Software Tuning Discuss all software tuning topics. |
07-19-2017, 08:27 PM | #15 |
Let the cars idle for a minute stationary
Check the afr and commanded afr both should be pretty close to 14.7 and fairly stable might go to 15 or 14.4 or so but outside that is unusual Check the long term fuel trims at idle should be less than 10% If you got unusual values check for intake or exhaust leaks dirty maf sensors clean connectors on maf and o2 sensors. You can try bumping idle to 750 and setting the overun fuel resume to 1400 from 1300 But fix hardware ussues first Seen couple if guys with bad front o2 sensors Bad rear 02 usyally only effect cruise fueling Last edited by steve99; 07-19-2017 at 08:38 PM. |
The Following User Says Thank You to steve99 For This Useful Post: | Detroiter (07-19-2017) |
07-19-2017, 09:41 PM | #16 |
TRACKBREAD
OFT - Control Minimum RPMs?
07-19-2017, 11:49 PM | #17 |
Seņor Member
I found on petrol the stg 2 OFT tunes to be really good at idle. I am now on e85 stg 2 OFT and the idle is not as consistent. Not terrible but will occasionally bounce around. I have a light flywheel so just figured the e85 tune wasn't as sorted.
1974 TA22 Celica
2013 86 GT |
07-20-2017, 08:50 AM | #18 |
BRZ Wannabee
Drives: 2013 Limited BRZ
Update, changing the PI/DI ratio tables didn't work for me. Might work for you guys with bigger injectors though, definitely worth a shot. It's only been one day but the car is relearning since I reflashed it and dipping as low as ever until it learns not to do that $hit... *sigh*
07-20-2017, 08:52 AM | #19 | |
BRZ Wannabee
07-20-2017, 10:11 AM | #20 | |
Same thing has been happening to me for months and months. I have a Tomei UEL and have tried several tunes, cleaned my MAF, air filter, bought new o2 sensors, injector orings replaced, new gaskets for my header and exhaust, yet this problem still persists.
I have noticed that when I have the A/C on, the problem becomes MUCH worse than when I turn the A/C completely off. Quote:
The Following User Says Thank You to paintdude258 For This Useful Post: | Detroiter (07-20-2017) |
07-20-2017, 03:07 PM | #21 |
Drives: UK GT86
It's not this. There are other settings other than the Target Idle RPM. Correct MAF settings help, it seems having slightly negative trims help. Try increasing the Idle Airflow and Load maps (if they are there).
.: Stealth 86 :.
07-20-2017, 07:54 PM | #22 |
Idle stability tables may help as well
07-20-2017, 07:57 PM | #23 |
Drives: UK GT86
This tends to be more when blipping the throttle or revs dropping and less so if the idle is unstable, unless the stability tables are jacked up and ends up in oscillation.
.: Stealth 86 :.
07-20-2017, 10:09 PM | #24 |
The Dictater
Drives: '13 Red Scion FRS
Is this only happening on aftermarket headers? Specifically UEL headers? I ask because if that's the case, then the folks with this problem might be running into a peculiarity with the idle control loop. Other than the Target Idle, are there other parameters we can adjust that have been defined? Haven't checked out the "idle stability tables" Steve mentioned, but those sound promising by title.
Maintaining a consistent idle might sound easy, but getting a machine to balance consistently is surprisingly complex. There are likely damping functions built in to the control loop to keep it from oscillating back and forth. Part of setting that up is adjusting for things like intake length, intake resonance, exhaust resistance, exhaust resonance, angular acceleration, etc. Making a change to ANY of these would mess with that control loop. If you change the header to a completely different design, you will have to adjust how the ECU maintains idle, or more likely than not deal with transient effects like this. |
07-20-2017, 11:39 PM | #25 |
07-20-2017, 11:48 PM | #26 | |
I have UEL header have my base idle at 650 modded idle stability tables full DI at idle no stalls coming to stop dips slightly on a/c cycling and on rear demister turn on but no stall or shaking just dips to say 550 then recovers |
07-21-2017, 01:08 AM | #27 | |
The Dictater
I was just attempting to point out that the shape of the header is a part of the idle control loop. Changing that is the same as messing with the ECU regarding idle stability. |
The Following User Says Thank You to Spuds For This Useful Post: | steve99 (07-21-2017) |
07-21-2017, 06:21 AM | #28 | |
TRACKBREAD
Can you elaborate on your idle stability tables? Sent from my iPhone using Tapatalk |
Tags |
jdl, oft, romraider, rpms, stage 2 |
Similar Threads | ||||
Minimum 51% Ethanol | smg1138 | Software Tuning | 13 | 03-15-2016 04:44 PM |
Minimum HPDE Brake Pad Thickness | DarkSunrise | Tracking / Autocross / HPDE / Drifting | 11 | 10-28-2014 10:26 PM |
Set a minimum post count to sell in Classified? | mav1178 | Site Announcements / Questions / Issues | 9 | 08-26-2013 07:25 PM |
The bare minimum? | Scaldy | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-11-2012 09:58 AM |
Minimum requirements... | Blokatos | Scion FR-S / Toyota 86 GT86 General Forum | 528 | 11-15-2011 04:04 PM |
