Forced Induction Turbo, Supercharger, Methanol, Nitrous |
07-12-2019, 10:16 PM | #1 |
Drives: 2013 FRS
Blow off valve open at idle
Hey guys, just finished installing the JDL turbo kit. My issue is that the BOV stays open at idle, even after tightening it down all the way ("hardest" setting). My line for the bov is T'd in to the brake booster line, before the check valve, as many instructions said to do. However, following this line does not lead to the intake manifold, but to a port on the passenger side of the block. I have a 2013 automatic FRS, and since researching a bit have seen indication that the automatic may be different than the manual in this regard. Can anyone tell me if I'm T'd in to the wrong line, and if so, where I should tap into on an automatic car? I was told I may need a stiffer spring for the BOV, but that seems strange considering the quality of this kit.
Pictures: https://imgur.com/a/tlsi3M3 Edit: couldn't figure out how to add a picture to the other album so here's one with the block port I mentioned circled. https://imgur.com/a/BJipqtY Last edited by James Russels; 07-12-2019 at 10:48 PM. |
07-12-2019, 10:55 PM | #2 |
Drives: Broken Blue BRZ
Yeah the autos have different routing for the brake booster lines. On the top/back of the intake manifold, there are two ports for vacuum lines. One will be capped off on your car. You can run the line to there. I ran a tee there for my gauge and BOV and it works fine.
07-12-2019, 11:35 PM | #3 |
Drives: 2013 FRS
Thanks, so just to clarify, I would run the bov line directly to the capped off port on the back of the intake manifold? And I'd just need an adapter of some sort?Since I'm pretty sure that port is way bigger than the bov hose. And you just had a tee since you had the boost gauge as well, I presume.
07-12-2019, 11:45 PM | #4 | |
07-18-2019, 10:06 PM | #5 | |
Drives: 2013 FRS
07-18-2019, 10:33 PM | #6 | |
Yeah my BOV will flutter when it’s only under a few psi. At like 10psi it’s more of a single loud sound. I don’t believe there’s anything to worry about with it and it’s more attributed to the style of BOV. If it’s staying closed under acceleration and properly releasing when you let off, it’s doing its job. The bad kind of turbo flutter is when your turbo is pumping so much air into the engine that it can’t take it all and then it starts pushing back on the compressor, creating a fluttering sound. Sent from my iPhone using Tapatalk |
07-21-2019, 11:46 AM | #7 |
Rust bucket enthusiast
This isn't a thing. It's called forced induction because it adds air that the engine can't refuse, if it can't hold it the engine blows. The chopping/flutter sound is when the throttle body slams closed and the blow off/bypass valve on the intake piping can't evacuate the air fast enough.
07-22-2019, 01:16 AM | #8 | |
Drives: 2013 FRS
07-22-2019, 01:31 AM | #9 | |
Similar Threads | ||||
Fs: AVO 50/50 blow off valve and 2 3 port boost control solenoid | protpibe | Engine, Exhaust, Bolt-Ons | 2 | 01-12-2017 08:02 PM |
FS: Brand New in box, Limited Edition HKS Super SQV Blow off Valve | FutureFT86 | Engine, Exhaust, Bolt-Ons | 15 | 08-29-2016 03:24 PM |
VIDEO - How a Blow Off valve works, what it does and how to choose the right one. | The Sentinel | Forced Induction | 3 | 01-18-2016 01:28 AM |
New: HKS Gunmetal Finish Super SQV IV Blow-Off Valve | HKSUSA | Engine, Exhaust, Bolt-Ons | 0 | 07-14-2015 02:28 PM |
Tial Q Blow off valve | Gen | Engine, Exhaust, Bolt-Ons | 1 | 11-01-2013 08:34 PM |
