Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
02-23-2014, 12:38 PM | #29 | |
Drives: Silver Premium Edition BRZ
Question about spacers... when I owned an 88 and then a 93 RX7 I was always told using spacers to push out the wheels for a flush look put strain on the axles for which they weren't necessarily designed. Any concern there with modern cars? |
02-23-2014, 12:43 PM | #30 |
Man-ape
Drives: 2013 Buddy Club Scion FR-S
I've modded a lot and my first mod was tires and wheels this car needs it. Then it was cat back suspension and header then tune. It's all about what you want to accomplish with the car. Have a clear goal in mind before you stop and drop thousands upon thousands
02-23-2014, 01:37 PM | #31 | |
Trust me, I'm the Doctor
I'm on my phone so if I make mistakes, blame Sportsguy83
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
02-23-2014, 01:52 PM | #32 |
Drives: Subaru BRZ Limited WRB Manual
For suspension, I have the following:
-RCE Yellow springs -Koni Yellow shucks and strots -OEM crash bolts in the front -SPC adjustable rear lower control arms If you are going to get springs, I highly recommend getting OEM crash bolts and the SPC adjustable rear lower control arms plus a professional alignment. The SPC LCAs will allow you to keep your rear camber closer to zero (ideally around -1.5 if you get the RCE yellows) and your toe at zero. FWIW, you might want to check out the Swift springs if you value comfort and appearance over performance, but I love my RCE yellows. |
02-24-2014, 12:51 AM | #33 | ||
Drives: '13 BRZ Ltd WRB
If you're lowering the car and adding other mods, I would think the goal would have some performance in mind. That said, zero camber is fine for someone who hates going around corners. I would leave at least some negative camber, front and rear, regardless of suspension. Even on stock, the -1 degrees in front from bolts made a HUGE improvement when turning the wheel.
02-27-2014, 01:21 AM | #34 | |
Huh, I'll be damned. Thanks for the info! Still not sure I'll do it but it would look nicer.
