Old 12-16-2013, 11:25 PM   #99
toekneehair
toekneehair's Avatar
Drives: 2013 Subaru BRZ/FBM turbo flexfuel
Originally Posted by Element Tuning View Post
I never had any issues on the street or on the dyno in terms of operating temps. Max power 400whp (baseline 153 whp).
Element Tuning Hydra EMS
FA20Club 60T turbo kit (header wrap and turbo cover)
Full Blown Radiator (oem fans and shroud)
90% water and water wetter
AC condenser in place
E85
Ok so when I was NA and racing even with oem radiator I never had issues even in 90+ f. In boosted trim we did have problems but they may have been mostly due to a pin hole leak in the radiator. When I first raced my boosted setup at NJMP at around 350whp I can say I had real issues but it did get warm but nothing dangerous. At the next two races we overheated into the red on every session and that's when we got desperate.
Most of it's common sense and the grill opening is very smal almost every inch covered by the FMIC, and the engine bay pretty sealed up. We also have an extended diffuser. We ditched the skid plate which gave us more exit volume. We cut a hole in the hood and added a gurney. We also cut holes in the bumper skin above the bumper beam (they needed to be bigger but that's what we had at the track). We also pulled the rubber seal at the wiper tray. All of this helped but one thing hurt us at one point and that was a cut through fendet liner. Do not underestimate how much pressure that will pump into your engine bay. Fix it or make new liners for bigger wheels etc.
In the end we found a pinhole leak in the radiator that only surfaced under racing conditions. At the track fix was "stop leak" and it appeared to have settled engine temp but then boom and she caught on fire as most know.
From my experience with cooling issues like this in general, the rad volume is just too little for 400+hp under racing conditions and their is too little entry volume of airflow. To improve flow you have to dump pressure out of the hood. Get more air to the radiator and you may have to cut bumper vents (you can do it nicer than I did). For fans its hard to beat the oem and shrouding for street and I bet for many your slim fans are worse (seen it many times). To run slim you need a shroud and you need some high dollar, super high cfm units, to do the trick.
Nothing off the shelf will do the trick for what we have planned for our FRS next season.
Thanks,
Phil Grabow
Can the fender liner really cause that much of an issue? I had one of mine pop out after getting caught on a curb then somewhat burned off. so I have a big hole behind my oil cooler right now. I thought that would help air either way so I wasn't to concerned when I found it. how does it create pressure inside the engine bay?
toekneehair is offline   Reply With Quote
Old 12-16-2013, 11:51 PM   #100
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
At low speeds no, but at high speed absolutely. The pressure from the rotating tire is massive which is why you see such massive vents on top of the fender and huge exits on the rear of race cars.
Element Tuning is offline   Reply With Quote
Old 12-16-2013, 11:58 PM   #101
toekneehair
so where can I get replacement fenders? just dealerships I imagine?
Old 12-17-2013, 12:06 AM   #102
Element Tuning
Originally Posted by Dipstik-sportech View Post
E85 runs considerably cooler than pump gas, that's probably why you've never had an issue. I'm going to try a different fan setup and if I can find a decent one a vented hood.
No problems with pump gas either in NA form. Boosted I was always on e85. The fuel helps but lets not forget I'm WOT for lap after lap.
Don't overlook the obvious and that low splitter reduces under car pressure substantially which helps exit engine bay pressure.
Old 12-17-2013, 11:23 AM   #103
mike the snake
Which aftermarket hood do you think would be the best at reducing engine bay temps?
From reading here, one with vents more towards the front?
Old 12-17-2013, 12:24 PM   #104
Element Tuning
Which hood, I haven't looked too much at what's available. After we are done building our engine etc. I'll make a decision to either buy something or work with the OEM hood. The vent over the turbocharger would be great for street cars since it will dump turbo/exhaust heat out instantly but at speed it doesn't have to be there unless you are ducting the radiator (hard to do with a turbo kit there).
Old 12-17-2013, 12:37 PM   #105
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
I've been told that the Seibon VS hood would be most effective since it is properly louvered, originally I thought the TS would be better, but apparently the VS would be most effective.
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 12-17-2013, 02:20 PM   #106
Frostyman
Drives: 2013 Raven FRS
That's what I have been led to believe as well.
Originally Posted by Don@Accelerated
For the sake of argument I went and cut my factory filter housing up.
Frostyman is offline   Reply With Quote
Old 12-17-2013, 02:36 PM   #107
mike the snake
The VS hood has a proper "trip lip" in front of the vent to cause more suction, and the vent itself is located in front, right over the turbo (on the FB kit), so air should flow up and across the turbo and out=ideal.
There was one or two other hoods that looked like they'd be pretty functional as well.
Old 12-17-2013, 02:41 PM   #108
Brody602
Drift King
Brody602's Avatar
Which other hoods are those?
Old 12-17-2013, 02:53 PM   #109
mike the snake
This one http://www.corsportusa.com/store/cat...ducts_id=28960
and this one http://www.corsportusa.com/store/cat...ducts_id=28970
The Following User Says Thank You to mike the snake For This Useful Post:
Brody602 (12-17-2013)
Old 12-18-2013, 11:01 AM   #110
canu_50
canu_50's Avatar
Drives: Scion fr-s
Nobody talked about Davies craig electri water pump conversion.. Or at least Evan's cooling coolant.
Davies Craig water pump: http://www.daviescraig.com.au/Electr...s-content.aspx
Evan's cooling solution:http://www.evanscooling.com/
canu_50 is offline   Reply With Quote
Old 12-18-2013, 12:35 PM   #111
mike the snake
OK, which do you think would be best between these two?
http://www.modbargains.com/seibon-ca...od-frs-brz.htm
Old 12-19-2013, 11:28 AM   #112
FullBlown
FullBlown's Avatar
Drives: Scion FRS
The shrouds are done. There will be an option for SPAL 12" fans as well.
FullBlown is offline   Reply With Quote
The Following 8 Users Say Thank You to FullBlown For This Useful Post:
Brody602 (12-19-2013), Dipstik-sportech (12-19-2013), mack4477 (12-19-2013), OICU812 (12-19-2013), OjiGeorge (02-17-2014), pmccut (12-19-2013), Sportsguy83 (12-19-2013), TRD_07 (12-19-2013)
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 03:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 10:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 01:18 AM
