Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
03-21-2019, 12:49 PM | #15 | |
03-21-2019, 04:30 PM | #16 |
In the US, the Ts springs are black.
But I have a sneaking suspicion that they are pink overseas. Also people should never order directly from parts.subaru.com. Always google the part number and you will find distributors up to 40% below msrp. Subarupartsdepot.com, subaruparts.com are examples. |
The Following User Says Thank You to norcalpb For This Useful Post: | KoreanJesus (04-11-2019) |
03-21-2019, 05:26 PM | #17 | |
Drives: BRZ 2018
Anyway a friend sent me a chassis number and confirmed what part.subaru.com mentions, of course I am not going to buy them directly from them, they are recently available in Europe where I buy at wholesale prices. Thanks all for your answers, the correct part numbers in case someone is interested: Front shock left (Sachs) 20310CA250 Front shock right (Sachs) 20310CA240 Rear struts (Sachs) 20365CA220 Coil springs front 20330CA260 Coil springs rear 20380CA270 |
03-21-2019, 06:06 PM | #18 | |
03-21-2019, 07:08 PM | #19 | |
Drives: 2018 BRZ tS
Also, while snapping the pic, I can confirm the front left shock is: 20310CA250 |
The Following 2 Users Say Thank You to J1Avs For This Useful Post: | KoreanJesus (04-11-2019), norcalpb (03-21-2019) |
03-21-2019, 07:26 PM | #20 | |
Now for my next question, are these the same springs as B2010CA000 which is sold as a set of 4? These are the ones that lower the car “10mm”. https://www.subarupartspros.com/sku-...SABEgLBjfD_BwE I never noticed a ride height difference between the PP package BRZ and the Ts, but that could be because it’s literally only 10mm. |
03-21-2019, 07:58 PM | #21 |
Drives: 2018 BRZ tS
That I’m not sure of.
But the tS comes with 18x7.5in wheels wrapped in 215/40/18/ while the PP comes with 17x7.5 in 215/45/17. That might be enough to screen with the eyes a bit. You would think they would be exclusive, but then they would have likely been something called out as exclusive to the tS like the flexible v-bars and draw stiffeners |
03-22-2019, 03:09 AM | #22 | |
Drives: BRZ 2018
That was also my question but US tS springs are harder 15% front 8% rear compared with basic model while B2010CA000 are only about 8% front (I don't know by how much rear), tS are two different part numbers for front and rear while the above pinks are one for the set. Plus the tS have the classic color dots that Subaru - depending of hardness - marks it's springs with, while the US pinks haven't. Only if/when I order them I can tell you for sure! |
03-22-2019, 05:55 AM | #23 |
Drives: BRZ 2018
Just found a video that confirms tS has pink springs with dots that look different from the B2010CA000:
03-22-2019, 09:27 AM | #24 | |
Thank YOU.
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | KoreanJesus (04-11-2019), norcalpb (03-22-2019) |
03-29-2019, 04:13 AM | #25 |
Drives: BRZ 2018
And just found the JDM >MY17 BRZ tS springs/shocks part numbers, does anybody know the differences on springs from the US ones?
20310CA240 (shock absorber front RH) 20310CA250 (shock absorber front LH) 20330CA260 x2 (coil spring front) 20365CA220 x2 (shock absorber rear) 20380CA260 x2 (coil spring rear) |
03-29-2019, 07:42 AM | #26 |
Drives: 06 Evo GSR SE, 17 Series Yellow BRZ
Hks g-series
https://www.kamispeed.com/products/h...-86-subaru-brz Showa Tuning Evolution https://frsport.com/showa-tuning-v04...8aAklSEALw_wcB Bilstein B6, Bilstein B8, Bilstein JDM STI BRZ Stuts (the silver ones) JDM STI BRZ Pink Spings All the above seems like it would be easier more cut and dry as to what the final product your purchasing actually is. Also if you need a Ts vin number just look them up on used car sites like autotrader, car guru or true car. Every dealership lists a used cars vin number. Contact a dealership for parts with whatever vin number you find. Lastly I think the US frs/86 trd springs which are made by eibach which is in Southern California would technically fall under the designation of a “USDM” Part Or Spec lol. So I believe there is a novel asterisk to place in your “USImport” argument señor Tcoat. |
05-16-2019, 12:01 PM | #27 |
Drives: 2018 BRZ TS
So is my set of 4 tS shocks and springs worth selling? 400 miles on them.
2018 BRZ tS #282 of 500 DELICIOUS TUNING Edelbrock FI, E-85 Flexfuel, DeatschWerks pump and injectors, SpeedFactory ceramic UEL, Invidia R400 cat-back, ACT HD street clutch and flywheel, TEIN Flex Z coilovers, Stance wheels, Michelin Pilot Sport 4
05-16-2019, 12:17 PM | #28 |
Drives: 2015 BRZ
Similar Threads | ||||
'13 BRZ USDM vs EU Spec | leevanf | BRZ First-Gen (2012+) -- General Topics | 27 | 07-07-2017 04:09 PM |
FS-USDM Red TOMS | Cards2323 | Exterior Parts (Aero, Lighting, Etc.) | 9 | 10-26-2015 02:54 PM |
FT: JDM Clear Tom's to JDM or USDM Red Tom's | Kit523 | Canada Classifieds | 3 | 09-23-2015 08:56 PM |
WTT usdm tails | *KID* | ASIA | 0 | 01-16-2013 10:48 AM |
