Old 02-13-2017, 08:41 PM   #239
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Originally Posted by all4spl View Post
I'd say cruise control and abs/traction is a big deal. Glad you guys got it working. Now it's time for the LS swap kits to include that.
Already in motion sir
Pure Automotive is offline   Reply With Quote
The Following 2 Users Say Thank You to Pure Automotive For This Useful Post:
Draco_PR23 (02-14-2017), Sportsguy83 (02-14-2017)
Old 02-23-2017, 07:50 PM   #240
maxjedi
The Cloudmaker
maxjedi's Avatar
Drives: GT86, G37S
Originally Posted by Pure Automotive View Post
/thread
I have a few quick questions about the Motec kit:
1. Is it possible to use a jdm vvti 2jz ?
2. Can I use an AT GT86 as a base for this swap ? As far as I know, the ECU wiring is different in AT and MT cars.
3. Do I need any fuel system upgrades if I keep stock twin turbos ?
... my build thread: maxjedi's turbo "daily drifter" GT86 ...
maxjedi is offline   Reply With Quote
Old 03-01-2017, 01:43 AM   #241
R2RO
R2RO's Avatar
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
I have already inquired about using the 2JZ VVTI, they said as of this moment they have no plans for it. Unless a customer comes into their shop locally and they can modify a harness for the VVTI inputs, I'd say just stick with a Non-VVTI 2JZ. Unless you end up going with a Motec m150 which Varis86 is doing currently. Also they mentioned in their video that you should upgrade your fuel system accordingly with a bigger fuel pump and etc
R2RO is offline   Reply With Quote
The Following User Says Thank You to R2RO For This Useful Post:
Apex-Apex (03-01-2017)
Old 03-01-2017, 02:31 PM   #242
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
like said, we would have to have a car here. the Motec m130 is pretty close to its input/output limit so it "could" need an m150, but without going into it more im just speculating. also the crank trigger is different i believe so we would have to alter that in the software.
for fuel, a stock in tank pump may run stock twins at stock 2j boost level, but every car we have done has a single turbo and 400+ whp so its hard to say 100%. will the car run, of course. it just may run out of fuel when trying to make power. any drop in fuel pump will work since the motec controls the oem fuel pump controller, just like factory.
as for the ecu and wiring, everything the car needs to work the abs, cluster, fuel pump, steering, etc is in the bulkhead harness at the ecu. the auto trans related wiring will just go to nothing on the motec end of the jumper
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following 2 Users Say Thank You to spitfire481 For This Useful Post:
Pure Automotive (03-06-2017), R2RO (03-02-2017)
Old 04-08-2017, 11:24 PM   #243
Pure Automotive
[ame]http://youtu.be/kcIUkmbJMsU[/ame]
Sportsguy83 (04-08-2017), turtlefeeder (07-25-2017)
Old 04-11-2017, 04:53 PM   #244
Pure Automotive
Due to popular demand, we are adding VVTi 2JZGTE To our catalog! Our Plug and Play Setup can now be ordered for use with VVTi motors. We have also added VVTi friendly mounts to our website!
www.pureautomotiveperformance.com/shop
I would LOVE it if someone decided to drop a car off at the shop for a full VVTi swap in the near future so we can do a build thread and show off the compatibility
The Following 7 Users Say Thank You to Pure Automotive For This Useful Post:
Draco_PR23 (04-11-2017), DustinS (04-11-2017), ILLSMOQ (04-12-2017), maxjedi (04-15-2017), pooch (04-11-2017), R2RO (04-14-2017), Sportsguy83 (04-11-2017)
Old 04-12-2017, 05:57 PM   #245
Apex-Apex
Apex-Apex's Avatar
Hi
Varis 2JZ Build Thread
IG: @apexapexapex
Apex-Apex is offline   Reply With Quote
Old 04-12-2017, 06:09 PM   #246
Pure Automotive
Originally Posted by Apex-Apex View Post
Hi
Whats up
Old 04-13-2017, 01:37 AM   #247
Apex-Apex
Apex-Apex's Avatar
Whats up
You guys are too far
IG: @apexapexapex
Old 04-14-2017, 03:41 PM   #248
R2RO
R2RO's Avatar
Damn I would have dropped off mine if I actually trusted shipping companies. My other FR-S just sits anyways.
Old 04-26-2017, 04:26 PM   #249
spitfire481
Drives: 2JZ FRS
Our first overseas swap package is up and running without issue! Starts right up with all functions working. We have another one heading to the UAE as well. This customer has been struggling for months trying to get the car running before going with our solution.
MoTeC
Build Thread
@spitfire481
The Following 5 Users Say Thank You to spitfire481 For This Useful Post:
aslanteye (04-26-2017), ft86xtc (04-27-2017), ILLSMOQ (04-26-2017), Pure Automotive (04-26-2017), Sportsguy83 (04-26-2017)
Old 04-26-2017, 06:40 PM   #250
jbravo373
jbravo373's Avatar
Drives: 2013 WHITEOUT FR-S
any reason for not going with the vvti mounts from xcessive , instead of the cxracing?
jbravo373 is offline   Reply With Quote
Old 04-26-2017, 08:30 PM   #251
Pure Automotive
Only because we already test fitted these and know that they fit. We've used Xcessive for Non VVti and they worked. I'm sure the Xcessive ones probably work, I just won't sell anything I haven't personally test fitted yet.
jbravo373 (04-27-2017), Sportsguy83 (04-26-2017)
Old 04-27-2017, 01:49 AM   #252
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Can't wait to get ours, we just had the our motor maincapped and going all out I guess. Also I'm considering Pure's LS Motec package (once finished) for my personal car.
The Following 2 Users Say Thank You to SmsAlSuwaidi For This Useful Post:
Pure Automotive (04-27-2017), Sportsguy83 (04-27-2017)
Budget V8 Swap (under $10,000) wutsaiu Engine Swaps 146 06-11-2018 08:53 AM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
WTB A/T BRZ/FR-S CA Budget 21k Euan Want-To-Buy Requests 4 07-20-2015 11:50 PM
$2K Budget. What Would You Do? Skippman Electronics | Audio | NAV | Infotainment 46 02-22-2013 11:23 AM
There goes my MOD'ing Budget RedRocket Scion FR-S / Toyota 86 GT86 General Forum 35 10-19-2012 08:14 AM
