05-09-2015, 02:11 AM | #365 | |
What got my attention was the fact that he lost 5 seconds on a 2:38 lap (compared to the A048). (2.38 is not that much time). |
05-09-2015, 04:55 AM | #366 |
Here's a video of a Slalom/Autocross on R888: [ame]http://youtu.be/mFDPw1OQzaQ[/ame]
One can see that lateral accelerations of up to 1.2 g are reached frequently. Unfortunately, I don't have one with the R1R but maybe someone has one with the RE71R for comparison? |
The Following User Says Thank You to rx3 For This Useful Post: | tahdizzle (05-11-2015) |
05-09-2015, 06:54 AM | #367 |
05-09-2015, 09:31 PM | #368 | |
Drives: In Perfect Control At All Times
For most of us, the R888 is not a consideration at all, as the rules make it illegal as a street tire, and it's WAY slow compared to the other DOT "race" tires it is classified with. |
05-09-2015, 10:29 PM | #369 |
Looks like more of a hillclimb mixed with a little autox.
05-10-2015, 02:58 AM | #370 |
Drives: 2013 FRS
I put on 225/45 RE71Rs recently and just went to a parking lot for a baseline "skidpad" test. I didn't mess with pressures or anything and hit 1.28 according to my iphone app. This was on what appeared to be older asphalt with the TRD springs&bars/CS setup. I'm sure there's more grip to be had with a bit more dial in....
Last edited by Briankbot; 05-10-2015 at 12:01 PM. Reason: clarification of car setup |
The Following User Says Thank You to Briankbot For This Useful Post: | rx3 (05-12-2015) |
05-10-2015, 12:35 PM | #371 | |
The R1R in the larger sizes was never as fast as the RS3, Z2*, etc. so I don't expect it to be in the same ballpark as the RE-71R. If it was national competitors would be using them, and right now all anyone is using is the RE-71R and Rival-S. |
05-10-2015, 03:18 PM | #372 | ||
And I read the comment about that RE-71R which lost 5 seconds compared to the A048 on a relatively short lap. Since the R888 is comparable to the A048 this let me to conclude that the RE-71R may not necessarily be faster, than the R1R (since I know that the R1R is definitely not 5 seconds slower than the R888). But my assumption may be wrong and if it's wrong the RE-71R could also be an alternative to the R888 (which is legal where I drive and is used by most people here). The question would then be: How/why can a 200 treadwear tire be faster than a 100 treadwear tire? (Unless that number is just arbitrary.) |
05-10-2015, 09:10 PM | #373 |
Because that number is indeed completely arbitrary.
05-10-2015, 11:31 PM | #374 |
Drives: like an asshat
I too have frequently hit 1.2 Lateral G's on my stones.
05-12-2015, 04:12 PM | #375 | |
Drives: 2014 FR-S
Your comparisons are running in a few too many different directions, with a few too many "close enough" assertions that probably aren't valid. I probably wouldn't judge the twins chances versus an MX-5 by looking at the gap between an RX-8 and 350Z. And that's kind of what you're doing here. I do like the new bridgestones, and the consensus so far is that they're faster than R1Rs (qualifier - 200TW toyos, not the magical 195 pixie dust thing). Plus, as we're hearing with the V720s, not all continents are necessarily getting the same compounds. So, even in the same model, we may not be getting the same things. As for how a 200TW tire can be faster than a 100TW tire...the way those numbers are arrived at is somewhat goofy. You can understate the wear rating, but not overstate it. Sooooo....the ratings can be fudged a bit. There's also very little autocross development done on the R888/RA-1/RR for autocross on this side of the pond. Any class where those tires are legal also have the Hoosiers available, and between those two, it's not even a mildly interesting contest.
-Mike
#24 CS/CSR |
The Following User Says Thank You to TrqlessWonder For This Useful Post: | rx3 (05-14-2015) |
05-14-2015, 09:47 AM | #377 |
Drives: 2017 BRZ
I'm not sure it's known, everyone else I've seen post up about them is either CS or on 245’s. I have 255 but won't get to run them for a couple weeks yet, and at the moment I'm still regaining confidence so may not be the best judge.
The Following User Says Thank You to cjd For This Useful Post: | autoXracer (05-14-2015) |
05-14-2015, 11:32 AM | #378 |
The Stig's German cousin
Try it and let us know!
Similar Threads | ||||
Areddi's Autocross Video Thread | Areddi | Mid-Atlantic | 130 | 05-17-2015 06:19 PM |
Anyone DD 200 Treadwear Tires? | CraftyObeseCrunchyKitty | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 01-09-2015 11:44 AM |
Tire PSI for completely stock autocross? | bladesamurai | Tracking / Autocross / HPDE / Drifting | 16 | 06-11-2013 10:07 AM |
Autocross Tire Pressure on ZII's | Areddi | Tracking / Autocross / HPDE / Drifting | 6 | 04-12-2013 08:37 PM |
KW V3 autocross set-up thread | -max- | Tracking / Autocross / HPDE / Drifting | 97 | 10-18-2012 08:02 PM |
