Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
04-17-2018, 06:17 PM | #43 |
Drives: 2017 BRZ Limited Auto
Or contact Bilstien US and have your shocks and struts tuned to your springs
I had this done on my Road Race Fox Body https://www.bilstein.com/us/en/techn...ledge/service/ Service Information BILSTEIN Technical Center - The official Bilstein Shock Absorber shop in the US offering complete rebuild of most A.M. dampers and customized valving of your aftermarket dampers for motorsports use. Aftermarket Damper Services Standard Aftermarket Damper Rebuild Service / Aftermarket Damper Re-valve Service Standard Aftermarket Damper Rebuild Service (Complete rebuild of most O.E. Fitment, BILSTEIN products only) Monotube non-damping adjustable $95 each Monotube non-damping adjustable Strut $127.50 each Monotube single damping adjustable (Examples incl. Corvette and Ferrari) $160 each Monotube single damping adjustable w/ knob (Examples incl. PSS9) $192 Monotube evolution II Single damping adjustable w/knob (Examples incl. PSS10) $225 Double damping adjustable w/reservoir $257 NOTE: Rebuild service applies to Bilstein products only. Refurbish to drawing specifications. Service includes replacing all seals, wipers, O-rings and oil. Additional parts and services that are not included in the normal scope of service will incur an additional charge (Examples include shock rods, tubes and/or end loops and machine work). Aftermarket Damper Re-valve Service (Complete Rebuild and Customized Tuning of A.M. BILSTEIN products only) Monotube non-damping adjustable $127 Monotube non-damping adjustable Strut $160 Monotube single damping adjustable (Examples incl. Corvette and Ferrari) 192.50 Monotube single damping adjustable w/ knob (Examples incl. PSS9) $225 Monotube evolution II Single damping adjustable w/knob (Examples incl. PSS10) $257.50 Double damping adjustable w/reservoir NOTE: Tuning service applies to BILSTEIN products only. Tuning service includes replacing all seals, wipers, O-rings and oil. All tuned shocks and struts are dynamometer performance checked. Dyno sheets are provided with service. Additional parts and services that are not included in the normal scope of tuning will incur an additional charge (examples include shock rods, tubes and/or end loops and machine work). Tuning fees of $55.00 an hour apply if it is necessary to meet specific damping targets. All non-standard and non-stocked replacement parts are subject to an additional 1 time $65 machini Additional Services 5160 / 5165 refurbish (convert to take apart retro-fit) 5160 / 5165 tuning (convert to take apart retro-fit) New mounting and replacement parts External snap ring grooves for spring seats Damper shaft replacement (Adjustable and non-adjustable) Spring hardware removal and/or installation (if spring compressor tool is required) Dyno evaluation Dyno evaluation of adjustable dampers Damper tube replacement Shop labor Machining Strut bearing replacement Rush service – standard Product Rush service – complex product NOTE: Rebuild service applies to Bilstein products only. Service includes replacing all seals, wipers, O-rings and oil. Additional parts will be replaced at customer expense. Service Address Send units to our California facility: Bilstein Shock Absorbers 14102 Stowe Drive Poway, CA 92064 |
Similar Threads | ||||
Koni Yellow vs. Bilstein B6 vs. Bilstein B8 | shattered_memory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 01-04-2017 11:22 AM |
**NEW**Bilstein B8 HD Struts and Shocks Released | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 118 | 09-12-2016 01:54 PM |
Swift Spec R with Bilstein B8 shocks? | JMoore412 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 05-23-2014 01:52 PM |
Bilstein shocks & struts | Fizz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 10-31-2013 02:56 AM |
JDM BRZ Struts different than USDM BRZ Struts? | switchlanez | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 08-30-2012 10:21 AM |
