02-23-2019, 11:25 AM | #155 |
I just Drive.
Drives: in the womb still
I just made a small batch of honda shifters. Custom 7075 aluminum. If interested in having a batch made , throw a napkin drawing my way and I can CAD something up and let you approve it and make one up for you to try. Just hit me up in PM.
(CNC programmer/machinist)
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project |
03-11-2019, 03:52 PM | #156 | |
ECUMasters EMU Black (https://www.ecumaster.com/products/emu-black/) can apparently do full CAN integration for these cars too. Not sure how much custom work would still be required beyond wiring though.
03-11-2019, 03:59 PM | #157 | |
Drives: MR2, Sliver BRZ
Always looking to tinker with something..
03-11-2019, 04:43 PM | #158 | |
The ECU being able to support it doesn't mean it's plug and play... the motec that pure automotive is using also supports it, but they to do a ton of work (wiring, firmware, etc) to make it plug and play. My point was that there is another ECU option if you don't want the motec.
03-11-2019, 04:50 PM | #159 | |
03-12-2019, 08:52 AM | #160 | |
Proud of Boxer
I'm local and very interested in the swap, will there be any hope for those of use that want a cable throttle? I fucking hate DBW and don't use TC anyway, although I would like to keep cruise. |
03-12-2019, 09:25 AM | #161 |
Drives: 2013 Ultramarine FR-S
That is interesting. Why do you hate DBW?
03-12-2019, 09:25 AM | #162 |
Drives: 2JZ FRS
There is zero advantage to a cable with this ecu. We switched our drag car to DBW even. The idle control alone is worth it
03-12-2019, 09:39 AM | #163 | |
Proud of Boxer
Rev hang and a noticeable disconnect between the gas pedal and what the gas pedal controls. I've driven both and I've never driven a DBW that wasn't noticeable worse than a throttle cable, even when that throttle cable is on a 1995 Isuzu trooper. Still better than the BRZ, even with the BRZ tuned. Compared to my wifes '05 S2k? Not even close. Quote:
*I've never experienced a Motec car either for what that's worth. Last edited by s0sl0w; 03-12-2019 at 10:33 AM. |
03-12-2019, 12:47 PM | #164 | |
Probably have 100 hours or more of my life tied up in adjusting cables and linkage.
The Following User Says Thank You to Tcoat For This Useful Post: | wparsons (03-12-2019) |
03-12-2019, 04:19 PM | #165 | |
The motec ECU alone is about $2200, the EMU Black is about $1200, but the wiring/ECU package with the motec is likely going to be in the $5200 range. If someone were to sell the same kind of package (or if you're DIY on the wiring), but with the EMU black it could save about $1000.
03-12-2019, 04:34 PM | #166 | |
03-12-2019, 05:06 PM | #167 | |
Motec doesn't have a plug and play option either? That's what pure automotive is making (wiring and firmware). Interesting that they pulled the 86 support from the change log, wonder if it was leaked early or something?
The Following User Says Thank You to wparsons For This Useful Post: | Irace86.2.0 (03-12-2019) |
03-12-2019, 05:15 PM | #168 | |
Oh and yes! that a mistake in my part. I meant to say Pure Automotive Plug and play package. Not directly from motec themselves.
The Following User Says Thank You to geraldjust For This Useful Post: | wparsons (03-13-2019) |
Similar Threads | ||||
Pure Auto's Swap Compilation Thread - 2JZ and LSX ! | Pure Automotive | Engine Swaps | 29 | 01-10-2018 01:20 AM |
SwapYour86.Com Pure Automotive 2JZGTE Billet Intake Manifold For 2JZ FT86 Swap | Pure Automotive | Engine Swap | 0 | 12-01-2017 11:57 AM |
SwapYour86.Com Pure 2JZ MoTeC Plug & Play Wiring For FT86 !! | Pure Automotive | Engine Swap | 0 | 12-01-2017 11:49 AM |
SwapYour86.Com Pure LSX MoTeC Plug & Play Wiring For FT86 !! | Pure Automotive | Engine Swap | 0 | 12-01-2017 11:23 AM |
Pure Auto's 2JZ Swap Thread - The DRAGFRS | Pure Automotive | Engine Swaps | 153 | 06-20-2016 06:33 PM |
