08-26-2016, 06:16 AM | #113 |
Drives: BRZ Cosworth SC MY16
My favorite YT channel. Thinking about oem+ audio plus now. I will be replacing my fujitsu ten head unit with a navi system next week.
The Following User Says Thank You to Seba For This Useful Post: | oemaudioplus (08-29-2016) |
08-26-2016, 08:42 AM | #114 |
Drives: 2014 WRB BRZ Limited 6MT
Would this work with an aftermarket headunit?
I couldn't stand the lag of the stock touchscreen in my BRZ. |
08-26-2016, 08:51 AM | #115 | |
Drives: http://bit.ly/Vantage86
Yes @iggy Completely compatible with your factory or aftermarket head unit (both in terms of installation and sound reproduction). We tune each of our sound solutions specifically to the output characteristics of your current head unit, so you experience our signature sound reproduction the moment you plug your O+ system in. Wanting to upgrade your system prior to changing out your head unit? Not a problem! We have several owners who change out their head units (a few times) over the course of owning the system. It just a matter of having their O+ Digital Signal Processor retuned to maintain our signature sound. |
08-26-2016, 02:49 PM | #117 | |
The Following User Says Thank You to iggy For This Useful Post: | oemaudioplus (08-26-2016) |
08-28-2016, 10:11 AM | #119 | |
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
The door speakers in the "system" do more work than in the reference and it can pull the sound stage down and to the left with deep-voice vocals. (Chris Jones, long after you're gone) With the reference setup, the dash speakers seem to handle a larger portion of the sound and bring the sound stage back up and do a better job of centering the (low-voice) image in front of me. The speakers in the reference system also do a better job with delicate details that is hard to describe, but one of the more noticable instances is the harmonizing chorus in "on this train". On my sytem setup it sounds good, but on my wife's reference setup I can follow Zac Brown through the chourus. (I can pick his voice out more clearly) |
The Following User Says Thank You to Twinz For This Useful Post: | oemaudioplus (08-29-2016) |
09-16-2016, 08:04 PM | #120 |
Drives: Scion FRS
so I was one of the original owners of the system 450Q back in 2013 and it was pretty good using the stock radio.. I finally now decided to finally do the upgrade to the reference 450Q and I have to say I am blown away of the sound that the system is producing it is so clear I sat in my car for over an hour just listening to all types of music WOW if you are still on the fence don't be. the customer support that I received from Daniel was incredible WOW thank you so much for making music sound the way it should LOVE YOU GUYS>>>> Tommie from NJ>>
The Following User Says Thank You to gothdaze86 For This Useful Post: | oemaudioplus (09-16-2016) |
09-22-2016, 02:38 PM | #121 |
09-23-2016, 03:51 PM | #122 |
Boost Creep
Drives: 2016 HyperBlue BRZ
Does your system work with Joying Android head units, and if I want to change head units later, how does that process go?
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
The Following User Says Thank You to Luftwaffel For This Useful Post: | oemaudioplus (09-23-2016) |
09-23-2016, 04:17 PM | #123 |
@Luftwaffel thanks for your questions. Yes! Our team has had extensive R&D time with the JOYING head unit and are just finalizing the EQ.
The Reference 450Q is completely compatible with the JOYING head unit both in terms of connectivity (completely plug and play with your factory connectors and applicable receiver adapter) and above all sound (our signature sound reproduction the moment plug you your system in). If you decide to upgrade down the road, no problem. We'll just want to retune your O+ amplifier so your system maintains our signature sound reproduction with your new head units output characteristics. This is a service we offer gratis, we just ask you cover the cost of shipping if applicable. |
09-23-2016, 04:51 PM | #124 | |
Boost Creep
09-23-2016, 06:23 PM | #125 | |
Keep the questions coming. |
The Following User Says Thank You to oemaudioplus For This Useful Post: | Luftwaffel (09-24-2016) |
09-27-2016, 02:54 PM | #126 |
Drives: 2016 FR-S
What exactly is the "NEW 3-Way O+ Signature sound"? I've seen it mentioned repeatedly with no explanation of what it actually is.
Tags |
amp, audio, music, radio, subwoofer |
Similar Threads | ||||
Audio Equipment Part out! AVH-x4500bt, illusion audio, OEM amp, arc audio and more!!! | CamryDS | Audio/Visual, Electronics, Infotainment, NAV | 25 | 10-23-2015 09:10 AM |
Incriminator Audio 6.4, Sundown Audio SAX-100.4, US Amps Xterminator XT800.2 | slicktop | Miscellaneous | 1 | 07-11-2014 08:58 AM |
WTB: berk dual delete/perrin exhaust. JDL El headers. BBK kit. OEM Audio+/JL Audio | YEAHdams | Want-To-Buy Requests | 0 | 07-01-2014 11:37 AM |
FR-S Audio Build - SQ (Illusion Audio/Mosconi) | DekaMori | Electronics | Audio | NAV | Infotainment | 28 | 04-17-2013 04:34 AM |
'Noobish' questions as I look to upgrade my car audio audio. | DkY in Vcr | Electronics | Audio | NAV | Infotainment | 0 | 09-22-2012 09:45 PM |
