Old 07-19-2019, 08:18 AM   #1
Crystalwhitebrzsti
Drives: Crystal white brz
How to wire zeitronix?
I’ve looked around a bit, but don’t fully understand where the zeitronix unit or what gets wired into the ecu. If anyone could help me better understand I would greatly appreciate the help. My understanding this far is that the wiring loom is fed through the firewall. Once that is done I don’t fully understand the reason for the canbus. It looks like from the wiring loom you can wire directly into the ecu and then just tap into power from the fuse box and ground? Is this wrong please help!
Crystalwhitebrzsti is offline   Reply With Quote
Zeitronix fittings? Tal DIY (Do-It-Yourself) Guides 2 07-17-2019 08:51 PM
handbrake wire and reverse wire location Australia gt86 rsingh Electronics | Audio | NAV | Infotainment 0 01-16-2017 09:12 PM
Zeitronix ECA errors SillySaxon Engine, Exhaust, Transmission 37 02-29-2016 10:57 AM
Help me identify this wire! Extra wire around battery after clutch job YouShallKnow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 12-09-2014 02:04 PM
Reverse Wire Tap wire Location? Norkoastal Electronics | Audio | NAV | Infotainment 2 10-19-2012 10:22 AM
