04-29-2019, 10:14 PM | #3585 | |
Drives: 2013 FRS
I think my mistake the first time was I started adjusting on the wrong corner. Then ended up compensating for that. Sent from my SM-G960U using Tapatalk
WIFE: "How can there be anything left to buy?"
The Following 2 Users Say Thank You to bmacfrs For This Useful Post: | H1C (04-29-2019), strat61caster (04-29-2019) |
04-29-2019, 10:19 PM | #3586 | |
Drives: 2013 FRS
04-29-2019, 11:37 PM | #3587 | |
Making sure the pads (and consequently the car) is level is a big deal too, using a laser level and all four corners are <0.1" difference. After adjustment car is shaken by hand to help settle, handbrake off as that binds up the rear suspension. Our other car balances much more easily, the FRS is just hard to pin down for me, starting over might do the trick unfortunately, I might have messed something up on the initial setup of the coilovers. Rob Robinettes site is pretty great for those that are looking into leaning more about diy setup, the link above is good reading on how one guy does it, but there are many ways to skin a cat. The suggestions are appreciated, some deep breaths and lots of patience |
04-29-2019, 11:59 PM | #3588 | |
Drives: 2014 FR-S MT
I think I was lucky that my garage floor is uneven when I installed my coilovers, so I couldn't rely on fender heights to set the ride height. I decided to ignore the fender heights and just get the spring perch heights even left to right, measuring the threads on the shock bodies. I would up lowering the front first as low as it could go with 6" springs and no helpers, while keeping the springs captive at full droop. I measured the threads on the struts to check if it was even left to right. Then I lowered the rear, trying to get a 0 rake as measured at the front and rear jacking points by the pinch welds to the floor. I again measured the threads on the shocks to get it even left to right, but then came back months later to lower the RR a couple of mm, after noticing (and having it confirmed by RCE Andrew) that the RR seemed to sit high with the L and R spring perches set to equal heights. I was surprised how balanced the LF/LR = RF/RR equation turned out to be using this guesstimated approach. I think Toyota and Subaru designed an inherently well balanced car. Last edited by H1C; 04-30-2019 at 12:32 AM. |
04-30-2019, 07:40 AM | #3589 |
Drives: 2016 Scion FRS
My friends built wheel stands with adjustable feet. For slip plates, we use a bottom plate with a bunch of holes drilled in it, then fill the holes with ball bearings. Place a 2nd solid plate on top. And the stand contains the bearings when the inevitably get loose.
Much prefer it to messing with grease/garbage bags, etc. |
04-30-2019, 08:20 AM | #3590 |
I simply created wood blocks as 2' roll off area behind the scales, where I'll just roll the car forward and back to unbind the suspension.
My perch heights aren't equal on any corner relative to another. Sure, it's a good starting point but not going to get you the corner weights that you want/need
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post: | strat61caster (04-30-2019) |
04-30-2019, 09:34 AM | #3591 |
I hit cones.
Drives: 2015 FRS
So much easier than having to constantly jack the car up, cheap and easy to build too.
The Following 5 Users Say Thank You to ein86 For This Useful Post: | bmacfrs (04-30-2019), DocWalt (04-30-2019), justint5387 (05-03-2019), Racecomp Engineering (05-22-2019), steverife (04-30-2019) |
04-30-2019, 11:13 AM | #3592 |
Drives: 2013 FRS
I found this article helpful too.
https://dsportmag.com/the-tech/diali...balancing-act/ I really like their chart on what to adjust. attached.
The Following 3 Users Say Thank You to bmacfrs For This Useful Post: |
05-03-2019, 07:28 PM | #3593 |
Drives: 2013 FRS
Wow racerx has some good fast shipping. I just ordered them the day after I asked about endlinks on here and they came today. With some gum.
The Following User Says Thank You to CoolHandMoss For This Useful Post: | strat61caster (05-03-2019) |
05-22-2019, 07:04 PM | #3594 |
Drives: 23 BRZ 15 Impreza
Does anyone know if front control arm front bushings are STX legal? I'm looking for a hair more caster if possible. If they aren't legal would the group N bushings for the 08-14 wrx fit? It seems like this bushing tears on other Subaru's fairly often.
https://www.suspension.com/superpro/spf3877k https://www.whiteline.com.au/product...CA434&sq=22922 |
05-22-2019, 08:36 PM | #3595 |
Drives: 2013 FRS
As long as it has the same metal and rubber content. It can't have more metal and less rubber.
05-22-2019, 08:42 PM | #3596 | |
You'd have to give up the camber plates to use offset LCA bushings since they affect camber as well as caster imho and would be considered 'modifying the lower control arm'. The SPC looks like it runs afoul of 14.8.B by being a ball/spherical joint but the Whiteline looks like it could be kosher, but no way in hell it's worth giving up whatever camber plates+bolts you have. For this car I'd recommend the Raceseng camber plates or Vorshlag has some that add caster as well unless of course you already have some caster from your plates. |
05-23-2019, 11:58 AM | #3597 |
Drives: 4 wheels
You can change the control arm bushings without giving up the camber plates.
Changing the bushing does not equal to changing the lower control arm. |
05-23-2019, 12:16 PM | #3598 | |
Man fuck these rules, I'm still pissed about the multi-link one arm judgement, makes no sense the way it's written. Don't get me wrong, I know you know your shit and half a degree of caster is nice but not game changing. I wouldn't mess with it but I can see the rules reading it as allowable per 14.8.B which is allowed with camber plates, but it's effectively modifying the LCA length which is what the 14.8.H.2 says you can only do if you don't have plates. I'll shut up now |
The Following User Says Thank You to strat61caster For This Useful Post: | justint5387 (05-24-2019) |
Similar Threads | ||||
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
