RR Racing
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > FT86CLUB Shared Forum > Member's Car Journals
Old 11-08-2018, 09:48 PM   #57
Viper8
Drives: Scion FRS
Next up I scuffed the fender with some 220grit and cleaned it. Then some primer and paint.
Viper8 is offline   Reply With Quote
The Following User Says Thank You to Viper8 For This Useful Post:
eastendraceshop (11-09-2018)
Old 11-11-2018, 09:12 PM   #58
Viper8
Drives: Scion FRS
I ended up placing some black gorilla tape over the gap to minimize the amount of water draining through the fender during rain/car washes. As the tape was glossy, I also sprayed a coat of matte spray paint over it. I have some extra two sided tape from my spoiler install that I'll use to mount them. Just need to catch the other side up...
Old 11-18-2018, 12:26 AM   #59
Viper8
Drives: Scion FRS
And for the final product...
Old 11-18-2018, 12:41 AM   #60
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Interesting thing with the fender vent, in the future instead of JB Weld you could use Amazing GOOP (Also called Marine Goop or Shoreline Marine GOOP). I have used it on my boat when I owned one and on two different Kayaks, held up fine even when exposed to Florida sun 24/7. It's easier to work with than JB Weld.
Trueweltall is offline   Reply With Quote
Old 11-18-2018, 04:55 PM   #61
Viper8
Drives: Scion FRS
Thanks for the suggestion. I'll try it on my next project.
Old 11-21-2018, 12:00 AM   #62
Viper8
Drives: Scion FRS
Track day at Hallett! It was pretty chilly in the morning, and the track started out fairly slick. After my second run of the morning, I noticed a slight squeaking at front my front right wheel. I had checked my pads prior to ensure I had sufficient wear for one day at the track. I pulled off the front left wheel and upon further inspection, while there was some wear remaining on the outer pad, there was nothing left on the inner pad.
Unfortunately, I hadn't brought a spare set of pads with me, so I ended up running to a local O'Reilly's for a temporary replacement. Unfortunately, the replacement pads just weren't up to the task, experiencing some extreme fade, and nearly put me off the track twice. I decided to take it even easier after that due to lack of brake confidence. It was a bummer as I was hoping to establish some performance data on my most recent mods, but it will have to wait for next Spring now with my DBA Pads I haven't had a chance to use yet.
Still on my to do list:
Stainless steel brake lines
DIY brake vents
Crawford billet power blocks
Front camber bolts
Old 12-07-2018, 12:33 AM   #63
Viper8
Drives: Scion FRS
My OEM battery finally crumped out after struggling ever since I got back from being gone for the summer. I elected to go with the Odyssey PC680 due to it being lighter weight than OEM (~16lbs vs. ~30lbs) and well priced. I reused the stock tray and bracket, but made a base form to sit in the oem tray that would hold the new battery in place.
Old 01-28-2019, 11:33 PM   #64
Viper8
Drives: Scion FRS
I just got my car back from the dealership for the valve spring recall. They even touched up the under-hood coloring. I had asked them to replace the spark plugs during the recall work (as they said they'd only charge parts - $40 - since the engine would be out and apart anyway), however, they ended up not having any on hand and weren't willing to wait for me to pick some up. I'd recommend getting it done at the same time if you can, as it will save you either a fair amount of time, money, or both!
daily driver, frs, naturally aspirated, oklahoma, track build
Mr. Frs Trd track build Mr.Frs Member's Car Journals 24 06-20-2018 06:20 PM
dp1 track build (NY) dp1 NY / NJ / CT / PA 114 07-19-2017 01:47 PM
Chronolgy101's DD and Track Build Chronology Member's Car Journals 1 04-21-2017 12:21 PM
What's your Track Build? neroman98 Subaru BRZ General Forum 4 08-06-2015 04:16 PM
FRS Track Build smoltz Tracking / Autocross / HPDE / Drifting 27 07-08-2015 09:17 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
