05-24-2018, 04:54 PM | #4551 |
05-24-2018, 07:10 PM | #4552 |
pessimistic skeptic
05-25-2018, 06:38 PM | #4553 |
Drives: 2015 Scion FR-S 1968 Camaro BB402
Here’s a question:
Logs have been showing .33 adv mult. I hear my throwout bearing talking to me... not really its more just a definite knock. Question time! Can the Knock sensor recognize this unholy romping as knock?? I for sure know what knock sounds like, and I am not getting knock:/ Also, what kind of mass air flow rates (g/s) are normal? I’m getting around 211 g/s (28 lb/min) which really doesnt add up considering the max for the C38 is around 1032 CFM, about 77 lb/min... ________ ~refer to username~ |
05-25-2018, 06:59 PM | #4554 | |
05-30-2018, 01:32 PM | #4555 |
Drives: 2017 Subaru BRZ Limited
How much of babying and monitoring do people DD their JRSC? Is this kit reliable to the point you don’t have to pay extra attention to every details under the hood each time you drive?
05-30-2018, 04:48 PM | #4556 |
pessimistic skeptic
Well, you have to monitor and take care of your car a little differently than the stock car. The dealer will not take care of everything for you anymore. I just got a P1072 the other week, for example. I didn't take it to service or post here. MAF had to be cleaned, cleaned it and the CEL is fixed. MAF needs to be cleaned more frequently than stock car. I listen the engine every day if recirculation valve is working when the car is idle or when I release the throttle after boost. The compressor can get damaged without that valve working properly. I monitor the sound of supercharger every time. Keep an eye on traction fluid, regularly clean and oil the air filter. Empty the catch can, if you install one. Just such little extra care which is fun actually.
05-30-2018, 05:08 PM | #4557 |
Drives: 13 BRZ
I don't monitor anything with the JRSC more than I monitor any other car. Check the oil in the system occasionally, follow the maintenance guide, if you hear/feel something wrong, address it. The only problem I've had since getting the JRSC, 15-20k miles ago, is a dirty belt.
05-30-2018, 05:19 PM | #4558 |
Wow, that is a lot of work not to mention I don’t understand half of the terms you just mentioned lol.
05-30-2018, 06:11 PM | #4559 |
Drives: 2017 BRZ
05-30-2018, 06:19 PM | #4560 |
pessimistic skeptic
05-31-2018, 04:07 PM | #4561 | |
Drives: '14 BRZ, '01 S2K
As for driving, I just warm up for a couple minutes every morning and keep the revs low until the engine it up to operating temperature. You can get decent oil temp readings from the Torque App and a OBD2 scan tool. There's a thread with the formula and sensor setting for torque to get the oil temps somewhere in the forums. The only other thing I monitor is engine oil pressure which I have a gauge with a sensor installed in place of the oil gallery plug. Mainly for my own peace of mind but I don't think it's necessary. Hope this helps. Last edited by Xiao Li; 05-31-2018 at 04:26 PM. Reason: spelling errors |
05-31-2018, 06:13 PM | #4562 | |
Drives: 2013 Subaru BRZ Premium
Check the rotrex fluid and empty your catch can (if applicable) whenever you do an oil change. Clean and oil the intake filter every 15k/20k Sent from my XT1650 using Tapatalk |
06-01-2018, 04:59 PM | #4563 | |
Drives: 2014 BRZ
Yes, there a few new maintenance items over stock, but nothing on a more frequent basis than stock.
06-01-2018, 06:05 PM | #4564 |
Who has JRSC with aftermarket header? Anyone pairing it up with Tomei EL? What’s your review?
Similar Threads | ||||
Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
