Forced Induction Turbo, Supercharger, Methanol, Nitrous |
11-14-2013, 08:10 PM | #393 | |
Drives: Raven M/T FR-S
11-14-2013, 10:13 PM | #394 |
Just a dude
Drives: Scion FR-S 2013
Just got mine today looks cool. No instructions on the wiring and so fourth, looks straight forward enough. Did anyone do a DIY for review before I climb into it to not miss anything? I always just like to look b4 doing anything is all. By looks being NA now only need to somehow connect the green wire for dimmer, but no clear indication as it has pre crimped tab on it as well as where to route from the vent tube assembly etc..
11-14-2013, 10:45 PM | #395 |
Drives: FA20Club.com
here is a diagram courtesy of a forum member
11-15-2013, 10:42 AM | #396 |
NASA SpecE30 Racer
None of those wires will work for the dimmer. I believe the only wire that you can use for the dimmer wire is the one going into the back of the stereo headunit. I tried using the wires near the dimmer switch with no success. @Sportsguy83 can probably confirm.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
11-15-2013, 10:50 AM | #397 | |
I Love custom Turbo kits
Drives: Limited BRZ
Yes, if the gauge is looking for a 12V input, the ILL + (or I'LL- depending on what the gauge wants) should work for dimming. Although IIRC, @Foobar tried it for the P3 gauge with no success. If this post has mistakes, blame Autocorrect
11-15-2013, 10:55 AM | #398 | |
SLO NO MO
This being the case, if you connect the green P3 wire to some wire that gets power when your lights are on, you'll be good to go. In Andy's illustration above, the pink parking light wire would do it. Note that that bundle is a pain in the ass to work with given the tight confines and shielding around everything. You'll most likely have to strip some shielding to free up the wires, or get to it from the other side of that harness, towards the firewall. |
The Following 2 Users Say Thank You to Foobar For This Useful Post: | Andy@FA20Club (11-15-2013), King Tut (11-15-2013) |
11-15-2013, 11:00 AM | #399 | |
Drives: Limited BRZ
The ones that do not work because of the above are the ones from the car dimming switch. That being said you are correct, any wire that has 12V when lights are on will work. If this post has mistakes, blame Autocorrect
11-15-2013, 11:00 AM | #400 | |
NASA SpecE30 Racer
- King Tut
11-15-2013, 11:01 AM | #401 |
SLO NO MO
Ah good to know - that should work then. For some reason I thought that the headunit had variable dimming lights.
The Following User Says Thank You to Foobar For This Useful Post: | Sportsguy83 (11-15-2013) |
11-15-2013, 11:40 AM | #402 | |
Seems Legit
Drives: Toyota
Auto-Dimming I didn't get a chance to tidy up my install but essentially the wire I labeled as the positive (+) trigger parking lights is where you want to tap into (i.e. military splice) with the green wire from the P3Cars gauge. Once done, go into the gauge configuration settings and change the dimmer setting to "On.A" then hold the right button to save the option (you gauge will then reset). Now when you turn on the lights, or your lights come on automatically, the gauge will dim. Bright Dim Video showing the transition between bright and dim View P3Cars Gauge Video
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here] |
The Following User Says Thank You to ecko04 For This Useful Post: | Andy@FA20Club (11-15-2013) |
Tags |
gauge, p3cars |
Similar Threads | ||||
LHD 3-meter gauge-pod? | TuxedoCartman | Cosmetic Modification (Interior/Exterior/Lighting) | 27 | 02-11-2015 06:19 PM |
Dash Cam + HU + Reverse Integration | JDMSushi | Electronics | Audio | NAV | Infotainment | 0 | 12-04-2012 06:47 PM |
iPodŽ/USB Integration in the glove box? | 8987846 | Electronics | Audio | NAV | Infotainment | 26 | 12-04-2012 12:45 AM |
Temperature Gauge a dummy gauge? | bambbrose | BRZ First-Gen (2012+) -- General Topics | 40 | 08-19-2012 04:29 PM |
Gauge Sweep? | himbo | BRZ First-Gen (2012+) -- General Topics | 17 | 12-12-2011 11:39 AM |
