follow ft86club on our blog, twitter or facebook. Interested in the FT-1? Check out FT1Club
RR Racing
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Engine, Exhaust, Transmission
go_a_way1
Old 05-03-2017, 03:54 PM   #449
johan
johan's Avatar
Drives: Limited
Originally Posted by nunonuna View Post
Can anyone tell me how this exhaust sound differ from Q300?
In every way, they're not even in the same universe. I've heard both in person. The q300 can diaf as far as I'm concerned, the lg90 makes the car sound like a Porsche.
johan is offline   Reply With Quote
The Following User Says Thank You to johan For This Useful Post:
Ultramaroon (05-09-2017)
Old 05-03-2017, 04:47 PM   #450
nunonuna
nunonuna's Avatar
How about loudness??
Your comment made me more interested in this catback lol tho.
nunonuna is offline   Reply With Quote
Old 05-04-2017, 02:09 AM   #451
johan
johan's Avatar
Drives: Limited
This is probably the quietest exhaust you can put on the car, I think it's quieter than stock.
Old 05-04-2017, 03:14 AM   #452
makinen
makinen's Avatar
Drives: Toyota 86
Originally Posted by retrofit View Post
Going back to the topic of reverse lights...
Is it in the realm of possibility to cut the center fog light out of the reverse light module to provide enough room for the exhaust tip to pass through while still retaining it's function?
Assuming the above is possible, would some heat shield between the exhaust tip, and the reverse light, be enough to stop it from melting/failing from the heat?
If the above is a no go then a simple standalone aftermarket or subaru reverse lights with compatible wiring/connector might be the easiest fix. I'm thinking of placing the standalone reverse light in the empty space next to the exhaust tip (assuming heat isn't an issue) or maybe to the right of the bumper close to the stock exhaust tip.
Right now I'm having trouble finding standalone aftermarket/OEM reverse lights as a google search of 'subaru reverse light' is giving me results for replacement bulbs or reverse lights integrated with tail lights
I'm already bought another reverse light module to make a center hole, but not yet started. As watching several stock bumpers of recent cars, I think this could be done.
/* RCE Tarmac springs + Koni yellow dampers
294x28mm 2-piece brake disc + modified stock calipers
Konig Hypergram 17x9 et+40 + 255/40R17 R-s3+RSRR
HKS GT Supercharger V3 + 100mm pulley
HKS GT EL header, 17MY intake manifold */
makinen is offline   Reply With Quote
Old 05-09-2017, 06:28 PM   #453
AxisPower
Drives: 86 Corolla GTS, 13 FRS
I'm sure I'm in the minority here, but if this redesign also had an option for a quad tip outlet that fit a trd rear bumper that would be awesome.
AxisPower is offline   Reply With Quote
Old 05-09-2017, 08:52 PM   #454
Autobahnned
It takes all the "ratta-tatta-tatta" and turns it into "raffa-taffa-taffa."
Jmonty (05-09-2017)
Old 08-05-2017, 10:23 PM   #455
Autobahnned
Bump.
My wife swears she saw another Ultramarine or GBS with an LG90 in Camas the other day. He had relocated his backups to cover the original exhaust cutouts. YOHB?
I've been lazy about getting my backups working.
Old 08-06-2017, 07:09 AM   #456
Williampreza
Drives: 2017 Ice Silver BRZ Limited
Bump.
Rigid Industries makes a set of flush mount backup lights. My plan (when I get this exhaust eventually) is to mount those in exhaust cutout covers and terminate the leads with wedge type connectors (easy to find on ebay). That way everything looks nice, but is also completely reversible JIC
Williampreza is offline   Reply With Quote
The Following User Says Thank You to Williampreza For This Useful Post:
Ultramaroon (08-06-2017)
FNA rear fog light Kit 1 w/high power LED HATED1 Exterior Parts (Aero, Lighting, Etc.) 5 02-09-2015 05:31 AM
HKS High Power Spec-L Ti-Tip Tien Engine, Exhaust, Transmission 0 10-23-2013 11:54 PM
Mach V muffler delete prototype Mach V Dan Engine, Exhaust, Transmission 118 02-01-2013 08:41 AM
5W High Power CREE LED Zoomryder Cosmetic Modification (Interior/Exterior/Lighting) 0 09-21-2012 06:30 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
