Old 05-17-2014, 10:38 PM   #1667
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Howardwei View Post
Thanks sports guys. Do you know if the cone like spring that came in with te electric fans cushion are there for a purpose? Where do they go? @Sportsguy83
The spring is supposed to create and keep tension on the radiator zip ties, but I didn't really have room for them the way I ran the zip ties, so I also didn't use them.
Old 05-18-2014, 03:19 AM   #1668
Howardwei
Gasket on down pipe
Hi,
Do you know if the down pipe and turbo hotside is suppose to have a gasket? I didn't get one. And the tab on the air filter sitting about the crash beam doesn't even align with the hole-.-
Howardwei is offline   Reply With Quote
Old 05-18-2014, 09:35 AM   #1669
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
No gasket needed since its a machined surface. I use one anyway but it didnt make a difference. The intake is a tight fit since no two cars super soft motormounts hold the engine in the same spot.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 05-18-2014, 11:40 AM   #1670
mashal
DADA
mashal's Avatar
Drives: 2013
I need some explanation on the exhaust set up on this car, So with the kit I have the EL header and downpipe, also have the greddy 3 catback.. so now am i only missing the front pipe?
mashal is offline   Reply With Quote
Old 05-18-2014, 12:37 PM   #1671
dabocx
dabocx's Avatar
Drives: Scion FRS
Front pipe and overpipe
dabocx is offline   Reply With Quote
The Following User Says Thank You to dabocx For This Useful Post:
mashal (05-18-2014)
Old 05-18-2014, 02:06 PM   #1672
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Hi,
I didn't get a gasket, but just like Reaper I did buy one and installed it later. You need to loosely connect the coupler on the turbo and the pipe until you can get the tab to line up with the bolt hole.
Old 05-19-2014, 05:55 AM   #1673
steveoexige
Drives: UK GT86 in White with alcantara
Guys, my tuner has just gone to fit the FBM 485 pump kit and is concerned as it doesnt seem to fit properly. It just seem to float around in the bottom of the tank (his words). Any suggestions or a link to some install instructions ? Just like my JDL turbo kit FBM didnt ship their pump kit with any instructions
steveoexige is offline   Reply With Quote
Old 05-19-2014, 08:20 AM   #1674
Dipstik-sportech
Dipstik-sportech's Avatar
Originally Posted by Sportsguy83 View Post
The clips will not clip and that is fine. It was designed to not clip and not need any clamps holding it down. When you push down the whole canister into the tank, it will be steady.
Remember, the OEM design holds the FP inside the canister by the force applied on the clamps. FBM design holds the pump in place with the billet piece on the bottom.
The large metal ring goes all the way onto the top of the top canister cover on the bottom part of it. (see pic below). Note and make sure the rubber gasket that usually sits on the mentioned top cover needs to be removed for this. Also, the small rubber o ring on the metal ring needs to face up to the sky.
Good luck and let me know if you need anything else.
Attachment 78926
Read this
The Frozen North
The Following 2 Users Say Thank You to Dipstik-sportech For This Useful Post:
FullBlown (05-19-2014), Sportsguy83 (05-19-2014)
Old 05-20-2014, 09:53 AM   #1675
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
I just "fixed" this problem for a friend of mine. What I did was drill small holes in the mounting tabs that you can't use anymore because the pump is too tall, then drill a hole in the side of the mounting area on the holder and use a tie strap to keep it from moving around.
Also, I've seen a lot of mistakes made when putting in a new pump, the internal hose routing needs to route underneath everything in such a way that it does not interfere with the unit when it's compressed on the slide spring. Otherwise this causes you a lot of issues down the road, kinked hoses, incorrect fuel level readings, etc. Also make sure to solder the leads.. Big pumps make a lot of vibration, crimp connections fail at some point.
Ironsquid is offline   Reply With Quote
The Following User Says Thank You to Ironsquid For This Useful Post:
Sportsguy83 (05-20-2014)
Old 05-20-2014, 11:08 AM   #1676
King Tut
NASA SpecE30 Racer
King Tut's Avatar
That is how I installed both the pump to the inner housing and the inner housing to the outer housing. It worked great for me for many miles. As @Ironsquid mentioned make sure you actually compress the housings prior to reinstall to make sure that the fuel lines and wires have slack and no issues.
Old 05-21-2014, 09:41 PM   #1677
FRS-HHH
igotthatpurp
FRS-HHH's Avatar
On someone who has never installed a turbo kit how hard would it be? Would love to do this myself as I have done all my other mods myself.
FRS-HHH is offline   Reply With Quote
Old 05-22-2014, 09:23 AM   #1678
FullBlown
FullBlown's Avatar
Drives: Scion FRS
It is not hard at all if you follow the instructions. Please PM me your email address and I can send out install instructions for you to review.
FullBlown is offline   Reply With Quote
The Following User Says Thank You to FullBlown For This Useful Post:
Ironsquid (05-22-2014)
Old 05-22-2014, 09:24 AM   #1679
Dipstik-sportech
I've never installed a turbo. If you can work a set of wrenches and a few sockets you'll be fine.
The Frozen North
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
FRS-HHH (05-22-2014)
Old 05-22-2014, 02:02 PM   #1680
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
It's just another bolt on
Take your time, and allow yourself plenty of time to do the work. I knew what I was doing but I still allowed myself two full days dedicated to it.
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
