03-23-2013, 09:03 AM | #29 | |
I Love custom Turbo kits
Drives: Limited BRZ
Shitty like: Me: "Hi, I hear you guys have a Mustang Dyno and I want to use it. I will bring my tuner down to tune it. How much do you charge to use it and when is it available?" A-hole: " Yes, we have a Mustang Dyno what car do you have?" Me: "I have a Subaru BRZ" A-hole: " Oh, we are not interested, we only do BMW's." Me: "Oh, but I am not asking for you guys to tune it, I'm just asking to use Dyno Time" A-hole: "No, we are not interested, we only do BMW's" Really.... WTF???? I'll pay your rate to use, just let me use it..... (True Story... sadly) Edit: BTW, it was this shop AVIOD them at all costs!! Active Autowerkes 9940 SW168th Terrace Miami, FL 33157 (305) 233-9300 Mustang Dyno MD-250
The Following 7 Users Say Thank You to Sportsguy83 For This Useful Post: | BRZranger (03-23-2013), DC2R (06-05-2014), eurominican (04-05-2013), ftc~brz (03-23-2013), killerkid08 (05-11-2013), lbroskee (03-23-2013), Pete (03-27-2013) |
03-23-2013, 09:35 AM | #30 |
GBS MAFIA, now sporting Turbo power!!
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
The Following 2 Users Say Thank You to Turbowned For This Useful Post: | Laika (04-14-2013), Sportsguy83 (03-23-2013) |
03-23-2013, 09:38 AM | #31 |
Ninja Moderator
Drives: 2013 Subaru BRZ
MMMM AVO! Nice build so far man. Will the AVO kit bolt right up to the Nameless OP/DP?
The Following User Says Thank You to MannyO For This Useful Post: | Sportsguy83 (04-05-2013) |
03-23-2013, 12:31 PM | #32 |
Glorious BRZ Master Race
Drives: Subaru Libird
I'm with you bud. I've had mine since launch and still feel childish excitement every time I take it out to drive. Comment from my neighbor when he saw me wrenching from underneath my jacked up car: "That car is so new and you're already ripping it apart!" They just don't understand.
The Following 3 Users Say Thank You to switchlanez For This Useful Post: |
03-23-2013, 01:08 PM | #33 |
Done
Drives: WRB BRZ
subscribed |
The Following User Says Thank You to ftc~brz For This Useful Post: | Sportsguy83 (03-23-2013) |
03-23-2013, 10:18 PM | #34 |
Drives: Limited BRZ
Yes, both were designed to bolt up to the stock location. Vubaru has it already. Some loosening up and adjustment needed to be made but that is to be expected because the AVO turbine comes pre-assembled.
The Following User Says Thank You to Sportsguy83 For This Useful Post: | MannyO (03-23-2013) |
03-23-2013, 10:23 PM | #35 |
Drives: Limited BRZ
Good amount of progress was made today. HUGE thanks to @jazztennor. He helped me knock out a lot of things today!!!
Two pics for turbo and bottom engine headerless: The install is not hard. It is time consuming, but you can follow instructions right along. Paul @AVOturboworld has been extremely helpful, even on a Saturday when he is off. I'm close to completing the install, now waiting for some more parts to arrive. I expect to finish the install next Friday. Thanks a lot for all the nice comments, it makes this thread very worthwhile!!
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post: |
03-23-2013, 10:26 PM | #36 | |
Drives: Attitude
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post: | Chewie4299 (04-11-2013), switchlanez (03-23-2013) |
03-24-2013, 11:19 AM | #37 |
Drives: 86 (FR-S)
Great progress man! Thank you for sharing. Very interested in how the plumbing is run (where oil and coolant are sourced/returned, etc). Subbed!
03-24-2013, 11:24 AM | #38 | |
Drives: Limited BRZ
The oil return to the oil pump in the back of the block, (it goes in place of that triangular plate that people have had leak oil because it came loose from factory). The oil feed is a block bolt plug located in the front part of the left side injectors. Edit: throttle water line:
03-24-2013, 11:31 AM | #39 |
Drives: Limited BRZ
@2forme, here is the plastic part that needs to be modified.
There are two plastic deflectors in the bumper. their function is to route air towards the radiator. The need to be modified to fit the IC inlet and outlet pipe. The are still left in place and still do their function. Here are mine with the pipes installed: There's two more things to be modified, but extremely simple stuff. The windshied water tank rests in a hole and that hole was made bigger to make it sit lower and be able to rout the IC piping on that side. Lastly, the bar that runs top to bottom middle of the radiator needs to have the bottom part flattened out. That's it. The rest is just installing parts.
The Following User Says Thank You to Sportsguy83 For This Useful Post: | raul (03-25-2013) |
03-24-2013, 01:37 PM | #40 |
Fiebru
Drives: Scion FR-S and Integra Type R
Looks great, thanks for sharing!
Current Cars:
2017 White Platinum Ford Fiesta ST 2013 Raven Scion FR-S 2012 Spruce Mica Toyota Tacoma TRD Off-Road 2000 Phoenix Yellow Acura Integra Type R |
The Following User Says Thank You to Draco_PR23 For This Useful Post: | Sportsguy83 (03-24-2013) |
03-24-2013, 08:07 PM | #41 |
That Guy
Drives: 2013 asphalt FRS MT
Hey man, would you mind taking and posting some pics of the IC mounting?
03-25-2013, 06:18 AM | #42 |
Drives: Limited BRZ
I'll do my best to remember. It bolts on to the back of the bumper beam.
The Following User Says Thank You to Sportsguy83 For This Useful Post: | Calum (03-25-2013) |
Similar Threads | ||||
Volk Racing TE37SL - Mag Blue/ Hyper Blue/ Flat Black/ Red/ Gold IN STOCK!!! | Speed Element | Wheels and Tires | 151 | 09-26-2013 04:56 PM |
Dream Mod For FR-S/BRZ | JPxM0Dz | Other Vehicles & General Automotive Discussions | 22 | 03-08-2013 10:35 PM |
Have You Had A Dream About Your Car? | chanomatik | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 01-29-2013 02:38 AM |
Sonic Blue 86, Galaxy Blue deleted? | 450hp/tonne | AUSTRALIA | 14 | 09-01-2012 07:10 PM |
I had a dream... | ashtray | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 03-12-2012 11:35 PM |
