03-09-2018, 11:01 AM | #183 | |
Drives: 2013 Subaru BRZ
Also, is the RTV silicon really needed? I talked to some mechanic friends and they said it isn't necessary in newer cars due to the gaskets they use. Finally, should I just order the driver side intake sprocket, since I'm already replacing the Passenger side one for CEL P0016? Is the driver side Intake sprocket Part No. 13322AA031 ? And Passenger side intake sprocket is 13322AA021 Thanks! Last edited by TheStig85; 03-09-2018 at 11:30 AM. |
03-09-2018, 10:58 PM | #184 | |
Drives: DGM BRZ limited
https://parts.subaru.com/p/Subaru_20...806916080.html There is no real gasket there. RTV is the only gasket. It comes this way from the factory. I went ahead and did both. An extra $180 for the other was worth it, but that's up to you. Part numbers look right but I highly recommend finding your way around the parts.subaru web site. Incredibly useful, has diagrams and will confirm parts for you. |
03-09-2018, 11:01 PM | #185 |
Update on my car, got the new ECU in. No issues following the instructions save the first start was incredibly rough, but that's to be expected when putting an ECU that had learned a different vehicle on.
Driven around 30 miles in 5 different trips and no CEL. Hope it stays that way. |
03-14-2018, 09:06 PM | #186 |
Drives: BlueBurz
P0018
Thought I'd contribute to this thread based on my current(ongoing) experience. Had this code 1 year ago and had the dealership change the OCV, then ECU and the issue went away for a year or so only to return. This time, had a mechanic friend at a dealership give me the skinny. I did the sensor swap check, he did the OCV swap check and issue stayed on the LHS, pointing to the sprockets. He took them apart and the little spring cover popped out as he was taking it apart, confirming in his mind that indeed the sprocket had failed. So FF to the sprocket change after which code came back within the 2nd drive cycle(code could be detected in the Pending list after the 1st drive cycle). He then indicated that the ECU needed to be changed, to which I challenged the notion. (That's what the repair manuals say to do.) I asked him to ask the Subaru Tech line about this(especially given ECU was just changed). They indicated that it_is_possible to not change the ECU and all will be ok, it just can take a couple thousand miles to register the new Cam values. That is the path I've taken-so I will report in a few(hopefully small few) thousand miles that all is well. For now I simply reset the code after the 1st drive cycle(pending code showing) . There is no longer a mechanical issue with the new (updated) sprockets, but the old values in the ECU are at odds with the faster responding new sprockets....ECU needs more time(allegedly) to realize that this is the new normal. My car is a 2013 BRZ. ECU already updated in 2016...I'm learning way more about this car than I planned. Car has had 3K mile oil changes-this is a flaw in the sprocket design, combined with an ECU that has an Elephant-like memory.
The Following 2 Users Say Thank You to kinghurl For This Useful Post: | TheStig85 (03-14-2018), Ultramaroon (03-14-2018) |
03-15-2018, 02:06 PM | #187 | |
03-15-2018, 03:45 PM | #188 |
Drives: Track preped NA FRS
The whole "need to change ECU, values are burned into it" is just wad. What probably really happens is that they have to way to delete or reset those values thru their software and thus, its easier to just throw parts at it. I had the P0016 and my mechanic was able to reset ECU after correcting the problem correctly, he did it thru Ecutek software tho, not Techstream or whatever subaru uses.
03-15-2018, 10:46 PM | #189 | ||
03-15-2018, 11:06 PM | #190 |
Yeah no, im not talking abour reflashing, but actually modifying values in the ECU thru the ecutek software (not flashing, flashing is just writing the AFR tables and what not, this is not that)
03-16-2018, 02:28 AM | #191 | ||||
Drives: FT86
AFAIK their are three main mamoty areas in the main processor in the ecu its a renasis SH72531. Their is the RAM area this is working memory for shortvterm data including learned data, fault codes, counters timers and the ecu workingmemory. All this data ia lost if power to the ecu is remced for a shotr period. Then their the flash memory area. Theors two secions the boot area that not changed when you flash tunes. 0000-7FFFF. This provides just basic operation and ability for ecu to talk to can buss and the obd port if the main flash area failes or is erased or corrupted , in most cases. Then their the tune area of flash memory 8000-13FFFF. This is where the tune is held, anad is the area reflashed by oft tactrix ecutek or whatever. If your ecu needs replacing it will be because ghe main processor has failed or got into a lockout and unrecoveravle state. You will know this as you car will not start and the ecu wont talk to the obd port. Or one or more of the periferal interfaces that send or recieve info from the various sensors like cam position or oil control valves or the many other sensors or acutators has failed or is not working correctly. This last case is why subaru or toyota would be replacing the ecu, ie the ecu is not sending or receiving or signals to cam sensors or actuators. The "burned in values" or that ecu takes thousands of km to calibrate cams again seems totally bogus. Each timecto reflash or resetvecu all the learned parameters are lost, when you first start car the ecu starts with default values and then calibrateds and learn coreections for various sensors and functions. You doo need to let car idle for avout a minute after reflash or reset to learn cam zero positions. But its not burned in . The ecu constantly learns corrections , and if you reset or reflash it it just stsrts again from default |
The Following 6 Users Say Thank You to steve99 For This Useful Post: | alxtheoreo (03-16-2018), DAEMANO (07-11-2019), Icecreamtruk (03-16-2018), kinghurl (03-16-2018), Teseo (03-18-2018), TheStig85 (03-16-2018) |
03-16-2018, 07:02 PM | #192 | |
Drives: BlueBurz
03-16-2018, 07:25 PM | #193 | |
Drives: BlueBurz
03-17-2018, 05:08 PM | #194 |
義理チョコ
If anyone has one of these OBDLink doohickeys, their software can now monitor vvt data real time.
I put together this dashboard with all the parameters that I figured were significant. A couple, like the target and actual angles, are intuitive but I don't know what the others mean. There are a couple times in this clip where the actual value seems to lead the target. I think that's aliasing due to the low sample rate. ...I think.
03-21-2018, 11:07 AM | #195 | |
I'd love to hear from other confirmed cases of broken sprocket what oil was being ran. |
03-21-2018, 11:09 AM | #196 |
I've been running a 0w30. Living in a warm climate though, Miami, FL.
Similar Threads | ||||
P0016 fixable without new ECU? | Mr.Jay | Issues | Warranty | Recalls / TSB | 8 | 02-06-2022 05:15 AM |
P0016/P0017 cause | AVOturboworld | Issues | Warranty | Recalls / TSB | 18 | 04-16-2021 11:09 PM |
P0016 Code | Shady195 | Engine, Exhaust, Transmission | 30 | 02-21-2019 02:31 PM |
p0016 need help asap | lol | Issues | Warranty | Recalls / TSB | 25 | 10-30-2018 03:49 PM |
OFT P0016 and TSB question | mmmcambelsoup | Software Tuning | 10 | 05-24-2017 09:24 AM |
