Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
04-03-2022, 09:13 AM | #15 | |
Drives: 2013 Rally Blue BRZ
Sent from my Pixel 4 using Tapatalk |
04-25-2022, 11:22 AM | #16 |
I ended up just cleaning out my OCVs and the codes went away. No rough idle either.
The Following 2 Users Say Thank You to demasrv For This Useful Post: | DarkPira7e (04-25-2022), Ultramaroon (04-25-2022) |
04-25-2022, 12:15 PM | #17 |
Rust bucket enthusiast
Good to hear! Glad everything worked out. The issue with my cam sprocket was that the bolts started backing out of the cam. Not a problem that had anything to do with cleaning them
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post: | demasrv (04-25-2022), Ultramaroon (04-25-2022) |
05-01-2023, 03:05 PM | #18 | |
Do you, or anyone have a re-assembly guide for these sprockets? Took one apart to clean, and then during reassembly noticed the internal cut-aways were different on 1 side (the other 2 being the same) and didn't know how it needed to be oriented. As well, another note. Using a spare engine to rob some pieces from, noticed differences on my sprocket faceplate (2016) from the other (presumably 2017+?). Does anyone know if the plate covers are the only differences or if the internal chambering is different? Mine (2016) - stock images: Spare Sprocket, presummably 2017+
Kyle H. - #89 STX
05-01-2023, 08:21 PM | #19 | |
Drives: Crapcan
Cleaning VVT camshaft sprocket assembly after spun bearing
Not a guide but does this work? I knew @rice_classic had some pictures and video in his thread. https://www.ft86club.com/forums/show...&postcount=247 Edit: oh and yes, the little cam reluctor is the only difference. When swapping 17’+ engine into older car, this is one of the things you have to change.
05-02-2023, 10:09 AM | #20 | |
I found a helpful video thanks to Dennis: Good to know we can swap to 17+ with only changing the faceplates in front of the solenoids, that’s currently what’s done and on the car so glad I don’t need to re-swap back Sent from my iPhone using Tapatalk
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post: | chanklins (07-24-2023) |
05-02-2023, 12:31 PM | #21 |
義理チョコ
He glosses over the most important part. The actual spool valve in the center comes apart. That's where carbon accumulates and jams the plunger.
07-24-2023, 12:29 PM | #22 | |
Drives: Scion FR-S RS1.0
That’s my sprocket right now: |
07-24-2023, 12:50 PM | #23 |
義理チョコ
Arrow points to the reluctor plate. The spool valve in the circle can be disassembled. Look down inside with a light to see a removable inside circlip.
Similar Threads | ||||
Spun Rod Bearing? | itsAlex | Issues | Warranty | Recalls / TSB | 38 | 03-12-2021 09:03 PM |
2013 FR-S Spun Bearing | kyjondeere | Issues | Warranty | Recalls / TSB | 1 | 09-14-2018 09:24 AM |
Spun Rod Bearing Warranty Service | Reprobate | Issues | Warranty | Recalls / TSB | 93 | 08-17-2018 02:39 PM |
Spun Rod Bearing #4 | KE70 | Issues | Warranty | Recalls / TSB | 13 | 07-05-2016 03:17 PM |
Likely hood of a spun bearing | aquaman | Engine, Exhaust, Transmission | 14 | 02-24-2016 01:37 PM |
