Member's Car Journals Car journals by our members. |
12-03-2019, 12:49 PM | #29 |
Site Moderator
Drives: Stuff
Not sure any future builds can have RCE products now.. good job Andrew.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
12-03-2019, 01:28 PM | #30 |
12-04-2019, 12:13 PM | #31 |
Drives: '13 BRZ TLM Spec
2013 BRZ Premium 6MT - Track Car, 2020 GMC Canyon Denali Duramax - Tow Vehicle, 2021 Forester Sport - Wife's Daily, 2016 Crosstrek - Daughter's Ride and always buying random flips...
07-23-2020, 11:48 PM | #32 |
Site Moderator
Drives: Stuff
ok so I just realized it's been a long time since I updated this thread... mostly because I'm lazy and with COVID I have been really lazy about working on the car.
Since the last update I think the following have been installed... ACE 350 header/overpipe ACE front pipe Swapped to the MXP CompRS dented up exhaust from the flood FRS @Opie and I bought SPC rear toe arms SPC rear LCAs Eibach R2 coilovers Cusco engine mounts Cusco trans mount insert Essex Comp sprint BBK I still have rear subframe mounts to install.. and a cage that needs to be built.. and a tune that needs to be done.. and seats.. and harnesses... and fire suppression... and a coolsuit system... and a tracbox.. and a switchpanel.....and jdm underpanels and a trans underpanel.. and I'm sure a bunch of other stuff like brake fluid since the pedal goes to the floor right now. Hopefully taking the car to Watkins Glen in early september. Anyways here's some updated pics of cage prep and misc crap. So first, using that little cap on the intake manifold to cap off a coolant line doesn't work really.. Replaced it with this which is sure to leak also Cusco trans insert ACE header/OP Some pics before I removed it and the graffiti Integra Type-R from my garage and moved them to storage Arrived at the storage place.. Cage prep starting. Dash/etc removed. Removing the blower motor and all the other HVAC crap. This job is absolutely fucking terrible. Beyond the dash you also have to remove the dash bar which is 8 main bolts plus the steering column (2 bolts to the bar, one mounting it to a bracket and then 1 for the bracket to the firewall) plus some pedal assembly bracket.. and then some twisting and pulling. Fuck this thing. Then started removing the rest of the interior.. also a pic of the brakes just because. I'll start working on it again tomorrow to gut the rest then need to figure out scheduling for alignment, tuning/dyno (since it's far from street legal) and the cage builder.. assuming the seat bases and other crap will arrive soon.
-Dave
07-24-2020, 11:00 AM | #33 |
07-24-2020, 11:24 AM | #34 |
Site Moderator
Drives: Stuff
Yeah I noticed those.. nothing was there and I didn't try to figure out what those wires were for so no clue what would have been tapped in.
-Dave
07-24-2020, 08:15 PM | #35 |
Site Moderator
Drives: Stuff
Went back to finish ripping the last few things out of the car today and to check a few other things...
Shockingly, the EPS coupler on this 2013 is actually in good condition: And eliminated the door panels: Now it's really ready for the cage builder: And I have a lot of random FRS parts making a huge mess in the storage unit......... anyone need some stuff? Next.. dyno/cage/corner weighting/alignment/brake bleeding/seat mounting/harness mounting/fire suppression install/some minor aero/who the hell knows what else... I have a month.. no problem lol
-Dave
The Following User Says Thank You to Dave-ROR For This Useful Post: | JesseG (09-15-2020) |
07-27-2020, 02:51 PM | #36 |
Geezus that Type R is not a shelf
The Following 3 Users Say Thank You to Opie For This Useful Post: |
07-27-2020, 04:06 PM | #37 |
Site Moderator
Drives: Stuff
-Dave
08-02-2020, 10:12 PM | #38 |
Site Moderator
Drives: Stuff
Did some more work on the car this weekend. Added metal to the firewall to block off the holes from the HVAC junk, installed the coolsuit mounting bracket, installed the fire suppression system bulkhead connector/passthru, installed a switch panel (to be used for the coolsuit and tracbox) with custom brackets, got the GY SuperCar 3R tires mounted and balanced and then put them on the car. Found that the belt was rubbing my Perrin intake too. At first though maybe the Perrin was the wrong one (17+ or something) but compared it to Will's and it matches exactly. My car does have Cusco mounts so maybe the engine is a little higher but seems weird still. Ended up trimming the tube on the airbox side to make it clear.
Didn't take too many pics - mostly of the switch panel work which is sheet metal bent with a 90 degree bend, some trimming to make it less likely to cut wires, riveted to the OEM stereo brackets and then rivnuts installed to attach the plastic panel. Eventually the fire system pull handle will go in the panel as well. Brackets: Close up of one: Switch panel installed: Red RPFs1 that I bought from @peaches mounted up: And of course, the most important track mod ever developed.... Progress for this coming week should be: alignment, tune, seat base delivery so initial bucket seat install, trans/diff fluid changes.. maybe some other misc stuff. Need to get the car to the cage building soon.
-Dave
The Following 6 Users Say Thank You to Dave-ROR For This Useful Post: | bcj (12-12-2020), JesseG (09-15-2020), Racecomp Engineering (08-03-2020), soundman98 (08-03-2020), Thefalls (08-03-2020), Ultramaroon (12-12-2020) |
08-03-2020, 08:58 AM | #39 |
Drives: '14 BRZ Limited
Looking good, it was too hot yesterday to be working on cars though
08-03-2020, 11:22 AM | #40 |
Site Moderator
Drives: Stuff
True. Unfortunately I need to have this car done in less than 30 days including the cage.. ugh
-Dave
08-03-2020, 01:40 PM | #41 |
Here are some more pics...don't forget all the excess wiring that was removed
The Following 2 Users Say Thank You to Opie For This Useful Post: | JesseG (09-15-2020), new2subaru (08-03-2020) |
09-01-2020, 10:11 AM | #42 |
Some pics from last nights progress on Dave-ROR's build...supposed to be loaded on the trailer by Thursday night for its first event...the push is on!
Similar Threads | ||||
FS: 2013 FRS Track build - FL | philooo | Tracking / Autocross / HPDE / Drifting | 3 | 02-08-2016 05:19 PM |
MVP Track Time 2013 Road Atlanta Track Dates | Feffman | Southeast | 7 | 11-05-2013 11:36 AM |
MVP Track Time 2013 Track Schedule and Invitation | Feffman | Tracking / Autocross / HPDE / Drifting | 13 | 10-16-2013 08:28 PM |
MVP Track Time 2013 Great Lakes/Midwest Track Dates | Feffman | Great Lakes | 5 | 09-07-2013 01:39 PM |
GPS Track Time- 2013 Autobahn and Blackhawk Farms Dates Here! | Chicago | Tracking / Autocross / HPDE / Drifting | 0 | 03-09-2013 10:38 AM |
