Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
10-30-2018, 11:25 AM | #1 |
Drives: 16' BRZ
Wheel and tire combo for 500 hp
I already have 2 sets of 17x9 wheels and I really don’t want to make the switch to 18’s. Does anyone make a good 17x10 so I can just buy 2 for the rear? I run nitto nt01’s 255’s right now. If I can’t find any 17x10’s would it be beneficial to put a 275 on a 9 inch wheel in the rear? This is for autoX and track use.
10-30-2018, 11:43 AM | #2 |
Drives: Track preped NA FRS
I do not think 275 in the rear will be a good thing. 255 is already a bit bulged and feels sloppy when compared to 235 and 245 in a 9". If you do find any decent (read light and strong but not costing and arm and a leg) 17x10 wheels I would be interested in buying those as well, so please do share.
10-30-2018, 12:01 PM | #3 |
Thanks
I opened this thread and read "Grab the ice cream truck wheel"
10-30-2018, 12:14 PM | #4 |
Rust bucket enthusiast
I'd also really consider changing your suspension setup based on what you're using this power for. You're going to want to be soft, and compliant in the rear.
For what it's worth, I've seen 17x10 RPF1's run on a Factory818 setup. Not sure if they make them in a 5x100 though...putting a 275 on a 9" wheel will bulge a little, this shouldn't hurt its performance. Just be sure you're not hellaflushdope1337CR3W |
10-30-2018, 12:20 PM | #5 |
We can have BRAID make some 5x100 17x10 wheels. Any offset. Let me know if you're interested.
- Andrew |
10-30-2018, 12:36 PM | #6 |
Drives: 16' BRZ
Hi Andrew, yes I'd be interested. Could I order just 2 or would I need to buy a set? I guess if I could pick the offset then it would be possible to make them fit in the front as well? I'm not looking to spend 3K plus on forged wheels just need something that's strong enough to handle some abuse!
10-30-2018, 12:40 PM | #7 | |
Very strong wheels and what I chose to run on my own car. - Andrew |
11-01-2018, 12:16 PM | #8 |
Drives: 1980 corvette, 2014 Subaru BRZ
I am guessing you want to run SM. Here is a very good build thread about someone doing the same thing
http://www.ft86club.com/forums/showthread.php?t=25212 towards the end he was running "I had 275/35R17 Hoosier A7s on 17x9et45 RPF1s." with some fender rolling and probably every other possible thing he could do?
Similar Threads | ||||
Help me identify tire/wheel combo | Last Lemming Alive | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-13-2017 08:08 AM |
Best Wheel/Tire Combo based on these choices? | leevanf | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-11-2017 08:00 PM |
Anybody taken their wheel/tire combo off their FR-S and... | cfordart | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 09-05-2013 01:47 PM |
Winter Wheel/Tire Combo... | Wes B. | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 09-10-2012 08:33 AM |
