01-28-2018, 06:24 PM | #99 |
Drives: DGM BRZ limited
Nothing other than take them out. I bought a new intake sprocket, came in yesterday, but I'm now out of town until Friday. Since I have a new one I'll probably further take my old one apart and see if there is anything else of note wrong with it. I expect I'll have it back together in about 2 weeks, at which point I'm 98% sure the code will come back, at which time I'll decide if I want to get a new ECU or try disabling the code.
01-29-2018, 01:21 PM | #100 | |
Drives: 2013 Subaru BRZ
My only guess is changing the oil (it's due) and the shims on the sensor. I'm at a loss otherwise. |
01-29-2018, 01:48 PM | #101 |
Your sprocket hasn't been out, correct? could still be a damaged sprocket.
01-29-2018, 01:48 PM | #102 |
01-29-2018, 02:11 PM | #103 | |
My car in stock form also ran fine. I noticed some issues around idle with my turbo tune, but they came and went, sometimes it would be fine for weeks. If it weren't for the CEL popping up I likely would have never faulted anything on the car once I went back to stock. |
01-29-2018, 02:14 PM | #104 | |
CEL or not, my car has run smooth for as long as I've remembered. |
01-29-2018, 02:42 PM | #105 | |
義理チョコ
01-29-2018, 03:03 PM | #106 | |
Mind to share the diagrams? I'll probably take apart the intake vvt but unless I'm 100% I won't mess it up I won't be taking apart the exhaust. Regardless I can document the intake if you are interested in seeing inside. |
01-29-2018, 04:34 PM | #107 | |
義理チョコ
I'd love to see pics if you get around to it.
The Following User Says Thank You to Ultramaroon For This Useful Post: | rusty959 (01-29-2018) |
01-29-2018, 06:32 PM | #108 |
If anyone is lazy like me, I compiled the o ring's and oil seal part numbers that should be replaced while the timing cover is off. Sometimes I don't replace things like this because they shouldn't leak but I really don't want to have to pull the cover back off if they do. I'm not going to worry about the ocv ones because it will be obvious if they leak and easy to replace if they do. (and I'm lazy)
806912190 x3 o ring $1.26 https://parts.subaru.com/p/Subaru_20...806912190.html 806924120 x1 o ring $1.88 https://parts.subaru.com/p/Subaru_20...806924120.html 806750080 x1 timing cover oil seal $14.57 https://parts.subaru.com/p/Subaru_20...806750080.html Not confirmed: 806916080 x1 https://parts.subaru.com/p/Subaru_20...806916080.html o ring for driver's timing chain tensioner. Passenger side doesn't use one. Looks like there is a different part number if you have a super early '12 build date. Last edited by rusty959; 03-09-2018 at 10:55 PM. |
02-03-2018, 11:06 PM | #109 |
Drives: None
Well... the nice little code came back today while I was driving for an ice driving event. I just kept on resetting the damn code throughout the day, but otherwise no perceptible with the engine running. Seems like others are having no better luck. Part of me is wondering if this is related to weather?
Anyway I will swap a few more parts and maybe the ECU before springing for a a cam sprocket. Freakin job is like 10% of the cars value... :/ |
The Following User Says Thank You to Jamestl For This Useful Post: | Ultramaroon (02-03-2018) |
02-04-2018, 12:25 AM | #110 | |
義理チョコ
That's how I understand the reasoning behind the need to replace the ECU. It is the second part of a cascade failure. It makes enough sense to me that I would consider replacing the ECU only if the issue is not resolved by first replacing the sprocket.
The Following User Says Thank You to Ultramaroon For This Useful Post: | Tcoat (02-04-2018) |
02-04-2018, 10:09 AM | #111 | |
Drives: None
The thing that pisses me off is that you don’t actually know whether sprocket has failed. If I just reset the ECU everything worked as before - I noticed zero change. I’m almost tempted to get a new ECU before I change the sprocket given the cost differential. Sigh...
The Following User Says Thank You to Jamestl For This Useful Post: | Ultramaroon (02-04-2018) |
02-04-2018, 10:41 AM | #112 | |
Drives: 2014 Subaru BRZ Limited 6MT SSM
The Following User Says Thank You to ApexEight For This Useful Post: | Ultramaroon (02-04-2018) |
Similar Threads | ||||
P0016 fixable without new ECU? | Mr.Jay | Issues | Warranty | Recalls / TSB | 8 | 02-06-2022 05:15 AM |
P0016/P0017 cause | AVOturboworld | Issues | Warranty | Recalls / TSB | 18 | 04-16-2021 11:09 PM |
P0016 Code | Shady195 | Engine, Exhaust, Transmission | 30 | 02-21-2019 02:31 PM |
p0016 need help asap | lol | Issues | Warranty | Recalls / TSB | 25 | 10-30-2018 03:49 PM |
OFT P0016 and TSB question | mmmcambelsoup | Software Tuning | 10 | 05-24-2017 09:24 AM |
