Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
01-30-2016, 12:45 PM | #15 | |
@anthonysestito
Drives: 2013 Sterling Silver Metallic BRZ
Agreed! Sent from my iPhone using Tapatalk
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO |
01-30-2016, 12:52 PM | #16 |
Drives: Ap2
I am downloading new ots file right now. Does e85 tune comes with lc and Ffs already enabled ? Last file had lc on stage2 but on e85stage2 was missing it.
01-30-2016, 02:04 PM | #17 |
Think that might have been the goal. Just easier to reuse and modify they restart altogether
The Following User Says Thank You to raven1231 For This Useful Post: | Cole (01-30-2016) |
01-30-2016, 02:05 PM | #18 |
Drives: Ap2
After new tune, my engine light came on, uo155. I restarted the car but light stays on, my oft says there is no engine light. Should I disconnect the battery ?
Nvm fixed !! Last edited by Who8myrice; 01-30-2016 at 02:23 PM. |
01-30-2016, 02:14 PM | #19 |
Not a troll
If I was in the market, this would be my first choice
The Following User Says Thank You to Cole For This Useful Post: | Shiv@Openflash (01-30-2016) |
01-30-2016, 02:20 PM | #20 |
Drives: 2015 Subaru BRZ Series Blue
What sort of gains do you expect ofh2 have over ofh? Worth upgrading?
http://instagram.com/cameronjones239
2015 Subaru BRZ Series Blue Build http://www.ft86club.com/forums/showt...09#post2002909 |
01-30-2016, 02:35 PM | #21 |
@anthonysestito
@Shiv@Openflash is there going to be any update to the site to purchase the OFH3 with the OFT as a combo like you previously had with the OFT + OFH (original) package?
Don't see it currently on the site but I am on a mobile device if that makes a difference (it shouldn't) Sent from my iPhone using Tapatalk
01-30-2016, 03:50 PM | #22 | |
Drives: 2013 FRS
The Following User Says Thank You to Shiv@Openflash For This Useful Post: | brzzy (01-30-2016) |
01-30-2016, 03:52 PM | #23 |
Drives: 2013 FRS
Minimal gains I'd say. Maybe 1-2whp and close to the typical run to run variance on a dyno. It's definitely an evolutionary upgrade, not revolutionary The OFH3 sees a couple who more since it replaces the slightly restrictive (bent and pinched) over-pipe.
The Following User Says Thank You to Shiv@Openflash For This Useful Post: | TouchMyHonda (03-11-2016) |
01-30-2016, 03:53 PM | #24 |
Drives: 2013 FRS
Looks like you fixed it. For others, the U0155 code is a communication code that is triggered by disconnecting any OBD2 device (like the OFT) while it is still communicating (data logging, data viewing, etc,.) with the OFT. No big deal at all. It will clear after a couple of ignition cycles.
The Following 3 Users Say Thank You to Shiv@Openflash For This Useful Post: |
01-30-2016, 03:56 PM | #25 |
Drives: 2013 FRS
We experimented with a 4-2-1 design early in the process. But for performance and packaging reasons, it didn't make the cut. Nothing wrong with it but was just not what we were looking for.
The Following User Says Thank You to Shiv@Openflash For This Useful Post: | tracerit (01-30-2016) |
01-30-2016, 04:52 PM | #26 |
Hey @Shiv@Openflash notced on new site two Open flash managers
1.24.0 & 1.28.0 assume its best to use 1.28.0 also no more template files not needed and more ? and no Windows8 patch not needed ? Thanks Steve |
01-30-2016, 05:32 PM | #27 | |
Drives: 2013 FRS
I will be putting Template files up like last time. I'll put the windows 8 patch up as well (although I don't think it is needed any longer). |
The Following User Says Thank You to Shiv@Openflash For This Useful Post: | steve99 (01-30-2016) |
Similar Threads | ||||
OFT350 (SBD/ZAGE) on E85 Dyno results | Shiv@Openflash | Forced Induction | 19 | 02-05-2016 12:00 PM |
Australian Dyno Dyno Results | Shiv@Openflash | Software Tuning | 11 | 07-22-2015 04:57 AM |
86 Dyno results | Anban | AFRICA | 18 | 01-14-2014 06:54 AM |
Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 07:00 PM |
TRD cat back, any dyno results | MTCRX | Engine, Exhaust, Transmission | 4 | 11-26-2012 06:26 PM |
