Forced Induction Turbo, Supercharger, Methanol, Nitrous |
05-10-2019, 12:11 PM | #15 |
It's the second haft of the tube that goes into the firewall. It's near the back on the passenger side
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post: | j_ros94 (05-10-2019) |
05-10-2019, 02:33 PM | #16 | |
What is the wastegate sprung for? Is there any sort of boost controller in the setup? Have you checked the vacuum lines for the wastegate to make sure there's no leaks/blockages?
05-10-2019, 02:38 PM | #17 | |
Drives: 2017 Subaru BRZ
Sent from my SM-G960W using Tapatalk |
05-10-2019, 02:39 PM | #18 |
Are you sure you have the T518Z kit and not T620Z? From what I can find, the T620Z is set with a 12psi spring vs the 7psi of the T518Z.
05-10-2019, 02:41 PM | #19 |
05-10-2019, 02:41 PM | #20 | |
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
33x on pump gas with a 518z kit is very very high in my opinion... I don't even think with the t620z would be able to get that high on pump
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside |
The Following User Says Thank You to Soloside For This Useful Post: | wparsons (05-10-2019) |
05-10-2019, 02:46 PM | #21 |
I'd check if the actuator is binding or anything, and if the vacuum line has any blockages. Definitely shouldn't be holding 6psi over the spring pressure. Where is it connected into the vacuum system?
05-10-2019, 02:50 PM | #22 | |
05-10-2019, 02:55 PM | #23 | |
Is there two (or more) holes on the actuator arm? If there is, you'll want the one that gives the most leverage (further from the pivot).
05-10-2019, 02:58 PM | #24 | |
The Following User Says Thank You to j_ros94 For This Useful Post: | wparsons (05-10-2019) |
05-10-2019, 06:51 PM | #25 |
Drives: Q5 + BRZ + M796
See the red tube on the left going to the sound generator? Remove the rest of the sound generator.
https://www.ft86club.com/forums/showthread.php?t=72263
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | j_ros94 (05-10-2019) |
05-13-2019, 04:10 PM | #26 |
So my car doesn't backfire even while Sasha was dyno tuning my car. Is that a tuning related question or?
05-13-2019, 04:12 PM | #27 | |
05-13-2019, 04:13 PM | #28 | |
Similar Threads | ||||
GReddy T518Z Turbo Kit | Richytort | Engine, Exhaust, Bolt-Ons | 4 | 09-01-2017 01:39 AM |
FS: GReddy T518Z Turbo | Jefffrs | Engine, Exhaust, Bolt-Ons | 2 | 08-15-2014 12:08 PM |
BRZ GReddy t518z | NOTORIOUS.BRZ | BRZ Photos, Videos, Wallpapers, Gallery Forum | 26 | 04-15-2014 02:15 PM |
GReddy T518z+Greddy CS GTS Ver 2. Video + pics (not tuned) | NOTORIOUS.BRZ | Engine, Exhaust, Transmission | 21 | 09-24-2013 06:09 PM |
