Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
02-25-2013, 12:23 PM | #1 |
Some guy in a white car
Drives: 2013 SWP BRZ Limited
Smoothing out 1st and 2nd gears
hello all,
I was wondering what modifications were out there that would remove some of the notchiness from the transmission, especially when shifting from 1st to 2nd gears. It is definitely worse when cold or on a cold day. I was thinking about Motul 300 and the cusco transmission mount collar, or the Perrin transmission support. Will these mods help correct what I am looking for here? thanks for the help guys. PS I did do a search so please hold off on the
2013 Subaru BRZ Limited 6MT - Satin White Pearl |
02-25-2013, 12:29 PM | #2 |
Drives: Attitude
02-25-2013, 12:30 PM | #3 |
KCCO From Canada
Drives: Asphalt FRS
better fluid (pentosin 75w-80 is way thinner than stock and helps alot with cold shifting) maybe a rear stay bushing(TWM)? and whiteline's positive shift bushing may or may not help. (i would pick it over cusco's IMHO)
02-25-2013, 12:31 PM | #4 |
Drives: FR-S 6MT Ultramarine (BeeDrill)
I haven't tried the Pentosin yet but the Motul Gear 300 didn't do much to remove the problems I have with shifting when the transmission is cold. Once warm it works great though. Much smoother than the stock fluid.
2013 Scion FR-S - Ultramarine 6MT
02-25-2013, 12:57 PM | #5 |
Red is Fastest
Drives: 13 FRS 6MT Firestorm
Miles have helped mine more than fluids and bushings. When warm.
02-25-2013, 12:58 PM | #6 |
Just the tip
I did the pentosin 75w-80 fluid, whiteline trans mount bushing, perrin rear shifter, and a heavier (flossy heavyweight) shift knob and the notchy-ness has all but disappeared. See my build thread in my sig for more info.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes |
The Following User Says Thank You to stockysnail For This Useful Post: | tech4pdx (02-25-2013) |
02-25-2013, 05:05 PM | #7 | |
Make love
Drives: H8R.. Not really
02-25-2013, 05:34 PM | #8 |
It's affecting so many cars.. maybe there should be a sticky on this subject.
I'm going to try the trans mount & bushing too.. 8K miles and 3 tranny fluid changes later, I'm still having the 2nd/3rd gear grind occasionally. 2nd gear is by far the worst tho.. Notchiness/stubborness occasionally too, at random times. |
02-25-2013, 05:39 PM | #9 |
The Answer
Drives: Mazda 2
I will attend to fix this using GM/penzoil synchromesh fluid. I had very good results in the past with my old toyota and civic SI. I'd use pentosin but it seems to be hard to get that product here.
02-25-2013, 05:53 PM | #10 |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
^This. The big question is: How many miles are on your cars? We have to remember that, like the engine, the transmission (specifically the gears) need to break-in aswell. The "notchiness" you feel is the rough fitting between the gears brand new "sharp" teeth. I too have had the same issues and was slightly worried in the beginning, even feeling some notchiness going from 2nd to 3rd. Now that I'm at almost 8k miles, gear teeth are better matching and 1st to 2nd and 2nd to 3rd are buttery smooth.
02-25-2013, 06:11 PM | #11 | |
02-25-2013, 09:11 PM | #12 |
Agreed, in that case, you might be looking at something else. I guess the point I was trying to make is to allow the car to break-in first, then try other avenues such as a fluid change or bushings.
02-25-2013, 09:18 PM | #13 |
Drives: 2013 Asphalt FR-S
double clutching with rev matching goes a VERY long way at eliminating the cold 1 - 2 shift notchiness FWIW. FLuid will help, i don't see how trans bushing will do anything for cold shift notch as that has more to do with fluid operating temperature than trans flex / location etc.
~Namaste~ |
02-25-2013, 09:40 PM | #14 |
Drives: White BRZ
I've had very good results with Redline's gear oil. Removed about 80 to 90% of the issue and many days its perfect from the first cold shift. Its not cheap but definately worth the effort. When my son first drove it after I changed the gear oil, his first words on getting out of the car were "that stuff is magic in a bottle"....
Similar Threads | ||||
Speeds at each gears. | mickey177 | Engine, Exhaust, Transmission | 10 | 08-25-2016 06:40 PM |
What really grinds my gears! | CircuitJerk | Off-Topic Lounge [WARNING: NO POLITICS] | 128 | 04-01-2013 08:45 PM |
2nd gears a b*tch | Carbon420 | Scion FR-S / Toyota 86 GT86 General Forum | 32 | 01-29-2013 05:09 PM |
Changing Gears | Naughty | AFRICA | 10 | 01-09-2013 12:30 PM |
Top Gears - Worst Car in the World | KlafKoon | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 13 | 12-02-2012 09:20 AM |
