Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
12-01-2017, 12:08 AM | #1 |
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
Performance Pack Brembos and Stainless Steel Lines
Hey guys,
Quick question that I couldn't find an answer to from searching: Will the Stoptech stainless steel lines available at ft86sf fit with the Brembo brake calipers on the Performance Package BRZ? I'm not sure if the fittings for the lines have changed.
12-01-2017, 03:12 AM | #2 |
Drives: Subaru BRZ
Should be the same fittings. I would go with Speigler brake lines though.
12-01-2017, 02:46 PM | #3 |
Why is that? I don't know too much about the differences between brake lines
12-01-2017, 03:34 PM | #4 |
The Fail Boat
Drives: CWP S.B.
Extra twist on the brake line = higher chance premature failure especially if you daily it.
Speigler you can adjust and get the twist out + lifetime warranty. If you don't really daily it ya go ahead. |
The Following User Says Thank You to chaoskaze For This Useful Post: | Code Monkey (12-01-2017) |
12-04-2017, 02:48 AM | #5 |
12-04-2017, 02:41 PM | #6 | |
Drives: Subaru BRZ / Toyota 86 Experts
Brake lines are wear items and consumables. They should be changed regularly if you track often. OEM lines are already braided from the factory. |
12-04-2017, 02:48 PM | #7 |
Drives: Car
At what interval would you recommend to replace them for a car that tracks 1-2x a month? There isn't a way to check the lines AFAIK. Once a year? Every couple of years?
12-04-2017, 02:55 PM | #8 |
Always do a brake system check before your trackdays no matter how veteran you are. We've been in the track community long enough to hear about rupturing brake lines even with "upgraded" units but were long overdue for replacement. Intervals are not systematic, but one should check for any sort of wear issues. With consistent tracking, sometimes as much as once a year is required. We always recommend getting the best you can get and have significant experience in products we can relay to the community.
The Following 4 Users Say Thank You to CounterSpace Garage For This Useful Post: |
12-04-2017, 03:19 PM | #9 |
IMO, unless you know exactly why you want the stainless lines just stick with OEM.
The Following 3 Users Say Thank You to wparsons For This Useful Post: |
12-04-2017, 05:40 PM | #10 |
A while back I ruptured a SS line on my MINI headed into a highway off ramp carrying some decent speed. Kept it on the road and it was all good in the end, but it was unpleasant.
Inspect your brake lines often, even if you don't track the car. I made a mistake...a very large pothole (bent a wheel) had shifted the line just a bit and it was rubbing on the wheel. I should have had a look immediately instead of waiting a few days. I don't think it would have happened with an OEM line. If I had to choose an SS line, I'd go with Spiegler. - Andrew Last edited by Racecomp Engineering; 12-04-2017 at 05:51 PM. |
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post: | CounterSpace Garage (12-13-2017), Tristor (09-03-2019), wparsons (12-05-2017), x808drifter (12-04-2017) |
12-04-2017, 06:49 PM | #11 |
I see it recommended for tracked cars, since I'm flushing the system next week and replacing the fluid I thought I might as well swap the lines too since they aren't too expensive.
12-04-2017, 07:12 PM | #12 | |
I have found that sometimes, you create more problems by changing something, that doesn't need changing, than just leaving it alone ...... humfrz |
The Following 2 Users Say Thank You to humfrz For This Useful Post: | strat61caster (12-04-2017), Tristor (09-03-2019) |
12-04-2017, 07:19 PM | #13 | |
The Following 2 Users Say Thank You to mjanmohammad For This Useful Post: | humfrz (12-04-2017), strat61caster (12-04-2017) |
12-04-2017, 07:36 PM | #14 | |
Keep good fluid in the lines and good pads on the calipers, way more important than your <1 year old brake lines. |
Similar Threads | ||||
Stoptech Stainless Steel lines review | PITTFRS | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 04-21-2014 08:51 PM |
FS: Stainless steel clutch lines | Tengu | Transmission and Driveline | 0 | 12-15-2013 09:57 PM |
[SYD] HEL Stainless Steel Braided lines (F&R) BRAND NEW | eckoflyte | Australia Classifieds | 5 | 02-05-2013 08:33 PM |
Goodridge Stainless Steel Brake Lines | LavosTRD | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 10-29-2012 06:37 PM |
Stainless steel brake lines | taosracer | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 09-20-2012 04:09 AM |
