Old 12-20-2016, 01:15 PM   #2045
Bowen
Powered by Crickets
Bowen's Avatar
Drives: 14' SWP MT Limited BRZ
Originally Posted by FaDuck View Post
My plan is to go with 265's as well, and from what Ive gathered on this site, as long as you have coilovers/atleast a +40 offset/and -2 degrees camber, you should be fine. Hmmm...
Can confirm, I run 265/35 with a 38 offset on a 9.5 rim and -2.5 camber and I have more than enough room.
Build Thread / OFT Stage 2, Tomei UEL, Perrin Resonated, ST Coils, 2 Sets of Wheels, Rally Armor, TOMS Tails.
Bowen is offline   Reply With Quote
The Following User Says Thank You to Bowen For This Useful Post:
amaciose (12-20-2016)
Old 12-20-2016, 01:52 PM   #2046
amaciose
amaciose's Avatar
Drives: 2013 BRZ Limited
Yeah I didn't think I was asking for anything too crazy from them.
I'm running 265/35/18 on 18x9.5+40. KW V3's and lowered 3/4". I asked them to decrease the rear camber from factory settings to around -2° to -2.5° and they said there's no room on the inside to add more negative camber. I'll be swinging by their shop shortly to check it out.
amaciose is offline   Reply With Quote
Old 12-20-2016, 02:05 PM   #2047
Bowen
Powered by Crickets
Bowen's Avatar
Yea that's not true at all. My ST coils (a daughter company to KW) are able to run -2.5 in the rear no issue. That's with the stock top hats and control arms too! They might be saying they can't do it so you don't get upset with them later on down the line if your tread isn't wearing evenly... regardless, just tell them to make it happen haha.
Old 12-20-2016, 02:47 PM   #2048
amaciose
amaciose's Avatar
You guessed correctly.
It was a miscommunication between the technician and the rep on the phone. Technician just wanted me to be aware of all of the 'problems' with cambering a wheel. The rep stated that there was no clearance to camber.
I requested -0.8°/-2.2° F/R. Hopefully that helps me clear the fender without adding too much tire wear.
Old 12-21-2016, 10:39 AM   #2049
amaciose
amaciose's Avatar
They brought the rear camber down to -2.3° and the wheel is about flush with the fender now. I tested the fitment out by going up my driveway and when all the weight shifted to my left rear coil, I noticed I'm still having a ton of rubbing issues with the top of the fender hitting the tire sidewall.
I guess I'll look into rolling and pulling the fenders now? I didn't think my setup was aggressive enough to need that. Don't really want to add much more camber because my car is pretty much a DD and I don't want the excess wear.
Old 12-23-2016, 05:21 PM   #2050
nima314
Drives: Subaru BRZ 2017 (almost)
Putting the coils and wheels on, guards are fully rolled, nice and soft in the '17 BRZ! As in factory rolled. Didn't need to do any! 9.5" wide +38
Sent from my Nexus 6P using Tapatalk
nima314 is offline   Reply With Quote
Old 12-23-2016, 07:23 PM   #2051
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
what tire are you running? Doesn't really sound right that things are rubbing.
fwiw, I ran -2.5 (hell I still am) and have minimal camber wear. I only notice that its more worn down on the insides when the tires are just about done anyway.
which wheel are you running as well? Maybe they aren't actually +40?
Old 12-24-2016, 01:32 PM   #2052
amaciose
amaciose's Avatar
I'm running MPSS 265/35/18, wheels are Gramlights 57xtreme 18x9.5+40 with KW V3s. I've seen this exact setup on other cars which is why I'm so confused.
I had the camber adjusted to -1.8 and the tires really don't poke that much, but the fenders still hit the outside tire sidewall when the coils compress. I guess another option is to get stiffer springs or increase my compression settings?
Old 12-28-2016, 09:21 AM   #2053
batlwagn
Drives: 2016 Outback 3.6R, 2016 BRZ(ordered
265/35R18 Hakook V12 Evos Enkei NT03+m 18×9.5 +40 running a 5mm spacer to clear my brakes on Apex'i coilovers no issues
Sent from my SAMSUNG-SM-G890A using Tapatalk
ALL THE MODS!!
batlwagn is offline   Reply With Quote
The Following User Says Thank You to batlwagn For This Useful Post:
Leonardo (12-28-2016)
Old 12-28-2016, 12:08 PM   #2054
Leonardo
Country Boy 4 Life
Leonardo's Avatar
FIFY
Looks great!
via Imgflip Meme Generator
I LIKE TIRES!
batlwagn (12-28-2016)
Old 01-02-2017, 05:32 PM   #2055
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
where are you rubbing?
i ran that setup for a long time
Jive Turkey is offline   Reply With Quote
Old 01-03-2017, 10:50 AM   #2056
amaciose
amaciose's Avatar
The lip of the fenders are hitting the tire sidewalls when the springs compress. Did you manage to get the wheels to tuck inside the fender or did you just increase your compression settings?
Old 01-03-2017, 10:39 PM   #2057
Jive Turkey
the tuna, no crust.
i had rolled my fenders, and i ran pretty soft settings. i also had a front sway.
The Following User Says Thank You to Jive Turkey For This Useful Post:
amaciose (01-04-2017)
Old 01-07-2017, 03:53 PM   #2058
FaDuck
Drives: 2014 UltraMarine FRS
So I read that @texasbound972 was/still is running a 275 tire... Since I'll be making roughly 450whp I would like to also go that route. BUT, not in the front.
So my question is:
Im planning on going with NITTO INVO tires and Tiresize.com has a chart with all the sizes you can go with. Ideally a 235/40 (819 rev/mile) and a 275/35 (814rev/mile) would be the way to go, but Ive never seen anyone run a 40mm difference in tire width. Would that cause bigger steering issues?
-OR-
Go with a 245/45 (779 rev/mile) and a 275/40 (780 rev/mile)... But they are much taller. I know my speedo will be off a bit, but besides that, is it really that big of a deal going this route?
Otherwise I would stick with the 275/35 (814 rev/mile) and go with a 245/40 (802 rev/mile).
FaDuck is offline   Reply With Quote
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
