11-29-2017, 10:58 AM | #43 |
Drives: 2015 FRS - FFR GTM
Nice work,,,,, thank you!
2015 FR-S - One Day I'll Finish The Swap |
The Following User Says Thank You to gtpvette For This Useful Post: | ILLSMOQ (11-29-2017) |
11-29-2017, 02:24 PM | #44 | |
Drives: 2017 WR BLUE BRZ
Then put it on the flat part at back of the transmission It’s pretty much dead on parallel. |
The Following User Says Thank You to ILLSMOQ For This Useful Post: | DustinS (11-29-2017) |
11-29-2017, 03:26 PM | #45 | |
12-04-2017, 08:36 PM | #46 |
Started working on the mufflers
Something like that Fit good I’ll work on the tips later. Gotta wait on the tips. Once the rest of the exhaust is done, and I see where the mufflers end up I can finish the tips. The whole thing can be moved forward or backwards like the stock muffler...hangs exactly the same. |
12-07-2017, 12:36 AM | #47 |
Got the Sikky oil pan. Clearance is good but the oil cooler line adapter it comes with still leaves me in the same predicament...it hits the steering rack and would hit the sway bar.
I need something like this. Here’s how it worked out Hopefully this leaves me with enough clearance for the headers. |
12-07-2017, 03:57 AM | #48 |
Drives: 2015 frs
Looks like a good fix. Thanks for posting solutions to issues you are running into.
The Following User Says Thank You to Zer0 For This Useful Post: | ILLSMOQ (12-07-2017) |
12-07-2017, 11:51 AM | #49 |
I Love custom Turbo kits
Drives: Limited BRZ
Great progress!!
The Following User Says Thank You to Sportsguy83 For This Useful Post: | ILLSMOQ (12-07-2017) |
12-09-2017, 08:52 PM | #50 | |
Drives: FRS Silver LS1 swapped.
12-09-2017, 09:03 PM | #51 |
Maybe i should read first....see how u did the tank......890 B ?????? Hilarious worked with that stuff my whole career as a Aircraft Mechanic........Good stuff.
The Following User Says Thank You to cf6mech For This Useful Post: | ILLSMOQ (12-10-2017) |
12-10-2017, 01:10 AM | #52 |
So I’ve read after hours of surfing the web...and yes, you would know hahaha! I only added it (alot of it) as a precaution. Tank didn't leak after I re-formed it...but if it decides to leak later, this stuff should keep it sealed I think.
12-11-2017, 10:49 AM | #53 |
Jonesing about your work on corvette CAI set up.....was going to start ordering parts but decided to wait for your findings.....noticed also if you remove OEM hood latch and do some sheet metal trimming there is a lot of room above radiator....I have noticed an extreme loss of power in Texas heat with my set up.
12-11-2017, 11:35 AM | #54 | |
Latch needs to go for sure and some of the sheet metal. I’m finding my current problem is I have so many different projects going on with the car my efficiency in getting things done has gone down haha... I figured I need to stick to a category. Right now I’m trying to focus on all my AN lines...oil cooler and fuel and coolant but @DustinS brought up AN heater lines the other day, so now I’m doing those and that led to steam port lines (want to do a 4 corner system) ...still need to figure out what I want to do on the AC lines. But I’ll jump back in the intake today to work on the throttle body coupler. I ended up with 8 different 45 degree couplers and settled on this one. https://www.summitracing.com/parts/ppe-515404045 It was the most rigid of them all and had the most usable bend radius for my setup. I need to trim up the length. |
The Following User Says Thank You to ILLSMOQ For This Useful Post: | DustinS (12-11-2017) |
12-11-2017, 12:57 PM | #55 | |
Front of the hood hits the rubber coupler and maybe the k&n ducting. Pretty sure the fast 102 intake and the 102mm throttle body aren’t helping matters. k&n fits pretty good otherwise so far Flipped the k&n over Options are; cut the hood. Heat up the k&n and reform it a bit or both...to be continued lol.... |
12-11-2017, 02:02 PM | #56 |
So patience isn’t my thing lol
Cut the hood and trimmed the coupler I’ll clean it up later. But yeah it fits. |
The Following 4 Users Say Thank You to ILLSMOQ For This Useful Post: |
Similar Threads | ||||
Pure Automotive's MoTeC Plug and Play V8 Swap Thread | Pure Automotive | Engine Swaps | 51 | 11-25-2017 11:10 AM |
Pure Automotive's 2017 Race and Show Schedule | Pure Automotive | Mid-Atlantic | 4 | 01-21-2017 12:07 PM |
Pure Automotive Performance's White Street Fighter- 2JZ Swap - Formerly the FRSS LS2! | Pure Automotive | Member's Car Journals | 53 | 03-05-2015 06:11 PM |
Pure automotive pre meet | KslayFRZ | Mid-Atlantic | 0 | 07-19-2013 11:32 AM |
Anybody want to help me pick up my car at Pure Automotive? | TyperRspec789 | Mid-Atlantic | 4 | 01-31-2013 02:07 PM |
