Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
05-20-2014, 10:09 PM | #29 | |
-Mike Paisan Maintaining, Modifying and Educating TriState Enthusiasts since 2001. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" |
05-20-2014, 10:14 PM | #30 |
Off Topic
The Following 2 Users Say Thank You to gramicci101 For This Useful Post: | Sportsguy83 (05-21-2014), wparsons (05-22-2014) |
05-20-2014, 10:15 PM | #31 |
Excellent, I was actually in the wine region of the finger lakes at the time. Motul 300V @ 275 hopefully went to red wine!
The Following User Says Thank You to AZP Installs For This Useful Post: | Sportsguy83 (05-21-2014) |
05-20-2014, 10:17 PM | #32 |
Off Topic
The Following 2 Users Say Thank You to gramicci101 For This Useful Post: | AZP Installs (05-21-2014), Sportsguy83 (05-21-2014) |
05-21-2014, 06:54 AM | #33 | |
In all seriousness I am planning on putting together an oil cooler setup for it because 275 imo is a bit high. -mike |
05-21-2014, 09:08 AM | #34 |
Drives: Scion FR-S/Toyota Yaris
[quote]There is also some issue where the AVC clicks-on and can cause an abrupt drop in oil pressure, does anyone have more info on that and would a heavier grade helpr or hurt?
The problem is so few have installed oil pressure gauges. I have all the parts to do it just not the energy at the moment. There were rumors that a mod here saw drastic oil pressure drop at high rpms, but that info is scarce. I wish someone could shed some light on those two issues?
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
05-21-2014, 09:38 AM | #35 | |
Drives: 2004 Subaru Forester 2.5XT
Eco-nergy is thinner at operating temp than X-lite, and is a thin 5W-30, but it has one of the highest HTHS viscosities for an oil that doesn't meet ACEA A3 and Euro builder specs. It's 3.4, so it's lower than X-Lite but still higher than most off the shelf Resource Conserving GF5 oils. I ran it one winter in my Forester XT and it did stay in grade for a 6k-ish interval, IIRC. -Dennis |
The Following User Says Thank You to bluesubie For This Useful Post: | Sportsguy83 (05-21-2014) |
05-21-2014, 09:44 AM | #36 | |
I Love custom Turbo kits
Drives: Limited BRZ
05-21-2014, 10:01 AM | #37 | |
Those oils just don't impress call me old school but for the price little moly & ZDDP and they dom't make claims of new tech protection like Sustana. And they are pricey. I better thicker oil IMHO is the catterham blend with is super high VI and advanced moly (with a half quart 0w30 mobile1 racing oil.) But I'm not convinced thus far from this thread that we need to go thicker, my engine is running great with the high moly 0w20 Mazda GL5 and since updating the calibration no more vvt noise.
05-21-2014, 10:41 AM | #38 | |
In a performance car, I'll take a lower NOACK over a higher VI any day. Take the new Pennzoil Platinum PP: 0W-20: VI = 168 and NOACK = 10.8 5W-20: VI = 158 and NOACK = 8.6 In all likelihood, the 5W-20 will maintain its viscosity better than the 0W-20 because it has fewer viscosity modifiers to begin (more stable base oil). For API/ILSAC certified oils, you're probably not going to do better than an 8.6 NOACK. That's approaching Red Line 5W-20 (NOACK = 8). -Dennis Last edited by bluesubie; 05-22-2014 at 11:35 AM. Reason: Brand info correction |
05-22-2014, 09:08 AM | #39 |
Drives: Currently 2018 Taco
The only reason caterham adds any M1 0W40 to Sustina 0W20 is to obtain adequate oil pressure. The word "thickness" is best used to describe people's skulls. Now there is talk of TGMO having a measured VI of 236. Would Wearcheck please measure the VI of Sustina 0W20 side-by-side with TGMO. Use identical testing procedures under identical conditions, and do it blind. Until then I say bull hockey to the idea of TGMO being superior to and/or lighter than Sustina, with its VI of a paltry 229. Open up bottles of TGMO and Sustina and rub them between your fingers. Drive for more than a few miles on each oil, like I have, then try and tell me that TGMO is lighter than Sustina. So much for the scientific method.
05-27-2014, 06:27 PM | #40 |
At this point if you have an NA car I see absolutely zero reason at this point to switch from 0w20.
Now that I am on my second Supercharged UOA on Redline with 6700 (winter and pre-summer) miles which included track and autox time unless you have a turbo or your car is a dedicated track machine, appears 0w20 is the oil to use. The only gotcha here is you should absolutely run an oil cooler for any track time. But until someone else shows any quality proof I don't see any reason to run a 0w30/5w30. Redline 0w20 | 6700 Miles on Sample 2 Hours Track Time, 50 Autox Runs | 2000 Mile Road Trip RESULTS: VERY GOOD POTENTIAL: Running 10,000 Miles in between changes
05-27-2014, 06:36 PM | #41 |
in orbe terrum non visi
Drives: violent
Anyone else on E85? Ill send mine in as soon as I get my car back.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
05-28-2014, 01:12 AM | #42 |
Drives: 2022 BRZ Limited
Also want to add, my car has seen oil temps 265F when it was completely stock powered (at 55F ambient temps) so I am glad I have been running 0w-40 European formula
Similar Threads | ||||
Quickie: 0w20 vs 5w20 / 5w30 | empower-auto | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 43 | 12-17-2016 01:54 PM |
Servicing at dealership - do they use 0W20? | Fizz | AUSTRALIA | 23 | 01-13-2015 12:55 AM |
Eneos 0w20 | Hayashi | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 154 | 10-27-2014 05:04 PM |
Redline 0w20, notice to vendors/shops | BRZPDX | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 05-06-2014 03:26 PM |
Anyone want 0.65 liters of Amsoil SS 0W20? | Laika | NY / NJ / CT / PA | 0 | 03-31-2013 06:53 PM |
