Old 08-10-2019, 07:36 PM   #29
ShibusaTouge
ShibusaTouge's Avatar
Drives: 2300LB FRS
Originally Posted by ermax View Post
The OEM rack is very compact. The assist motor is mounted to the column right behind the gauge cluster inside the cockpit. They specifically went with this layout to allow them to put the motor as low and far back as possible. Other Subarus do not use this layout.
Thing i have to worry about is wiring it to my Kseriesparts tucked K harness
ShibusaTouge is offline   Reply With Quote
Old 08-10-2019, 07:39 PM   #30
ermax
ermax's Avatar
I just read in another thread that as long as it has 12v it will have basic functionality. The assist will not change with speed though.
Old 08-10-2019, 07:51 PM   #31
ShibusaTouge
Drives: 2300LB FRS
Can you link that? that'd be great if I could keep it. My wheel is locked and I have to figure out I'm going to unlock it without getting rid of the rack.
Old 08-10-2019, 08:20 PM   #32
ermax
ermax's Avatar
K24, let's do this. TheVTEC86
I have no idea what it takes to get speed into it. I’m guessing it communicates to ver canbus for that.
When you say your wheel is locked I assume you are talking about the column lock. That should be easy to defeat by simply removing the lock physically.
I made a DIY for replacing the EPS coupler. You can look at that to get an idea of what is involved removing the column. It’s not that bad at all.
http://www.ft86club.com/forums/showthread.php?t=133606
Old 08-12-2019, 04:54 PM   #33
ShibusaTouge
Drives: 2300LB FRS
We got the engine apart!
The Following User Says Thank You to ShibusaTouge For This Useful Post:
Icecreamtruk (08-13-2019)
Old 08-12-2019, 04:56 PM   #34
ShibusaTouge
Drives: 2300LB FRS
Contacted AEM today and they said they should be able to run some CAN accessories on the column to allow me to keep everything.
honda, k24, racecar, swap, vtec
K24, let's do this. TheVTEC86 ShibusaTouge Member's Car Journals 23 08-14-2019 06:56 AM
