03-05-2014, 12:40 PM | #85 |
Drives: Scion FR-S
Is the factory header design the reason for needing the quick shift in cam phasing and overlap? Someone earlier mentioned after getting a header and tune they don't have the rasp. So do most tunes for cars with headers not have the rapid cam phasing change and overlap?
Sent from my XT1060 using Tapatalk |
03-05-2014, 12:41 PM | #86 | |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
03-05-2014, 12:59 PM | #87 | |
03-05-2014, 01:01 PM | #88 | |
Drives: 2013 FRS
Regards Shiv |
The Following User Says Thank You to Shiv@Openflash For This Useful Post: | DAEMANO (03-05-2014) |
03-05-2014, 01:11 PM | #89 |
Drives: Scion FR-S
03-05-2014, 01:17 PM | #90 |
Drives: 2013 FRS
03-05-2014, 01:21 PM | #91 | |
Drives: Hydra EMS Powered FRS Raven Black
Also you can try lowering the "DI Pressure Target." This will not run the pump as hard which can help. |
03-05-2014, 01:22 PM | #92 |
Trust me, I'm the Doctor
Except the torque dip has been eliminated through tuning + aftermarket exhaust. No trouble.
So, I wouldn't put it all on the di pump design & calibration. On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
03-05-2014, 01:33 PM | #93 | ||
What units is the OEM ecu logging for DI pressure? Quote:
By no means is this a gloom and doom scenario but it will answer why some people have no idea why one member say's his engine is making a different noise than others. One noise normal and one noise bad. Thanks, Phil Grabow |
03-05-2014, 01:39 PM | #94 |
True. I am hearing noise, but it doesn't sound too serious. Just a different sound is all. Next time I have my tuner in the car with me, I'll draw his attention to it to just make sure it's not the bad noise, just the "that's normal but noisy" noise.
I do want to see if deleting the stock header cat and then tuning for that would help as well, as that cat presents a significant air restriction.
The Following User Says Thank You to SirBrass For This Useful Post: | DAEMANO (03-05-2014) |
03-05-2014, 01:41 PM | #95 | |
Drives: 2013 FRS
03-05-2014, 02:00 PM | #96 | |
Drives: Scion FR-S
03-05-2014, 02:09 PM | #97 | |
The Following User Says Thank You to Element Tuning For This Useful Post: | DAEMANO (03-05-2014) |
03-05-2014, 03:02 PM | #98 | |
Drives: 2013 FRS
Hi Phil, That drop you are seeing occurs as engine goes from deccel (no fuel, injectors shut off) to accel (injectors on). You can see this by looking at AFR and DI on-time. That is what causes the short term fuel pressure drop. And that is present in the stock tune and to be expected. There is no discernible fuel pressure drop that occurs during the VVT intake swing which occurs a moment later. This point is driven home in the last few WOT runs which add 5psi of boost to the equation. -Shiv |
Similar Threads | ||||
Variable Valve "Butterfly" Exhaust | dlux | Southern California | 19 | 02-22-2016 06:21 PM |
First tank OFT E85 tuning. Noise? | Tromatic | Software Tuning | 2 | 02-20-2014 05:43 PM |
Exhaust Cut Off Valve | beagoodruslan | Engine, Exhaust, Transmission | 2 | 01-01-2014 01:47 AM |
Exhaust Noise that goes away after warmed up | FastLane1000 | Engine, Exhaust, Transmission | 10 | 08-15-2013 10:06 PM |
Knock/valve slap/crick noise under accel | yomny | Issues | Warranty | Recalls / TSB | 47 | 01-07-2013 08:53 PM |
