Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
05-26-2019, 02:28 AM | #1 |
Drives: FRS RS 2.0 #757
Coolant levels
Hi, got my frs just over 3 weeks ago. I noticed that the coolant level when the car has been sitting over night, is just slightly above the low level mark. When I drive it, the coolant goes to almost to the full level mark, but it doesn't go all the way to the full level.
Is this normal for these cars? I'm not sure what to think, because I just got this car. |
05-26-2019, 02:43 AM | #2 |
Coolant expandes when hot, into the expansion tank, it will then return to the system when cold via the vacuum.
I set my coolant to the full when cold. https://www.quora.com/How-does-a-rad...flow-tank-work
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
05-26-2019, 03:02 AM | #3 |
義理チョコ
It's normal for every car.
05-26-2019, 03:54 AM | #4 |
Drives: WRB Subaru BRZ Limited 6MT
Absolutely normal for every car. In my experience with this car, if you fill the expansion tank to the "Hi" line, the level will drop to just above the halfway point between Low and Hi after just one drive, even if you have recently bled the system. So I guess what I'm saying is: don't chase the reservoir level after every drive; you're just wasting coolant as it must weep from the motor at some point. Personally, when the reservoir level drops below "Low," I fill to halfway and keep an eye on it. But maybe that's just my car...
05-26-2019, 10:23 AM | #5 | |
Drives: 2017 toyota 86
05-26-2019, 03:35 PM | #6 | |
humfrz |
05-26-2019, 11:56 PM | #7 |
Ok, thanks for the info guys.
The Following User Says Thank You to Phuviano For This Useful Post: | humfrz (05-27-2019) |
05-27-2019, 05:10 PM | #8 | |
The car does gurgle a little on shut down at what seems like the heater core, which has always led me to think the core is just hard to bleed on my car. I got it to go away for a few weeks after changing my coolant and meticulously bleeding it but the sound has since returned and it doesn't seem to be affecting anything. Maybe there's a small crack in the core that evaporates before it hits the ground. I'm sure as hell not removing the dash to find out lol. |
Similar Threads | ||||
How is it possible to lose coolant, if the coolant system in a car is a closed loop, | ghostzfh | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 09-12-2020 01:09 AM |
Coolant level dropping & Dirty coolant | redwine | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 44 | 09-30-2018 08:37 PM |
Coolant loss - Void Warranty/ Edit: coolant flush question | BRZach | Engine, Exhaust, Transmission | 15 | 01-02-2016 08:21 PM |
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? | mike the snake | Forced Induction | 8 | 04-01-2014 05:56 PM |
Coolant Levels | DriftEightSix | AUSTRALIA | 17 | 01-29-2013 09:19 AM |
