Engine Swaps Discussion of engine swaps. |
11-17-2017, 12:15 PM | #15 | |
Drives: 2JZ FRS
the wheel speed is through the abs module, not through the ecu directly
11-17-2017, 12:23 PM | #16 | |
Drives: 2013 FRS Whiteout
No PS, No AC, No ABS, No speedometer, No Odometer, Might as well buy a total loss at that point because it's not even close to a street car. But yes, that would make it cost less. If you want to go that route I'll sell you a Race Pak and FRS Bezel designed for Race Pak dash, I have one here. |
The Following User Says Thank You to Pure Automotive For This Useful Post: | DustinS (11-17-2017) |
11-17-2017, 12:51 PM | #17 |
Our game plan with this car is to install every piece of the the swap that we sell, outline these parts and the install, and show you that they do fit and we support them 100% because we have personally installed them all piece by piece.
But what if I told you.......... We might sell this car as a complete running car when we are done..... Would anyone be interested? You would get to follow the build all the way through and see every part of it go together and then take it home when we're done. Thoughts? |
11-17-2017, 03:24 PM | #18 | |
Drives: 2JZ BRZ
by having an android tablet running as the dash, it will have speed, tach, fuel lvl, odo, and even more by adding in afr, boost, timing, knock... information provided by the ecu. This isn't a top of the line way of going about it but for some of the people wanting to save here and there, maybe this could be made as option or suggestion. Last edited by rob 2fast4u; 11-17-2017 at 03:37 PM. |
11-17-2017, 03:25 PM | #19 |
Drives: 2JZ BRZ
11-17-2017, 03:51 PM | #20 |
Drives: 2JZ FRS
nobody else has a fully functioning electronics setup yet that works without issue, at any price point. we built this package to make an easy, plug in setup that doesn't require you to re-wire half of your car or spend countless hours doing trial and error testing. We can't sell a "kit" based on the hopes that the end consumer can/wants to go through all that r&d. Also if that were the case, they wouldn't even be in the market for an electronics plug and play kit to begin with. We are not in the market to make a cheaper solution that needs a bunch of wiring, testing, setup, etc. It was as close to OEM as possible or nothing
The Following 2 Users Say Thank You to spitfire481 For This Useful Post: | shayangh (11-17-2017), Sportsguy83 (11-22-2017) |
11-17-2017, 03:56 PM | #21 | |
Drives: 2JZ BRZ
11-17-2017, 03:59 PM | #22 |
Drives: 2JZ FRS
Can't beat building an entire race chassis harness, so satisfying knowing every square inch of the car lol
11-17-2017, 04:04 PM | #23 |
Drives: 2JZ BRZ
haha yeah man, its alot to take in but its rewarding in the end, and makes you that more knowledgeable about your own car. When is the deal going to happen on your custom engine mounts Im getting close to that point
11-17-2017, 04:55 PM | #24 | |
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
depends on what we are looking at for the $$$$$ range
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside |
11-17-2017, 07:13 PM | #25 | |
Drives: Frs
Would you be interested in building another th400 car? |
The Following User Says Thank You to silthos For This Useful Post: | Pure Automotive (11-17-2017) |
11-17-2017, 07:17 PM | #26 |
Drives: 2015 Brz
Depending on when the project is finish and price absolutely!
If you build a car for attention, to me, you aren't a car enthusiast. You're an attention whore.
11-17-2017, 08:28 PM | #27 |
11-17-2017, 09:11 PM | #28 |
Drives: Frs
I need to find a shell first. I sent an email awhile back about y'all building me one but never got a response. I'll hit you up once i get a shell.
Similar Threads | ||||
Budget V8 Swap (under $10,000) | wutsaiu | Engine Swaps | 146 | 06-11-2018 08:53 AM |
Get Your Subscriptions In, We're Doing a Budget 2JZ Swap!! | Pure Automotive | Engine Swaps | 258 | 09-27-2017 02:41 PM |
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
$2K Budget. What Would You Do? | Skippman | Electronics | Audio | NAV | Infotainment | 46 | 02-22-2013 11:23 AM |
There goes my MOD'ing Budget | RedRocket | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 10-19-2012 08:14 AM |
