Forced Induction Turbo, Supercharger, Methanol, Nitrous |
10-11-2016, 09:08 PM | #43 |
Drives: 2015 Scion FR-S 6MT
Should have the engine out in the next couple weeks and another FA20 going in the car a few weeks after that. Pretty sure I know exactly what happened and how to prevent it from happening again. More details to come.
Sent from my SM-G900T using Tapatalk
10-12-2016, 08:51 AM | #44 | |
Drives: Late 2014 Subaru BRZ
I have mixed feelings about low comp pistons out of boost.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
11-04-2016, 06:28 PM | #45 |
Quick update: the FA20 I was going to buy didn't work out so looks like I'm going to put a V8 in it after all. But there's a twist, it won't be an LS engine.
Got the stock engine out And the trans is out Found a trans I think will work with the new engine And then there's this. . . . Sent from my SM-G900T using Tapatalk
The Following User Says Thank You to Amaya For This Useful Post: | Kylebrz (11-04-2016) |
11-04-2016, 08:23 PM | #46 | |
11-04-2016, 09:05 PM | #47 |
Nope, it's not a V6. (It's also not a Toyota engine)
11-04-2016, 11:06 PM | #48 |
11-04-2016, 11:24 PM | #49 |
I believe that's the rc-f or something. The 350 has a 3.5L V6. And this engine only makes about 380hp on the stock E85 tune.
11-04-2016, 11:59 PM | #50 |
That would make sense(350z). I can't afford a Lexus so I never looked into it much lol. I just remember seeing 5L V8 making any 450hp and LOLing at the Americans shitty power to ratios
11-05-2016, 11:01 PM | #51 |
Started taking the engine apart a bit
The Following User Says Thank You to Amaya For This Useful Post: | Sosa (11-10-2016) |
11-10-2016, 03:23 PM | #52 |
[||]--(86)--[||]
Drives: 2015 Firestorm FR-S
Thanks for the pictures! I love following projects like this as I'm no where near competent enough to open up an engine :-)
Do you know what causes the build up on the cylinder head? I wonder if it's a result of blow-by.
[||•]==(86)==[•||]
11-10-2016, 03:45 PM | #53 | |
The Following User Says Thank You to Amaya For This Useful Post: | Sosa (11-12-2016) |
11-12-2016, 12:38 AM | #54 |
[||]--(86)--[||]
How embarrassing, lol. Yes, I meant piston. I'm still learning so there is a lot of info rattling around in my head causing a mix up from time-to-time... but I promise I know the difference between the two.
Thanks for the answer!
[||•]==(86)==[•||]
02-07-2017, 02:51 PM | #55 |
Any updates on the LT1 swap?
2001 MR-S - long, slow, rebuild
2000 MR-S - 2zz swapped daily 2013 BRZ limited - new toy |
07-17-2019, 10:22 AM | #56 |
Drives: Brz ts
found this thread on the googles.....
i think an update is in order |
Similar Threads | ||||
WTB: SBD TURBO SETUP | BRZ_HaVoKx | Want-To-Buy Requests | 5 | 04-08-2016 09:36 PM |
Oil Catch Can for Turbo Setup | tonytduc | Forced Induction | 15 | 03-23-2016 11:16 PM |
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp | PrimeMotoring | Engine, Exhaust, Bolt-Ons | 8 | 10-30-2015 06:36 AM |
So you think your JDM turbo setup is simple, huh? | D K | Forced Induction | 6 | 07-27-2015 05:00 PM |
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp | PrimeMotoring | NY / NJ / CT / PA | 0 | 10-20-2014 10:48 AM |
