Old 07-06-2012, 04:27 PM   #43
simpleisbest
Senior Citizen
Drives: Scion FR-S
Hopefully my first event will be later this month.
I'll play with disconnecting the rear to see how it feels!!
It'll be tough to tell with the stock tires, but still should provide a good starting point.
simpleisbest is offline   Reply With Quote
Old 07-06-2012, 07:46 PM   #44
UncleFester
I forgot to mention that I am also running 225/17 Star Spec's on the factory wheels. So I get a lot of grip up front.
It's super easy to take the rear bar off. Six easy to get to bolts and it comes right off.
UncleFester is offline   Reply With Quote
The Following User Says Thank You to UncleFester For This Useful Post:
simpleisbest (07-16-2012)
Old 07-15-2012, 11:10 PM   #45
Sam Strano
Sam Strano's Avatar
Drives: 2013 FR-S Asphalt
Originally Posted by Asterisked Accolade View Post
Does anyone think that maybe the stock rear sway bar should be left as is, and only the front should be stiffened up? I ask because i would think a stiffer rear sway bar would increase an already present oversteer.
I think the rear should be left alone until/unless you do something with the front. And I sell swaybars!
Sam Strano is offline   Reply With Quote
Old 07-15-2012, 11:13 PM   #46
Sam Strano
Sam Strano's Avatar
Originally Posted by Archer1.8 View Post
You would think so, but its drivers preference. I have always driven nothing but subarus. EVERY subaru understeers like a pig. So the rule of thumb was always bigger rear bar, but thats my preference. I think a bigger bar upfront as well as a 17mm adjustable rear bar to dial in preferance would be good.
As stated, that's a stereotype that will lead to trouble. Most Subaru's also are much more nose heavy, with a higher cG, and you know... All wheel drive.
The last thing this thing needs is more rear bar in stock trim. The balance will go away. Also that causes more wheelspin. And how much more front do you need to make a given bar work? Well, that depends on a LOT of things including the spring rate and alignment (how aggressive do you want to be, how do you use the car, etc).
Old 07-16-2012, 02:33 AM   #47
simpleisbest
Senior Citizen
Drives: Scion FR-S
Couldn't you quickly disconnect the rear bar by just unbolting one of the end links? Used to be the quick fix for test'n tunes for the Miatas...
Old 07-16-2012, 10:47 PM   #48
Heero
Heero's Avatar
Drives: 2-door
What would be you opinion on getting stiffer bars in the back AND front for the BRZ? I'd imagine to get the same experience as the FRS on the BRZ we would need stiffer rears on the Zed?
Heero is offline   Reply With Quote
Old 07-16-2012, 11:01 PM   #49
jamal
jamal's Avatar
Drives: Legacy GT
It really depends on the tires you are using. More grip means you need more roll stiffness. There is a point where just adding more spring rate is detrimental and you need bigger bars.
With an Impreza, it's a safe bet to buy bigger bars (for a track sti, even huge bars work well). With the BRZ, I would expect only a modest swaybar upgrade is ever going to be needed even on slicks.
jamal is offline   Reply With Quote
Old 07-19-2012, 11:28 AM   #50
UncleFester
You could disconnect the endlinks and leave the bar on there if you wanted to.
I chose to take it all the way off and save myself the dead weight.
Old 07-28-2012, 11:04 PM   #51
jehu
Drives: JDM LN130 Toyota Hilux Surf
does anyone know what size the TRD swaybars are? or, how much stiffer they are than stock?
jehu is offline   Reply With Quote
Old 09-01-2012, 06:43 PM   #52
gmookher
since mounting the dunlop star specs I want a little more stiffness up front laterally, no more than a 10mm drop all around, and the rear sway bar is FINE imho. if .75 of camber is all stock class allows, that will be fine with how it turns in with the stiffer sidewall, it makes ita little twitchier than stock
those of you who are running stock tires dont do it for onemore day
you will regret waiting to wear out those ties
sell them to someone witha prius like i did, on ebay
gmookher is offline   Reply With Quote
Cosworth Internal Upgrades Confirmed DanPO Engine, Exhaust, Transmission 60 05-26-2015 05:45 PM
adjustable sway bars!!! carbonBLUE Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 05-04-2012 08:42 AM
STI rear sway bar carbonBLUE Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-25-2012 12:58 PM
