives: Frs
I had the dealership fill the bottle when they did my free oil change.
The TBN was still good so I think that's what they were referring to. I wouldn't be surprised if we could go longer than 10k for subsequent changes |
11-22-2012, 11:54 AM | #75 |
Drives: 2013 FRS Whiteout
Just sent mine in at 4k miles, eager to see what comes back.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
11-30-2012, 10:12 PM | #76 |
Seems like my Mobil 1 could make it to 6k, il see what my next analysis says.
The Following User Says Thank You to yomny For This Useful Post: | civicdrivr (11-30-2012) |
11-30-2012, 11:26 PM | #77 |
Drives: 2018 Golf R
@yomny, you might want to blur out your full address and phone number.
Parting out HERE
The Following User Says Thank You to civicdrivr For This Useful Post: | yomny (11-30-2012) |
12-01-2012, 07:12 PM | #78 |
Drives: 2013 Subaru SWP BRZ Limited 6AT
So I guess it goes to show that there's nothing to fear with Mobil 1?
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam. |
12-01-2012, 10:13 PM | #79 |
I've been using it in most of my cars, and i can easily acquire 0w-20 at my local auto parts.
12-01-2012, 10:35 PM | #80 |
I've always had great results with Mobil 1. It wasn't till I got here that I saw negative reviews of it. Glad to see you're getting good results with it.
12-01-2012, 11:08 PM | #81 |
Drives: 2013 FR-S Blue MT
@yomny your UOA has been the best one I have seen for this engine yet. You didn't have much oil shearing compared to nearly everyone else. What kind of driving do you typically do (highway/city percentage)?
12-03-2012, 10:20 AM | #82 | |
Your residual moly levels from the factory fill assembly lube and factory fill will drop, but I believe ExxonMobil uses the new trinuclear moly. Infineum Moly additive technology pdf. Similar friction modification and anti-wear with lower moly levels. -Dennis |
12-04-2012, 12:27 PM | #83 | |
I did a frist oil change at 150 miles, so that could be a good reason why. I drive the car a 50/50 between highway and city, plus i drive me car hard, not abusively but like a sports car.
The Following User Says Thank You to yomny For This Useful Post: | bestwheelbase (12-11-2012) |
12-06-2012, 09:51 AM | #84 |
This thread reminded me that you guys doing uoa's will really need to keep an eye on fuel and flashpoint. As I mentioned in the other thread, BS does not actually test for fuel dilution but they extrapolate the number from the flashpoint reading.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=968027 Interesting to see that Blackstone is recommending that the above interval be extended when the flashpoint has dropped to 375. Short trips will increase fuel, as will not taking the uoa sample on a hot engine or a couple of WOT runs before the sample. I would still be a bit cautious about following Blackstone's advice. I've pointed out errors in their uoa's before. Two cases were uoa's of Rotella T6 that came back with weaker zinc and phosphorus levels than a typical GF-5 5W-30, which is not possible. -Dennis Last edited by bluesubie; 12-06-2012 at 10:02 AM. |
Similar Threads | ||||
DIY BRZ / FR-S Oil Change | RallySport Direct | DIY (Do-It-Yourself) Guides | 169 | 09-01-2018 02:42 AM |
First Oil Change | Jehuty77 | CANADA | 14 | 08-09-2012 11:54 PM |
When to do your first oil change, and why... | MrBodyMassage | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 07-17-2012 07:43 PM |
Do you change your own oil? If so, why? | SteelReign | Other Vehicles & General Automotive Discussions | 77 | 04-16-2012 10:12 AM |
