04-27-2019, 12:22 AM | #57 | |
義理チョコ
The support bushing could be made taller so it projects more deeply onto the quill. There's plenty of room and it would greatly reduce binding and galling for free.
04-27-2019, 02:33 AM | #58 | |
humfrz |
05-03-2019, 06:48 PM | #59 |
Drives: Scion FR-S Series 10 #2462
@Beachin86, quick question:
Your Series-10 is from 2013 so your 36-month warranty ran out in 2016-17. You got the Toyota Golden Ticket Extra Special Super Sonic Service Plan (as I did) that allowed you to get the work on your TOB done "free" under warranty? The last time I tried to renew my service plan with South Bay Toyota, they said my Series-10 no longer qualifies. :-( |
05-03-2019, 07:44 PM | #60 | |
Drives: FR-S 10 Series
The Following 2 Users Say Thank You to Beachin86 For This Useful Post: | gravitylover (08-04-2019), MJones_RB (05-06-2019) |
06-04-2019, 11:58 AM | #61 | |
Drives: 2014 FR-S MT
I've been chasing a small oil leak since I changed my TOB and clutch last fall. At first I thought it was the oil pan, because I dented my old one during the job and put a new one on. But I changed my oil this weekend and cut off and resealed the pan, but the leak was still there after coming back from a drive. I checked around the edge of the pan and oil doesn't seem to be coming from there, or to be seeping through any of the bolts. Looking closely, it seems to be coming from within the bell housing. I use Motul transmission fluid, so it's the same color as engine oil. Thinking back, I remembered seeing some oil at the bottom of the bell housing when I pulled the transmission. I didn't think much of it at the time -- I thought it was just grease from the old TOB. But now I'm thinking that retainer/cover is the source of my leak. I saw in Techstream that the cover is FIPG'd on -- is it a real pain to cut off? I'm debating whether to go to the dealer to try to have it fixed under warranty. But I don't have a relationship with them; they haven't seen me since the free oil changes ended a couple of years ago. |
The Following User Says Thank You to H1C For This Useful Post: | MJones_RB (06-14-2019) |
06-04-2019, 04:44 PM | #62 | |
義理チョコ
The Following User Says Thank You to Ultramaroon For This Useful Post: | H1C (06-04-2019) |
06-04-2019, 06:18 PM | #63 | |
Thanks! One thing that makes me think it's not engine oil is that I just changed my engine oil this weekend, and when the leak came back after a drive, it looked like dark, used oil. This batch of Motul trans fluid went in in October when I changed the TOB. Either way, it looks like the transmission has to come off again to be sure. I'll try to get it covered by warranty first before I tackle the job again. I really did not enjoy pulling and reinstalling the transmission by myself last time. |
06-04-2019, 11:54 PM | #64 | |
義理チョコ
Also get a nice little transmission jack. Your noob friends will appreciate it when you help them drop their transmissions.
The Following User Says Thank You to Ultramaroon For This Useful Post: | H1C (06-05-2019) |
06-05-2019, 12:33 PM | #65 | |
Yeah, my over-enthusiastic supporting of the engine is how I dented my original oilpan I like your idea of using a tie-down strap to the strut tower braces -- do you route it under the oil pan? And I picked up a HF trans jack -- after I finished my TOB/clutch job, a buddy with a WRX tried to rope me into helping him change his clutch. I declined IF the dealer declines warranty coverage, I'm picking up a set of SUV jackstands to create more room to work underneath the car this time. |
06-05-2019, 02:17 PM | #66 | |
義理チョコ
At first I went into detail about the strap tip, but backed out after I realized that I don't remember exactly how I did it. I want to say I snaked the strap underneath the alternator and A-C pulleys but I'll go out and review tonight when I get home. I think I had to work around some delicate bits. I'll post some images for posterity.
06-05-2019, 11:56 PM | #67 |
義理チョコ
The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (06-06-2019) |
08-04-2019, 01:50 PM | #68 |
Drives: 2014 BRZ Limited
I think I'm having this problem. Started yesterday. I noticed it after about an hour and a half drive.
I bought my car in August 2014 and have 58K on it so hopefully I'll be able to get this covered under warranty. I'm probably going to be selling the car early next year so I don't want to spend several hundred on a clutch. I don't drive hard at all and the clutch feels great otherwise so I'm pretty sure it's still in good shape. |
The Following User Says Thank You to echo419 For This Useful Post: | humfrz (08-04-2019) |
08-04-2019, 04:03 PM | #69 | |
I understand that once a TOB goes out on these cars - it can take a lot of clutch associated parts with it. You may wish to share what you are hearing/feeling that leads you to believe the TOB is going bad? humfrz |
08-04-2019, 05:03 PM | #70 |
義理チョコ
You may find yourself in a beautiful house, with a beautiful wife.
The Following User Says Thank You to Ultramaroon For This Useful Post: | gravitylover (08-04-2019) |
Similar Threads | ||||
Melted Throw Out Bearing | danthedirt | Issues | Warranty | Recalls / TSB | 59 | 01-25-2018 05:32 PM |
Throw out bearing | Hyp | Northern California | 26 | 03-13-2017 11:42 PM |
Post If You Have Had Your Throw-Out Bearing Go Bad! | Bushhy | Issues | Warranty | Recalls / TSB | 8 | 10-24-2016 05:34 PM |
Throw-out bearing | mhigham | Issues | Warranty | Recalls / TSB | 71 | 08-18-2016 10:21 AM |
throw out bearing clips... | Shit Luck | Engine, Exhaust, Transmission | 0 | 04-12-2014 06:34 PM |
