86SPEED
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Engine, Exhaust, Transmission
Old 07-16-2019, 09:33 PM   #1
kev0
AUTOMATIC TRANNY
Drives: 2014 FRS AT
Where is the DI Ecu located?
Can someone post a picture of where this is located?
kev0 is offline   Reply With Quote
Old 07-16-2019, 10:16 PM   #2
skylinekin
skylinekin's Avatar
Drives: 15 BRZ, 13 FRS
On passenger side of engine near valve cover. Large black box with harness.
skylinekin is offline   Reply With Quote
Old 07-16-2019, 10:17 PM   #3
CSG Mike
CSG Mike's Avatar
On the passenger side above the injectors
Old 07-16-2019, 10:47 PM   #4
kev0
AUTOMATIC TRANNY
Drives: 2014 FRS AT
So this one, right? I read that the bottom bolt can cause grounding issues and I'm going to try and see if that will rule out my issues. It looks really tight...how can I even screw the bolt down there? Would I need to jack my engine up? :x
The Following User Says Thank You to kev0 For This Useful Post:
CSG Mike (07-17-2019)
Old 07-16-2019, 11:05 PM   #5
Mr_Eyo
Drives: 2017 Toyota 86
That's it. If you can see the 3rd bottom bolt going into the block and it's tight, your ECU is grounded. What are your issues?
Mr_Eyo is offline   Reply With Quote
Old 07-16-2019, 11:41 PM   #6
kev0
AUTOMATIC TRANNY
Drives: 2014 FRS AT
Got a lean code (P0171). Fuel trims are actually pretty high so it could very well actually be lean. Was just trying to rule out a possibility.
Thanks!
Old 07-17-2019, 03:31 AM   #7
steve99
steve99's Avatar
Drives: FT86
Thanks!
Alternativly you can run a ground wire to chassis ground from the top bolt
steve99 is online now   Reply With Quote
Old 07-17-2019, 01:24 PM   #8
Mr_Eyo
Thanks!
I got this too. Turns out the aftermarket in-tank fuel pump was not seated properly, dropping feed pressure to 38 psi. The DT flex fuel kit I have saw an out of limit low pressure and zeroed out the ethanol content signal to the ECU, making it think I had 100% gasoline instead of the e85 I actually had. It then was running leaner than it should have been, my STFTs pegged at 30%.
Perrin 25 mm wheel spacers, 4 of them located in so cal Lonelydriver Brakes, Suspension, Chassis 3 03-04-2019 09:14 PM
FS: OFT Located in SoCal bitesthedust Engine, Exhaust, Bolt-Ons 4 11-11-2016 03:21 PM
Anyone located near Fullerton, CA? Help! bcmakesiteasy Southern California 4 03-16-2014 07:58 PM
FS/FT Whiteout FRS AT under 5k miles located in MI CW-FR-S Cars for Sale/Trade 4 10-04-2013 07:27 AM
Located Firestorm FR-S in Katy, TX PhastekSport Southwest 5 11-20-2012 02:22 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
