Software Tuning Discuss all software tuning topics. |
10-05-2014, 04:32 PM | #1 |
Drives: '13 Whiteout FR-S (M/T)
Any OBD power switch options?
Wondering if anyone has found some elegant way of incorporating an on/off to OBD ports. Specifically, trying to figure something out for my OFT. I know there's the new low power draw option, which is great but there are times where I won't drive the 86 monday through friday. Just want to be extra sure
The Following User Says Thank You to 1Cor10:23 For This Useful Post: | serial gixxer (10-06-2014) |
10-06-2014, 06:22 AM | #2 | |
Drives: FT86
Buy a obd extension cable and put in an inline switch some crowd makes a obd connector with built in switch buy one and make your own cable buying a cheap obd extension and inorporating switch probably cheapest non intrusive way |
The Following 3 Users Say Thank You to steve99 For This Useful Post: |
10-06-2014, 09:10 AM | #3 |
Did some searching - this looks promising : http://www.fes-auto.com/products_det...p?productid=28
Can anyone confirm if the male connector to OFT is indeed a molex 8? Visual inspection looks close... @Shiv@Openflash
10-06-2014, 11:33 AM | #4 |
with the new software update the oft will go to sleep. so now you dont have to worry about unplugging it
10-06-2014, 11:37 AM | #5 |
As noted in OP, will be common for me to not drive my twin for 5+ days at a time, low draw might be too risky in case of unforeseen absences.
10-06-2014, 11:48 AM | #6 |
ah gotcha. i missed that part haha.
The Following User Says Thank You to lucid215 For This Useful Post: | 1Cor10:23 (10-06-2014) |
10-06-2014, 11:53 AM | #7 |
Drives: 2013 GBS BRZ Limited
I thought you were looking for an OBD command to turn off power to the OBD connector.
I thought "Oh that will work, send OBD command to turn off power to the OBD port. Then when you want it back on just send an OBD command to....... wait.." |
The Following User Says Thank You to stugray For This Useful Post: | wparsons (04-15-2015) |
10-06-2014, 12:01 PM | #8 |
Drives: TIE interceptor; BRZ13
Why an on/off switched? why you need a "elegant" way for something that is not visible? Just unplugged it. If you can forget to unplugged then you can easily forget to turn off a "on/off switch". Unless you are thinking of an auto-power off obd cable. What if this elegant solution malfuction during ECU writing process.
OFT may offer this in future firmware anyway.
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
10-06-2014, 12:49 PM | #9 | |
The Following User Says Thank You to 1Cor10:23 For This Useful Post: | TIE Pilot (10-06-2014) |
10-06-2014, 01:14 PM | #10 | |
Not criticizing. Just exploring your idea: cost/pros/cons/alterantives. *In for results
The Following User Says Thank You to TIE Pilot For This Useful Post: | 1Cor10:23 (10-06-2014) |
04-07-2015, 11:27 AM | #11 |
Update - purchased this from Amazon - going to take ages to ship, likely coming from China.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The Following 3 Users Say Thank You to 1Cor10:23 For This Useful Post: |
04-07-2015, 12:30 PM | #12 | |
Drives: 2013 FRS
The Following User Says Thank You to Shiv@Openflash For This Useful Post: | continuecrushing (04-07-2015) |
04-07-2015, 12:44 PM | #13 | |
Stealth
Drives: Ultramarine FR-S
04-07-2015, 12:59 PM | #14 |
Drives: Raven MT
Sub'd
OpenFlash Tablet Tune v2.06 E85 Stage 1 - Grimmspeed Intake, Strut Tower Brace & Master Cylinder Brace - MTEC Clutch & Shifter Springs - TRD Quickshifter - cQuartz Finest Paint Protection Coating - and more to come... |
Similar Threads | ||||
Scion FR-S options:what options did you have dealer installed? | Scionshaun | Scion FR-S / Toyota 86 GT86 General Forum | 42 | 01-06-2014 01:35 AM |
Bushing upgrades, geometry options and other component options? | der_rainman | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-26-2013 12:53 PM |
How to replace turn signals with switch backs and its relay switch. | Scionshaun | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 05-30-2013 11:42 PM |
FRS/BRZ BRUSHED SATIN POWER WINDOW SWITCH TRIM | zetaproducts.net | Interior Parts (Incl. Lighting) | 28 | 05-14-2013 09:32 AM |
Gearing Options and Diff options | airboy808 | Engine, Exhaust, Transmission | 26 | 12-25-2011 01:11 PM |
