DIY (Do-It-Yourself) Guides For all DIYs. |
03-25-2019, 08:23 AM | #15 |
Fun to see how many more don't read this and say don't do it.
03-25-2019, 04:53 PM | #17 |
ProCrastinationConsultant
you're supposed to ask?!?
The Following User Says Thank You to soundman98 For This Useful Post: | Spuds (03-25-2019) |
03-25-2019, 06:54 PM | #18 |
Sarcastic SOB
That would be more like lifting your car from the side mirrors.
The Following User Says Thank You to wbradley For This Useful Post: | soundman98 (03-25-2019) |
03-25-2019, 06:55 PM | #19 |
Sarcastic SOB
Do it!
03-25-2019, 07:17 PM | #20 |
The Following User Says Thank You to Tcoat For This Useful Post: | soundman98 (03-25-2019) |
03-25-2019, 08:45 PM | #21 |
how long is short enough for a 'cut off'? i could use a new garage.
03-25-2019, 10:41 PM | #22 |
Sarcastic SOB
Just cut it off cutoffs from a tree.
The Following User Says Thank You to wbradley For This Useful Post: | soundman98 (03-26-2019) |
06-15-2019, 03:14 PM | #23 |
Drives: 2013 FR-S 10-Series
Location: SJ/OC/IE California; Temporarily: Glendale,AZ
Update: I forgot to mention, I found the actual tow hooks that are welded to the frame, located in front of each of the front wheels, that I mentioned using for jacking up the S-chassis. These work perfectly! I will update with a picture when I get the time.
Also I agree, I doubt it will be a good idea to jack it up from a "bolt in tow hook" or license plate frame relocator. Thank you for everyone's insight! |
07-06-2019, 09:24 PM | #24 |
Here it is, there is one on each side of the car for your jacking purposes.
07-07-2019, 07:59 AM | #26 | |
Weight Weenie
Drives: 15 FR-S
The Following User Says Thank You to new2subaru For This Useful Post: | soundman98 (07-07-2019) |
07-07-2019, 11:36 AM | #27 |
I've never seen that on my car... Now i need to look tonight
Also, if i need to jack that far forward, i just use the front crossmember.
07-08-2019, 08:18 AM | #28 |
Those are actually the tie down points for shipping. If you tried to tow by the you would rip your front bumper off. I would be nervous using them as jack points because the small contact area would be an invitation for slipping. They are also not designed to take weight at that angle.
Similar Threads | ||||
Jacking points? | bleox | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 36 | 02-19-2016 01:03 AM |
Jacking points | Qwimby2 | BRZ First-Gen (2012+) -- General Topics | 4 | 12-08-2015 09:48 PM |
Jacking a lowered BRZ/FRS? | swift996 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 03-19-2013 02:04 AM |
Track Tow Hook R&D Thoughts and Comments (Pictures) | NON-VTEC | Scion FR-S / Toyota 86 GT86 General Forum | 24 | 02-06-2013 10:06 AM |
Car Jacking up Points? | J-Money | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 01-21-2013 02:55 PM |
