02-16-2018, 01:54 PM | #309 | |
Drives: 22RE, FA20, 4G63
Vortech Owner Thread & Setup Questions
I think I understand... wait wait wait you have the car currently with out engine? Right? And the sc shouldn’t be near the engine bay? Right? So why don’t you search, lest said on eBay for 6 rib pulley of 3” diameter and buy the cheapest one that is in new condition, then buy, also on eBay the one way bearing (you will need some measurements that I could provide) Then take all 3 of them to the machine shop and explain how it should work. That’s basic what I did, I only put the idea and some elbow grease but the machine shop thing... I do not have any kind of training for that but know someone that I really trust and this is a second car that I like to used daily. After the modification is done, reinstall as it was and use a proper size belt. Sent from my iPhone using Tapatalk Last edited by AJPG; 02-16-2018 at 02:07 PM. |
05-09-2018, 09:31 PM | #310 |
Drives: '15 BRZ, Vortech supercharger
PSA: change your oil, folks
I bought my BRZ with a Vortech SC kit already installed. The car was bought at auction after being repossessed, so it had no records other than what Carfax showed. Not knowing how well the car was taken care of, I wanted to do as much preventative maintenance as possible and changing the supercharger oil was part of that.
The car has 27k miles on it, so I guess its possible that the supercharger could have the same, but i think it's safe to say the previous owner wasn't really keen on that 7500 Mike oil change interval... I might have a $1200 major rebuilt in my future. |
05-17-2018, 07:53 AM | #311 |
Drives: 2018 BRZ tS
Is anyone running the Vortech Kit on a MY 2017 or 2018? If so, any install/clearance issues. It seems it's a bit hit or miss with what kits will work on the 2017/2018s.
05-18-2018, 02:01 AM | #312 |
Drives: 13 BRZ Limited WRB
Anyone here do much Logging with EcuTek? Specifically, has anyone looked at what actual boost levels you're getting? I'm reviewing logs from pre-built motor to now post-built motor, and comparing boost levels. On average, at around 7300RPM i'm seeing about 7.5lbs of boost. Does anyone else have data to compare to?
If you just have a log, I can pull the data for you. Thanks!
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925 |
10-24-2019, 09:28 PM | #313 |
Drives: 2013 FR-S Argento
Hi fellow vortech folks, installing mine now and have been having a heck of a time getting the belts on and off.
Using a 14mm ratchet, I start from as far as I can against the crank hub/belt and pull until the ratchet handle hits the bracket holding the dipstick and I still have a lot of trouble getting the belt on. Even with all slack out of the other pulleys. Trying to put the belt over the alternator pulley last. Any tips? Was thinking of wedging something in between the hub and tensioner pulley so I can wind the ratchet back a few more notches. Or should I try another pulley? The sc plate tends to get in the way. Any help/wisdom would be greatly appreciated, thanks! Sent from my SM-G965U using Tapatalk |
10-24-2019, 11:52 PM | #314 | |
The easiest pulley to use to slip it on / off would be the smooth edged one just below the Supercharger.
The Following User Says Thank You to Gopherboy6956 For This Useful Post: | bfrank1972 (10-25-2019) |
10-25-2019, 10:44 AM | #315 | |
Thanks so I had the old belt on from before and had to adjust my SC alignment, so I put a wrench on the tensioner and zip tied it to a bolt used for the SC side bracket lol. Before taking the belt off the tensioner was already pulled over by the belt so I could get enough room with a wrench to max it out. Pulled the belt off, left the zip tied wrench in place, and was able to get it done. Though I dunno about these belt sizes - I put on a new Gatorback 4060970 belt and it was ALL I COULD DO to get that dang thing on there. Tried the smooth idler but no go. Actually went back to the alternator, got it hooked enough over the lip so it would grip, and literally grabbed the belt on the opposite side and turned the motor over a few inches. Was able to get it to ride up on the pulley, but dang. Took the wrench off the tensioner and there was very little movement, so seems like the tensioner is near max with just the new belt. AND... that's with a smaller 3.125 pulley. Everything else looks in line and properly routed, so not sure why it's such a tight fit, seems like it should be easier... |
10-25-2019, 10:32 PM | #316 | |
10-26-2019, 05:26 PM | #317 | |
01-06-2020, 10:59 PM | #318 |
Drives: 13' Brz
Just wanted to share my vortech build, im going to get it dyno’d soon. Hoping for 400whp+
Its been boosted for 55k miles now. My brz has 87k miles currently on stock motor, still holding up fine *knocks on wood* Oh, its only been about 10k miles since i swap from 3.33 pulley to the 2.87. Mods: - Vortech v2 w/2.87 pulley @15psi on e85. - 1050x ID - 65c DW fuel pump - Radium catch can - Radium fuel rails - Ptuning flex fuel kit - Custom intake setup to front of bumper (thanks to pure automotive for the design) - Max bov upgrade - 2017+ red intake manifold - 72mm grams throttle body - p3 multi vent gauge w/ analog boost reading - oil pressure gauge - afr gauge - 19 row oil cooler - Csf radiator - tomei UEL headers - JDL 3” overpipe/front pipe combo (catless) - 3” Greddy Ti single exit exhaust That’s basically it for power mods, other than that full suspension has been done coilovers, control arms, solid rear mounts, braces, etc..the list is long lol. Currently tuned by mike @xero limit (aka moto-east) I definitely recommend him. I have 2 separate maps with different timings. One for daily “conservative” and other one is “kill mode” |
The Following User Says Thank You to Try Again For This Useful Post: | Fish Eagle (01-07-2020) |
01-20-2020, 06:52 PM | #319 |
Drives: '15 Vortech Supercharged
Hi, is anyone else using Torque for a boost gauge able to verify the accuracy of it with this car and SC kit? I recently bought a 2015 that already has the Vortech kit installed and I've used Torque with all of my other cars with few issues, but this seems wonky.
Shows between -12psi and -9psi on idle or deceleration and sits right at zero when the engine is off and the ignition is in accessory which all seems right, but the boost seems to peak at around 2psi by like 5000rpm or so. Never reads any higher than exactly 2psi on Torque's boost gauge. This kit has the 3.48" pulley and the supercharger itself says "H67B" so I was expecting to see somewhere around 9psi max. I haven't driven a stock FRS in a couple of years but this one really doesn't feel down on power at all. I mean it's on tires comparable to OEM in a wider size and it can easily power oversteer in the middle of second gear which my stock 2013 never could manage to do. Definitely doesn't feel like 2psi, plus I assume if the car was leaking boost by nearly 80% it would be running very very poorly right now which it's not. |
01-21-2020, 12:03 AM | #320 | |
Drives: 13' Brz
The Following User Says Thank You to Try Again For This Useful Post: | jstn (01-21-2020) |
01-21-2020, 10:30 AM | #321 | |
01-21-2020, 04:42 PM | #322 |
Not sure about that, or about torque, but my ecutek logs show manifold pressure fairly accurately. I imagine that's what torque is reporting but not sure? Are you tuned with a MAP sensor, and is that MAP sensor aftermarket?
Similar Threads | ||||
STX Rules and Setup Questions | Scooby South | Tracking / Autocross / HPDE / Drifting | 3914 | 07-18-2023 04:16 AM |
Questions and Discussion on Vortech Supercharging Systems | Brian@Vortech | Forced Induction | 1462 | 01-27-2017 02:05 PM |
Vortech Offical Owner Thread | cjsporl1996 | Forced Induction | 2 | 03-27-2014 12:50 AM |
Who to tune Vortech setup? | pheoxs | Forced Induction | 18 | 02-20-2014 02:58 AM |
Sprintex or Vortech, which setup has more potential? | Turbowned | Forced Induction | 328 | 09-14-2013 11:09 AM |
