09-04-2014, 10:41 AM | #351 | |
Drives: 2013 Ultramarine FR-S
With that being said. Anyone else have a terrible time getting the bolt treaded? It would get maybe a thread in, then bind. It went in no problem with it out of the car, just as soon as I installed the adapter, the bolt felt like it wouldn't line up correctly. Even after I got it threaded (45 minutes -1 hour fighting it). The shift linkage end wouldn't fit in the bottom of the adapter, because it was hitting the bolt head. I had to back the bolt out(just enough to create some slack to move things around), slip the linkage in, and then torque the bolt down. This seems to have made 4th a bit mushy to get in, but I don't really know what it should feel like in the first place. The feeling could be caused by something else altogether. Every other gear feels just as described in this thread, bit more force to get it in, and super short throw. So I am very happy. I should also note that I took the clutch helper spring out at the same time. Both of these mods are near perfect. Now I just need to find a way to take up the slack in the clutch pedal..
The Following User Says Thank You to DustinS For This Useful Post: | JohnJuan (09-04-2014) |
09-04-2014, 09:26 PM | #352 | |
Drives: 2013 fr-s
You're probably right. I'm sure Toyota/TRD put very little time into r&d this thing and they have very little history with this stuff. Please read with sarcasm.
09-04-2014, 09:32 PM | #353 |
Drives: 2014 BRZ MT (Sold); 2006 V70R
And that's why they have two different kits, one from JP and this US one. And also why Sti doesn't offer one in the USDM, but has one in the JDM market which is like the JDM TRD kit.
I'm sure this one will work fine. It's just not the best implementation imo.
'14 BRZ LTD MT DGM
09-09-2014, 09:49 AM | #354 |
After Installing the Whiteline Positive shift kit(and rear subframe inserts), The shifting is crazy tight and precise. There is no slack. It is quite a bit tougher to get into gear, but I do imagine that things will loosen up a bit(hopefully not much). I can't imagine what moving to a stock car would feel like. It really is a must install.
09-16-2014, 07:17 PM | #355 |
Drives:
Can't wait to install mine!
Sent from my KFTHWI using Tapatalk |
09-29-2014, 11:04 AM | #356 |
Drives: 2013 Scion FR-S Firestorm Red
Posted this is the trd quickshift discussion thread, but wanted to put this here in case someone knows but isn't in that thread.
Installed yesterday and while the throw is shorter, it takes a lot of effort to get the car in gear. Thought the moving joints needed grease, but even after grease its still really hard to shift. This goes beyond any "cold start wait till it warms up" shifting problems. I took the pieces apart again and made sure everything was lined up correctly, but still have a very hard time shifting. Any ideas? |
09-29-2014, 11:18 AM | #357 | |
'14 BRZ LTD MT DGM
10-18-2014, 09:05 PM | #358 |
Drives: FRS monogram
So i just installed my kartboy shortshifter, my buddy was sitting here with me watching me do the install and then it clicks, as he has the trd quick shifter and knowing how much of a bitch it was to install from under the car as per toyotas crappy instructions. Well im here to tell you all, that its wrong, very very wrong! Do it from the top as per a kartboy install. We had to retighten his as he was a dumb dumb and did not use locktight. Doing it this way you can properlly tighten the 'extension'
As i have read that one of the biggest problems of this kit is the shifter play.. well doing it this way there is almost zero. Like literally next to nothing. If i didnt just take mine out i would have compared them but i would have to say its atleast as good or actually LESS play then stock. You can not do the entire install from the top because you still need to replace the bushing But i highly recommend everyone get at it this way and retighten and you should notice a difference. Will be different for everyone but none the less a difference @KonTheory |
The Following User Says Thank You to Top-Secret For This Useful Post: | ISDriven (12-04-2014) |
10-18-2014, 09:33 PM | #359 |
Also, removing the dustboot is sooo much easier, instead of a 90% ripping it you have a 90% chance npt wrecking it
10-24-2014, 03:08 PM | #360 |
Drives: 2013 FRS
Chiming in after having installed the kit a week ago, much like the rest of the people here I am a boot-ripper. The rest of the install went fairly well, though I did put the bolt into the adapter the wrong way. Overall driving impressions are great, throws are short but do require a bit more effort to get into gear. Didn't have any issues with cold-starts until this morning, I found it surprisingly hard to get it into 1st, but this hasn't been an issue any other day. Overall great purchase, easy install, recommend.
10-28-2014, 11:05 AM | #361 |
Drives: VW MK6 GTI | 13 Mustang GT
I bought one of these TRD quick shift kits off eBay today. I am going to combine it with my weighted Raceseng Topologi knob and see how it does during my daily drive and upcoming time attack in November.
SOLD FR-S Build | MK6 GTI Build | I might be getting another FR-S
10-28-2014, 11:28 AM | #362 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Its pretty sweet, no complaints here
12-19-2014, 10:28 AM | #363 |
Sweeper
Since this seems like the unofficial TRD Quickshifter mega thread, I want to share a problem I have discovered that may relate to using this in conjunction with the Perrin rear shifter stay bushing. The following is what happens when one installs the shifter rod parts of the kit and the Perrin rear shifter bushing.
Issue: The shift linkage arm, which has been dropped by the Quickshifter, comes in contact with the driveline knuckle in 4th and 2nd gear- a very audible rumbling with significant feedback through the lever like you forgot a bolt and the whole thing is loose and rumbling around. When I took the car around the block after install, it was a constant rattle whenever I shifted into 2nd or 4th (primarily 4th, 2nd was intermittent). All others were fine. After 10 or so minutes driving in the other gears (to try and see if the rattle was temporary as the quickshifter settles in), the problem indeed got better and I could shift and cruise into 4th with no driveline contact 90% of the time. There are times the linkage arm will come in contact with the driveline, exacerbated by medium-large bumps or if I shift and then continue pulling 'down' on the shifter after 4th is engaged. 2nd gear causes rubbing/collision when cold but not at temp.. interesting.. Here's some pics taken with a potato that probably won't convey the point: TRD Quickshifter and Perrin installed, to confirm I'm not pulling your leg Ultra-detailed high fidelity breakdown of the issue area You can barely make out the place where the linkage rod and knuckle of the driveline were rubbing. In person you can most definitely make out the place where they rubbed- bare steel on the rod and little knick of paint off the tip curls of each knuckle Conclusion: Swapping out the perrin for the kit mount and bushing eliminated the shifter linkage/driveline collision. Shifting is crisp, smooth, rub free and QUICK. ( describes my sex life with the fiancée lately ) 5th and 6th feel stock throw surprisingly, but 1st through 4th... goooood lord what a difference. Even helped out with 1st-2nd upshifts and 2nd being a bitch when cold. Clocked around 50 miles on the shifter post install where I tried hard braking in every gear- acceleration, slamming the bugger in there etc. No rubbing at all -- Fully recommend this piece. Confirms what most others who installed it correctly (everyone but myself and @stockysnail apparently haha) have to say about it. Very smooth, OEM feel. Short shifts, smooth and buttery gates.. more force needed, but not excessive. Mods to clutch system for reference: - 3/4 swapped Slave Cylinder - Whiteline transmission insert - Mtec springs - Motul 300 Will update after a couple thousand miles seat time with it Last edited by Koa; 12-20-2014 at 01:27 PM. |
The Following 2 Users Say Thank You to Koa For This Useful Post: | GT86_PRAGUE (12-19-2014), JohnJuan (12-19-2014) |
12-19-2014, 10:57 AM | #364 | |
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes |
Similar Threads | ||||
TRD Quickshifter | lovebeingbleu98 | Brakes, Suspension, Chassis | 3 | 02-13-2014 12:14 AM |
Amazing Wax | geb2391 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 27 | 04-12-2013 04:42 PM |
The most amazing thing I've done with my BRZ so far | azngolfur | BRZ Photos, Videos, Wallpapers, Gallery Forum | 8 | 01-09-2013 08:23 PM |
Concept-Three-LED's DRL's are AMAZING! | soros151 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 11-09-2012 01:42 AM |
