10-24-2014, 06:46 PM | #8723 |
Drives: Scion FR-S White Out
I was planning on it...but my phone had no power when I started the install so I couldnt take photos. Here is a list of parts from ebay and some quick tips if it helps.
Ebay parts links: Red LED Switches http://www.ebay.com/itm/301310970001...%3AMEBIDX%3AIT 4 LED Strips http://www.ebay.ca/itm/4x-30cm-Red-1...item4ac200de4b Basics on wiring to cigarette lighter (He uses the same type switch) [ame="https://www.youtube.com/watch?v=juvFWa6PcBo#t=273"]How to Install Multicolor RGB Footwell Kit from Diode Dynamics - YouTube[/ame] How to access the cigarette lighter in the FRS center console explains at 1:00 minute mark how to remove shifter ring trim explains at 2:23 minute mark how to access cigarette power [ame="https://www.youtube.com/watch?v=YYQaiv8n4es#t=160"]DIY: FR-S FT86 LED EL Illuminated Console Plate Installation - YouTube[/ame] You will need a 3/4" spade bit to drill the hole....might have to carve it out a bit more to get the switch in.....this part took me the longest to line up the switch with the yo speed plate. You can choose whether you want 1 or 2 switches. Wiring is still the same. Tips for the switch The center pole is the switch....the positive from the LED strip solders there. The copper colored pole is for the ground. (splice ground from cigarette lighter and ground from LED strip and attach/solder here) The silver pole at the opposite end is for power. (splice positive from cigarette lighter and attach/solder here) You should pre solder or attach leads (wires) to your switch before you start. Hope this helps...at least a little.....feel free to PM if you have any questions. Last edited by Parappa; 10-24-2014 at 07:05 PM. |
The Following 4 Users Say Thank You to Parappa For This Useful Post: | illicitstylz (10-25-2014), iStanley (10-24-2014), LucidMomentum (10-27-2014), wtrxprs007 (10-25-2014) |
10-24-2014, 06:47 PM | #8724 | |
They call me Stan
Drives: Firestorm FR-S
10-24-2014, 10:52 PM | #8725 | |
Drives: 2014 FR-S
The Following User Says Thank You to kbye For This Useful Post: | G-awesome (10-25-2014) |
10-25-2014, 01:45 AM | #8726 |
Drives: 2014 FR-S
An update on the OEM sharkfin... I just did a test fit. It's 100% plug and play from 2015 -> 2014/13, despite what your dealers say.
The reason they might tell you it's not compatible is because they updated the part numbers on the entire harness from the antenna leading to the HU. But the connectors are exactly the same. Of course this is for FR-S only, I do not know if the same thing applies to the BRZ which has satellite radio. |
10-25-2014, 09:02 AM | #8727 |
Drives: 2014 Scion FR-S|Whiteout
Do you have the part number by chance?
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt |
10-25-2014, 10:52 AM | #8728 |
gotta go slower
Drives: 2014 FR-S
10-25-2014, 11:43 AM | #8729 |
Drives: Raven FRS
225/45/17 hankook ventus s1 noble 2's.
Flappy Paddlez~
The Following User Says Thank You to LT For This Useful Post: | Jolaessss (11-10-2014) |
10-25-2014, 01:16 PM | #8731 |
Drives: Raven
Road trip! Attempting to enjoy the car as much as I can before the Winter snow enters.
10-25-2014, 02:08 PM | #8732 |
Drives: Da-Big Banana
The Following 4 Users Say Thank You to TRD-X For This Useful Post: |
10-25-2014, 02:31 PM | #8733 |
Drives: Raven Toyota GT86
Nothing to the car itself, but i recieved my Tomei UEL header & keep on drooling all over it untill i can install it tuesday (hopefully)
Toyota Corolla E12 Hatchback (2005) - GONE
Toyobaru GT86 ハチロク - CURRENT |
10-25-2014, 02:46 PM | #8734 |
gotta go slower
Drives: 2014 FR-S
Nothing yet but FINALLY received my clear sidemarker lights.
Knocking these out the second I get home. |
10-25-2014, 05:12 PM | #8735 |
Drives: 2014 FR-S
Installing fourth brake led light.
The Following User Says Thank You to torranosaurus For This Useful Post: | dentalprodigy (10-25-2014) |
10-25-2014, 09:33 PM | #8736 |
Drives: Raven FRS
Thanks! Lowered on eibach sportlines and 20mm front and 25mm rear spacers.
Flappy Paddlez~
Tags |
:popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
Similar Threads | ||||
Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 10:19 PM |
