Old 06-14-2019, 10:45 AM   #1177
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Ready to burn the car to the ground.
[ame="http://youtu.be/dC5Xa3RmmV4"]Latest Oil Change[/ame]
Also still have a drivetrain vibration at higher speeds that makes the shifter shake so bad the transmission feels like it's about to fall out.
DustinS is offline   Reply With Quote
Old 06-14-2019, 10:54 AM   #1178
fika84
fika84's Avatar
I'm really surprised you've been this patient! You've had that engine out more times than I would've had patience for!
Can't stop, won't stop! You gotta see this through! What the hell is failing internally now? Have you considered rebuilding the engine yourself from the crank up?
fika84 is offline   Reply With Quote
Old 06-14-2019, 11:41 AM   #1179
DustinS
DustinS's Avatar
I try my hardest to be patient.
I'm not quite sure what it is now, but oil pressure is still decent and hasn't changed, so not any bearings I don't think. I have plans / a build list to redo the engine completely. Don't really have the funds to jump head first though. Trying to see if I can recoup most of the cost by selling off all the stuff I won't use. Which is pretty much everything Texas Speed haha.
For grins I sent Texas Speed the pictures and they didn't like them either. I don't expect them to do anything as they barely did anything last time. Though not sure I want them to do anything besides possibly a refund at this point. Nothing but issues.
The Following User Says Thank You to DustinS For This Useful Post:
fika84 (06-14-2019)
Old 06-14-2019, 12:07 PM   #1180
jflogerzi
jflogerzi's Avatar
Damn man so sad.. at least the shell of the car is still good. I am assuming you have another car as a daily?
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
djliquidsteele (06-14-2019)
Old 06-14-2019, 12:11 PM   #1181
DustinS
DustinS's Avatar
This is technically my daily, but I do have other cars I could daily. I just really enjoy driving this car.
Old 06-14-2019, 12:12 PM   #1182
jflogerzi
jflogerzi's Avatar
I get you man. After putting in my supercharger and dip into boost hearing the SC whine makes me grin from ear to ear.
Old 06-15-2019, 10:14 AM   #1183
gtpvette
Drives: 2015 FRS - FFR GTM
Dam man,,, that sump plug has got a lot if stuff on it. I know you've had some metal in the oil in the past but I don't recall you posting a picture of the plug before,,, is this new?? Maybe stuff from the work you've just done???
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
Old 06-17-2019, 08:48 AM   #1184
DustinS
DustinS's Avatar
The new oil pan came with a magnetic drain plug, I never did switch out the stock GTO drain plug. So this is my first time having a magnetic plug.
The only thing that could possibly wear would be the oil pump, and I think it would be really bad if it was shedding that bad.
Old 06-17-2019, 09:16 AM   #1185
all4spl
I would assume that since emtron has a plug and play kit available, the ability to utilize the push start button should be available by now.
all4spl is offline   Reply With Quote
Old 06-17-2019, 09:26 AM   #1186
DustinS
DustinS's Avatar
I don't have push button start, so that doesn't effect me any. I am really looking at syvecs because I know for a fact they integrate with BMW DCT which I may go with down the road.
Old 06-17-2019, 09:50 AM   #1187
all4spl
LOL I'm not sure why this posted here. I posted this on the other thread about the 2jz and motec vs emtron.... weird.
The Following User Says Thank You to all4spl For This Useful Post:
DustinS (06-17-2019)
Old 06-17-2019, 03:06 PM   #1188
DustinS
DustinS's Avatar
Minor updates.
I am starting to think my driveshaft is too short, which has been causing my speed related vibration. Not super happy with the length I decided to go with anyway. So I might as well have that fixed while I am chasing an issue. I will measure pinion angle while I am doing that.
Texas Speed definitely thinks there is an issue. Which is good for confirmation, but not for wallet.
Old 06-17-2019, 04:07 PM   #1189
toast
Drives: 14 BSP Edelbrock BRZ
This is the company that built and then rebuilt it for you? They aren't going to fix it on their dime?
toast is offline   Reply With Quote
Old 06-17-2019, 04:20 PM   #1190
DustinS
DustinS's Avatar
Yes, and I haven't heard back on that just yet, but I am 99% sure they are only going to offer to fix it on my dime, or maybe a slight discount on getting it fixed?
At this point, I really just want a new engine or partial refund. This one obviously has issues, but I am not holding my breath. With as much money and time I have spent working on this engine, I don't feel it's worth continuing with TSP products. Especially with @ILLSMOQ having similar issues and finding the heads cracked with only 2500? miles on the car.
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) -- General Topics 13 03-22-2016 03:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-21-2015 11:38 PM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 11:14 AM
Should I swap? michaelahess BRZ First-Gen (2012+) -- General Topics 8 06-12-2012 07:32 PM
