04-12-2018, 10:21 AM | #71 | |
A.K.A. Starlord
Drives: 2015 Series.Blue
FWIW, I run 245s all-around for autocross. If I were to put 215s back on the front as you seem to suggest I should, I would get butt-raped in the butt with a lot of rape.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
04-12-2018, 11:00 AM | #72 | |
Only users lose drugs.
Drives: All the time
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
04-12-2018, 11:29 AM | #73 |
Rice King
Obviously no one knows what they are talking about here. You kids all need to start running 265/70/15 in the front and 185/35/18 in the rear for maximum grip and and acceleration.
:b arf::bar f:
Glorious Honda.
Know my 5x120 GREATNESS PEASANTS. |
The Following User Says Thank You to Jordanwolf For This Useful Post: | rvoll (04-13-2018) |
04-12-2018, 11:58 AM | #74 |
Drives: 2013 Scion FRS
I personally prefer running a staggered setup with 255/R18s on the driver side and 205/R17s on my passenger side. Since all the off-ramps in my city are right hooking, I get the immediate responsiveness of the passenger side narrower tires throwing me into the bend with the meaty driver side tires keeping me from spinning out. 10/10 wood recommend.
The Following 4 Users Say Thank You to Deorio For This Useful Post: |
04-12-2018, 12:06 PM | #75 |
LOL at the recommendation in another thread to run staggered 215/245 setup...can't make this shit up.
04-12-2018, 12:22 PM | #76 | |
Drives: Crapcan
......and no one like butt-rape so......... |
04-12-2018, 12:38 PM | #77 | |
Drives: '15 BRZ RA
04-12-2018, 12:56 PM | #78 |
A.K.A. Starlord
They absolutely heat up. On warmer days, you need to bring a water sprayer to keep your tires cool. It only takes one 45-60 second autocross run to bring them up to a good temperature. Even with 5-10 minutes between runs, your second run will be significantly grippier, and your third run will be even grippier. If you get shoehorned into a re-run in between, though, you can sometimes get buttfucked by an overheated tire if you don't get the 5 minutes between runs you are supposed to get.
The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post: | nikitopo (04-12-2018), strat61caster (04-13-2018) |
04-12-2018, 01:26 PM | #79 | |
Drives: Working on it
The Following 4 Users Say Thank You to Soonsoon For This Useful Post: |
04-12-2018, 02:04 PM | #80 |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
This thread is nuts and the comparisons brought up are horrible.
I run 17x9 with 255/40 because I think it looks good, protects me from NYC potholes, and saves my wheels from the occasional curb rub from a hasty parallel parking job. Never been on the track. We all have our own reasons, stop justifying to others or trying to convince others. Especially with such bad comparisons. |
04-12-2018, 02:37 PM | #81 |
Errr...how does that size protect against potholes? It's virtually the same sidewall as the stock 215/45...
04-12-2018, 02:50 PM | #82 |
StreetKart
Drives: 2014 Scion FR-S Monogram
if you're in a cold environment and cant get heat into your 205's sufficiently and the manufacturer says its safe on your wheel that would work. You'd drop weight and get into your operating temp range quicker.
There is no 100% right answer for all conditions. most people WAY over tire this car... I know mine is but dammit it looks cool lol
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
The Following 2 Users Say Thank You to Roadcone For This Useful Post: | new2subaru (04-12-2018), why? (04-13-2018) |
04-12-2018, 02:52 PM | #83 |
Loading...████████] 99%
Drives: #0517
for this particular wheel size, the 255/40 is a little more meat on the 9" wheel
R1 3 5
╘┼┼┤ . 2 4 6 |
04-12-2018, 03:35 PM | #84 | |
Drives: '15 BRZ RA
Your own reasons using large wheels/tires are not relevant with performance. Why do you need to get bothered with this discussion? |
Similar Threads | ||||
What am I missing with all the ultra-wide wheels & tires? | Vdub | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 53 | 07-14-2017 08:08 AM |
What are some good slippery narrow tires? | PowderfaceTr. | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 38 | 02-07-2015 12:14 AM |
Tires that run wide or narrow | switchlanez | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 12-08-2013 03:55 PM |
I have a 18x7.5+38 wheels..How wide can i go with tires | Bmore_Raven86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 07-23-2013 12:04 PM |
235 mm tires, great fit but not too wide | Black Tire | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 02-07-2013 08:38 AM |
