01-13-2014, 11:46 PM | #155 |
Drives: 2015 WRX
This question has been answered at least half a dozen times over the past three months including a formal response from Subaru. The pulleys are just pulleys, not harmonic dampeners.
01-13-2014, 11:47 PM | #156 |
Drives: Sc10n FRS "DCLXIV"
Are you going to offer the red anodized S2 kit again?
Sc10n FRS #0664
01-14-2014, 07:04 AM | #157 |
The Following User Says Thank You to Raceseng For This Useful Post: | *LongFella (01-21-2014) |
01-14-2014, 09:25 PM | #160 |
Drives: Toyota Galaxy Blue Silica 86
Loving my blue ones... haven installed it yet though... its too beautiful to put it on the car... lol
03-02-2014, 10:33 AM | #161 |
Any DIY videos available for a complete pulley swap? Took a look around, nothing conclusive.
Jarrett, would you recommend this as a DIY? I see a few people taking the install to shops in the thread. Thanks!
03-02-2014, 10:42 AM | #162 | |
Drives: 2015 WRX
http://www.ft86club.com/forums/showthread.php?t=12583 The crank pully is the only one that sounds like you need to seriously pay attention to. The other pulleys are pretty straight forward minus the alternator pulley, which sounds like a pain in the ass to get the bolt off. The directions that came with my cascams and the rear shock tops were pretty good. Jarrett has personally answered all my questions when I've called him several times. If you were going to do puleys, there is no other company than raceseng I'd recommend. The customer support was outstanding. |
The Following User Says Thank You to Malt For This Useful Post: | Raceseng (03-02-2014) |
03-02-2014, 10:50 AM | #163 | |
This can be done as a DIY. The hardest part is getting the crank pulley bolt to loosen. It requires a breaker bar and some effort. The other pulleys are simply bolt off and bolt new pulley on. Email me jarrett (@) raceseng.com and I can email you the instructions to see if it's something you want to tackle. Thanks! Jarrett Seng Raceseng | Owner 610.336.0206 |
The Following User Says Thank You to Raceseng For This Useful Post: | 1Cor10:23 (03-02-2014) |
03-02-2014, 10:50 AM | #164 |
Yeah the instructions are basically what you would find in the DIYs posted. I just did the install last week. The crank pulley is a PITA to get loose, and just make sure when you pull it off you put your finger in to keep the sleeve from pulling out with the pulley.
The water pump pulley if you have the belt on you can get them loose very easily, just keep the car in 6th gear with the ebrake on. Alternator pulley I used an electric impact wrench to get off so I can't help you there but if you have a strap wrench you can probably hold it in place to get it off or again if the belt is on it might have enough tension to keep it in place since it's not that tight. |
03-07-2014, 09:11 AM | #165 |
Severed Member
Drives: Argento 2013 Scion FR-S Manual
I've done a few searches to no avail. You know of any thread with that response from Subaru? thx!
87 Volvo 760 Turbo <3
02 WRX THE QUEEN IS DEAD, LONG LIVE THE QUEEN! 06 Xfire Bite me I liked it 13 FRS doriftoooo! DON'T PANIC |
03-07-2014, 10:06 AM | #166 | |
Drives: 2015 WRX
The Following User Says Thank You to Malt For This Useful Post: | red_comet (03-07-2014) |
03-07-2014, 10:21 AM | #167 | |
Severed Member
03-29-2014, 07:46 PM | #168 |
Drives: 2013 MT Asphalt FRS
I need some help.
Had a hard time taking off crank pulley, so started searching on the forums for other alternative. Read it would be best to take off the serpentine belt first. Eventually got it off, but now I'm having a hard time loosening the alternator pulley. I put the belt back on, but the the alternator screw moves as I try to loosenit. Any advice? Thanks. |
Tags |
engine pulleys, raceseng |
Similar Threads | ||||
SRP Billet Aluminum Door Sills | pedalpusher | Interior Parts (Incl. Lighting) | 2 | 09-20-2012 10:25 PM |
SRP Billet Aluminum Door Sills | pedalpusher | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 09-20-2012 06:44 PM |
