Old 05-22-2013, 12:58 AM   #43
vubaru
Now with Boost!
vubaru's Avatar
Drives: 2013 SWP BRZ Ltd.
I like what @carbonBLUE has in mind for his build.
Also, it's cool he's down with the idea of a FMIC water spray kit, I posted about that while ago but folks seemed ambivalent about the potential benefits despite the cheap DIY nature of that mod, I think it's beneficial in hot temperatures. It's on my to-do list again.
vubaru is offline   Reply With Quote
Old 05-22-2013, 01:12 AM   #44
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Really? It was a joke.
eh it gave me an excuse to post how i wanted to do my build
yeah, this would actually be something i would use on hot days (98F-110F) when my car had been hard parked out side for a while.
Spray then drive and give it a couple more sprays to cool off the FMIC while cruising or when intake temps get hotter than i want.
and also for when i go to mineral wells.
I havnt decided on the gauges but i think im going to go with
1 boost pressure
2 af ratio
3 transmission temp
4 engine oil temp
5 intake temp
i might get a head unit that can give me digital displays of all that instead of doing pods... still dont know... i like my buttons on my radio too much lol
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 01-14-2014, 05:06 PM   #45
deadsailor86
Drives: 2013 Subaru BRZ
Last season I ran Fullblown's kit at 9 psi and made 310whp on 93 on the stock bottom end. we experimented with slightly higher boost levels but had to retard the ignition timing so much to stop it from pinging that we didn't see a very significant gain. in my experience, if you're running the car on pump gas, 9psi seems to be the threshold for safe, reliable power. that being said, I'm currently in the middle of installing a set of CP dropped compression ratio pistons (9:1) and a set of Brian Crower rods. I'll be interested to see what it makes on 15-20 lbs of boost at that CR.
Hope that helps.
deadsailor86 is offline   Reply With Quote
Old 01-14-2014, 05:16 PM   #46
lexusb3
Drives: FRS
my sig below are numbers based off the stock internals
lexusb3 is offline   Reply With Quote
Old 01-14-2014, 05:23 PM   #47
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Safe amount of boost on stock engine?
Holy thread revival from 8 months ago.
Once again, saying stock internals are good up to "x" psi is ridiculously arbitrary.
x psi Vortech is not equivalent to x psi Innovate is not equivalent to x psi FA20Club is not equivalent to x psi FBM is not equivalent to x psi PTUNING, etc.
If I were to run the PTUNING kit, as is, on pump gas without WMI @ 9psi, I'd run into problems in short order. However, if I were to run FA20Club 57trim @ 9psi on pump gas with a good tune I'd be ok.
There are other factors to consider, which are vastly more important than x psi.
With so many different configurations, designs and options it's rare to see any 2 setups exactly alike.
The most important relationship is that of the competent tuner, the meticulous owner and car.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 01-14-2014, 05:28 PM   #48
lexusb3
Drives: FRS
so tru!!! i posted im running 10psi ahhahhhahahha throwwwwbackkKK!!!
Old 01-16-2014, 02:07 AM   #49
Ludacrits
Ludacrits's Avatar
Drives: 2007 Porsche Cayman S MT
Originally Posted by Whitigir View Post
While many people on the forum or the internet may throw this out and around. Personally, I do not enjoy the idea of E85 neither do Meth injections. If I was to do this with my VR4, she would break 550 AWHP.
Meth Injections = Rusty part + 70% more for catastrophic failure (Not practical for every armatures )
E85 = Very few fuel stations, and the Fuel consumption is 2-3x times more of the traditional 93. Your full tank of gas may just serve you 1/3 of the original mileage range
The best possible is to build a car running on 93, with conservative tune.
The good news is that with 93, and running around 10 PSI will have you in the range of 300-350 RWHP already. This already makes this car into a beast
While you would consume more E85 than 93, you would be paying a lot less per gallon. It's more than a $1 less per gallon in my area than 93.
Ludacrits is offline   Reply With Quote
Old 01-16-2014, 01:04 PM   #50
LBC Por Siempre
LBC Por Siempre's Avatar
Drives: 2008 Toyota Prius, 2012 911 Turbo
Originally Posted by nix View Post
I heard via the ecutek and haltech networks of a few cars throwing rods around 300 .
Must be The TORQUE throwing those rods, not necessarily the Horsepower!
LBC Por Siempre is offline   Reply With Quote
Old 01-16-2014, 01:20 PM   #51
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
Just from basic numbers thrown around here on the forum, 300lb tq is around 450whp? Then I can see stock internals crapping out, rather than 300whp.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 12-06-2017, 07:25 PM   #52
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
3 Year Thread revival! It's a miracle!!
I know the game has changed but good read though. Conservative tune it is. I'll talk with my tuner to make a VERY conservative tune. I'm not looking at anything over 8 PSI or anything over 280 whp.
I don't believe Boost is just another number that doesn't matter, I think it absolutely matters
Instagram: 86_Maul
ShadowReaper is offline   Reply With Quote
How much spacer is safe on stock rear studs? wparsons Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 12-27-2014 01:49 AM
Amount of Brake Fluid.... THEmailman Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 04-13-2013 11:46 PM
2JZ engine swap on low boost - low 11's run HighLife FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 10 03-07-2013 05:55 PM
FS Stock Engine/Trans/Drivetrain ecda Engine, Exhaust, Bolt-Ons 1 02-13-2013 05:04 PM
What socket size and what torque amount for stock alloy wheels? Takeshi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-01-2012 10:25 PM
