03-15-2023, 01:53 AM | #183 |
I have to check the CalID, I'll let you know.
BTW, please let me know how to update the ABS module with Techstream, I didn't succeed. I already had normal Brembo definition before, I have PP. |
The Following User Says Thank You to gpvecchi For This Useful Post: | Trap63 (03-15-2023) |
03-15-2023, 08:36 AM | #184 |
Drives: Brz WRB - Europe LHD
How are you able to receive CAL ID files? with TIS regular h/m registration/payment?
03-15-2023, 08:47 PM | #185 |
Drives: None
I pulled the calibration ID on a few I had here, they all kinda match the unit that they came off of, just with a different leading part number.
IE: 27536CA050 => 27522CA050 27536CA070 => 27522CA070 Ignore all of the errors, car is K24 on Haltech. I also checked the units from two of my friend's GRs - one base, one premium and same numbers It is a mystery, definitely not like MK60 stuff where you can adjust chassis / slip parameters with INPA.
03-16-2023, 02:38 PM | #186 |
Drives: MR2, Sliver BRZ
The GR and modules are much more different than gen1. The canbus networks are completely different and the internal program is too. The subroutines in code are slightly different. So they won't drop in without major rewriting firmwares on it. At the point Pedal dance does the same thing.
Always looking to tinker with something..
03-16-2023, 02:45 PM | #187 | |
Drives: None
03-16-2023, 04:12 PM | #188 |
The latest Cal ID for JDM Racing models is 27522CA840.
I'm interested in how to flash it using Techstream |
03-18-2023, 07:51 AM | #189 |
Drives: 86 GT
I wonder why the calibration is etched onto the body of the VSC module, does that imply that it is not rewritable?
DIY stuff at Compelica Works
03-18-2023, 01:59 PM | #190 |
Probably for identification. It seems that both Techstream and SSM4 can write calibrations, but I don't know how to do...
12-28-2023, 06:35 PM | #191 |
Drives: Toyota GT86
I found a unit 27536CA030 But it has a date of 2016 (16-06-24).
the crashed car has the track button and other aesthetic elements of my17. Do you think it will work? It is the only unit I have found in my country. |
12-29-2023, 02:08 PM | #192 |
Drives: None
Yup. 27536CA030 is good to go as long as the transmission types match.
The Following User Says Thank You to RedReplicant For This Useful Post: | Ruben_86_ (12-31-2023) |
01-17-2024, 11:41 PM | #193 |
Thanks for the guide. I had this installed tonight. Don't be like me and accidentally push the white plug into the hole when trying to repin. I spent an hour trying to pick it out and then eventually got a screw, screwed it into the hole with the plug and pulled it out.
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
The Following User Says Thank You to tyler_win_photo For This Useful Post: | Yoshoobaroo (01-29-2024) |
01-29-2024, 03:15 PM | #194 |
Drives: Toyota GT86
I installed a 27536ca030 of 2016 and it works perfect in my 2012, thanks for the guide.
The Following 2 Users Say Thank You to Ruben_86_ For This Useful Post: | Jdmjunkie (01-29-2024), Yoshoobaroo (01-29-2024) |
01-29-2024, 03:43 PM | #195 |
Drives: None
Has anyone tried downloading calibrations through TIS and updating units with Calibration Update Wizard?
The Following User Says Thank You to RedReplicant For This Useful Post: | Trap63 (02-02-2024) |
03-15-2024, 12:32 PM | #196 |
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Is there a way to turn everything but ABS off automatically on startup?
2014 BRZ: Full track car. Gutted, caged, coilovers, AP enduro, OMP, bolt ons, aero, etc,
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc. 1992 NA Spec Miata: 1.6 + 1999 NB Spec Miata: 1.8 w/ all the goodies. 2018 GLE 63 AMG: +800hp whistling AWD TT V8 grocery getter 2016 GX460: IDK. Too reliable to sell. Too boring to use. |
Similar Threads | ||||
Review of "Track Mode" on the MY17+ cars | trippinbillies40 | Tracking / Autocross / HPDE / Drifting | 85 | 02-22-2021 09:27 PM |
FS: Nameless muffled track pipe 2013-2016 | Dave-ROR | Engine, Exhaust, Bolt-Ons | 4 | 05-20-2020 11:27 PM |
Track mode vs. VSC sport | alex87f | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 10-30-2018 10:47 PM |
2017 Track mode on older model | Bobster | Engine, Exhaust, Transmission | 17 | 12-03-2017 10:34 PM |
