04-23-2018, 01:25 PM | #141 | |
04-23-2018, 01:43 PM | #142 | |
Drives: 2018 BRZ Limited, 2017 Sportage
04-23-2018, 01:51 PM | #143 | |
The platform is not restricted to AWD it isn't even restricted to gas powered engines. It is designed to do everything they need it to do. If it can be used for a compact hatchback it can be used for a RWD coupe. How is this concept so hard for people to grasp? "Flexible — without all the flexing" "The Subaru Global Platform is so named because it can be adapted to the requirements for everything from a compact hatchback to a 7-seater SUV. This level of flexibility has many benefits to the Subaru customer and to the environment. Existing Subaru factories around the world can be quickly turned over to produce different models according to what types of vehicles customers want and need. In addition, this revolutionary design can be modified to accept a variety of powertrains; ranging from our current gasoline SUBARU BOXER engines to future alternate powertrains down the road. The result: a truly flexible and environmentally friendly way to meet the needs of drivers for years to come."
04-23-2018, 02:16 PM | #144 |
Drives: '15 BRZ RA
It is like trying to fit everything in a single bag. Some will have to remember how the BRZ platform evoluted from the Impreza platform and achieved a better weight distribution and lower cog, because it had a specialized engine and the advantage of not using an AWD drivetrain:
The Following 4 Users Say Thank You to nikitopo For This Useful Post: |
04-23-2018, 02:33 PM | #146 |
Drives: '15 BRZ RA
My point was that the BRZ doesn't fit very well with the global platform. It was more about specialization and not like taking an existing engine and changing a bit the design to be a coupe (i.e. just being shorter than the sedan wrx) and so on.
The Following User Says Thank You to nikitopo For This Useful Post: | rvoll (04-23-2018) |
04-23-2018, 02:40 PM | #148 | |
Yes that image is very deceiving since it supports the myth that a "platform" means a prefabbed base that everything just bolts on top of.
The Following User Says Thank You to Tcoat For This Useful Post: | NoHaveMSG (04-23-2018) |
04-23-2018, 02:46 PM | #149 | |
Drives: Crapcan
As long as the heritage of the car continues I will be happy. I don't foresee selling mine anyway even for a significantly updated version. |
04-23-2018, 02:55 PM | #150 | |
04-23-2018, 06:38 PM | #151 | |
That said, the BRZ is a joint project with Toyota and I doubt if Toyota would approve of the inherent weaknesses of the global platform for a sports car. The proportions of the global platform are all wrong for a car as low as the BRZ. If you don't have any engineering experience, have an engineer look at the picture and then tell me how they could possibly get a RWD only low car out of that platform. |
04-23-2018, 06:42 PM | #152 |
Looking at the picture of the "myth" that Subaru presents, they are talking primarily about a base that everything bolts onto. You're right, theoretically it could be a "myth", but in this case it is not. Now you will obviously have additional commonalities among the models, but Subaru has already confirmed their platform and showed pictures of it.
04-23-2018, 06:51 PM | #153 |
Drive From Home
Drives: BRZ STI Performance
Thanks to VW and the handful of car part suppliers now every car manufacturer's marketing dept will have to sell a "global platform" regardless of what it is in reality.
If Subaru goes it alone they should do a 3rd gen Alcyone instead of a BRZ successor. Last edited by krayzie; 04-23-2018 at 07:07 PM. |
04-23-2018, 07:11 PM | #154 | |
